Result: Success.
========== 2014.01.01 00:00:04 remo-con disconnect======
Packet: WM610_FW_V01.03.00.00.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2015.08.06 16:26:03 =====================
Result: Abort.
========== 2015.08.06 18:05:25 =====================
Upgrading ...
Result: Success.
========== 2015.08.06 18:07:39 =====================
Result: Abort.
========== 2015.08.06 18:08:44 =====================
Result: Abort.
========== 2015.08.06 18:09:24 =====================
Upgrading ...
Result: Success.
========== 2015.08.06 18:11:31 =====================
Result: Abort.
Result: Abort.
Upgrading ...
Result: Success.
========== 2015.08.06 18:14:54 =====================
Result: Abort.
========== 2015.08.06 18:15:39 =====================
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
========== 2015.09.09 14:19:14 =====================
Packet: WM610_FW_V01.04.00.10.bin
Upgrading ...
Result: Success.
========== 2015.09.18 01:48:36 =====================
Upgrading ...
========== 2015.09.18 01:49:47 =====================
Upgrading ...
========== 2015.09.18 01:52:12 =====================
========== 2015.09.18 01:53:36 =====================
========== 2015.09.18 01:55:09 =====================
========== 2015.09.18 02:03:34 =====================
Upgrading ...
Result: Success.
========== 2015.09.18 02:26:20 =====================
Upgrading ...
Result: Success.
========== 2015.09.18 02:32:53 =====================
Upgrading ...
Result: Success.
========== 2015.09.18 02:35:08 =====================
Upgrading ...
Result: Success.
========== 2015.09.18 02:37:34 =====================
Upgrading ...
Result: Success.
========== 2015.09.18 02:40:24 =====================
Upgrading ...
Result: Success.
========== 2015.09.18 02:44:04 =====================
Upgrading ...
Result: Success.
========== 2015.09.18 02:51:19 =====================
Result: Abort.
========== 2015.12.08 13:09:51 =====================
Packet: WM610_FW_V01.05.00.30.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2015.12.08 13:16:14 =====================
Result: Failed.
========== 2014.01.01 00:00:07 remo-con disconnect======
========== 2014.01.01 00:00:06 remo-con disconnect======
Result: Failed.
Result: Failed.
========== 2015.12.08 14:22:17 =====================
Result: Failed.
========== 2015.12.24 02:28:30 =====================
Packet: WM610_FW_V01.06.00.40.bin
Result: Failed.
========== 2015.12.24 02:32:09 =====================
Result: Failed.
========== 2015.12.24 02:40:26 =====================
Result: Failed.
========== 2015.12.24 02:49:23 =====================
Upgrading ...
Result: Failed.
========== 2015.12.24 02:55:57 =====================
Result: Failed.
