Result: Success.
========== 2014.01.01 00:00:13 remo-con disconnect======
Packet: P3X_FW_V01.02.0006.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2015.06.20 18:00:04 =====================
Result: Abort.
========== 2015.06.22 09:57:41 =====================
Result: Abort.
Packet: P3X_FW_V01.03.0020.bin
Upgrading ...
Result: Success.
========== 2015.08.22 10:42:13 =====================
Upgrading ...
Result: Success.
Result: Abort.
========== 2015.09.13 12:13:17 =====================
Result: Abort.
Packet: P3X_FW_V01.04.0010.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:14 remo-con disconnect======
Upgrading ...
Result: Success.
========== 2015.09.20 15:14:43 =====================
Result: Abort.
========== 2015.09.20 15:47:11 =====================
Result: Abort.
========== 2015.09.20 17:25:47 =====================
Result: Abort.
========== 2015.09.20 21:03:06 =====================
Result: Abort.
========== 2014.01.01 00:00:12 remo-con disconnect======
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
========== 2015.12.05 16:23:02 =====================
Result: Abort.
========== 2015.12.05 16:30:07 =====================
Result: Abort.
Packet: P3X_FW_V01.06.0040.bin
Upgrading ...
Result: Failed.
========== 2014.01.01 00:00:15 remo-con disconnect======
Result: Failed.
Result: Failed.
Packet: P3X_FW_V01.05.0030.bin
Result: Failed.
========== 2016.03.10 22:01:04 =====================
Result: Failed.
Result: Failed.
Result: Failed.
========== 2014.01.01 00:00:16 remo-con disconnect======
Upgrading ...
Result: Failed.
Result: Failed.
Upgrading ...
Result: Failed.
Result: Failed.
就是这个
