@所有大神
手机看帖 16 355
“起飞准备”中这个警告你们遇到过吗?什么条件下才会弹出“起飞准备中”的警告?
春媚  管理员 1-22 09:24 2#
您好楼主,很抱歉给您带来困扰。若提示“起飞准备中”,一般是指IMU预热/初始化中或者电池初始化中,只需等待初始化完成,异常提示消失后即可正常起飞。
楼主  Osmo Mobile SE认证用户 1-22 18:58 3#
<div class="quote"><blockquote><a class="nopicture" rel="noopener" href="https://bbs.dji.com/forum.php?mod=redirect&goto=findpost&pid=5198616&ptid=372330" target="_blank"><span class="customName">春媚</span><span class="customShow">超级版主</span><span class="customTime">1-22 09:24</span></a>
<span class="customSpan">您好楼主,很抱歉给您带来困扰。若提示“起飞准备中”,一般是指IMU预热/初始化中或者电池初始化中,只需等待初始化完成,异常提示消失后即可正常起飞。</span></blockquote></div>好的,谢谢啦~
庸碌   1-22 21:23 4#
没事,不用理会,稍等片刻即可,有这是在提示类似于电池在预热
楼主  Osmo Mobile SE认证用户 1-22 22:56 5#
<div class="quote"><blockquote><a class="nopicture" rel="noopener" href="https://bbs.dji.com/forum.php?mod=redirect&goto=findpost&pid=5199446&ptid=372330" target="_blank"><span class="customName">庸碌</span><span class="customShow"></span><span class="customTime">1-22 21:23</span></a>
<span class="customSpan">没事,不用理会,稍等片刻即可,有这是在提示类似于电池在预热</span></blockquote></div>明白了,谢谢告知~
等几秒就没了,或者不管直接内八,他自己就会消失了
这个才叫刺激
楼主  Osmo Mobile SE认证用户 1-23 15:20 8#
<div class="quote"><blockquote><a class="nopicture" rel="noopener" href="https://bbs.dji.com/forum.php?mod=redirect&amp;goto=findpost&amp;pid=5200179&amp;ptid=372330" target="_blank"><span class="customName">mini3Prouser</span><span class="customShow">Osmo Pocket 3</span><span class="customTime">1-23 09:39</span></a>
<span class="customSpan">这个才叫刺激<a class="picture" rel="noopener" href="https://bbs.dji.com/forum.php?mod=redirect&amp;goto=findpost&amp;pid=5200179&amp;ptid=372330" target="_blank">[图片]</a></span></blockquote></div>这个我看过,零下温度太低,大概率是电池加热
楼主  Osmo Mobile SE认证用户 1-23 15:22 9#
<div class="quote"><blockquote><a class="nopicture" rel="noopener" href="https://bbs.dji.com/forum.php?mod=redirect&amp;goto=findpost&amp;pid=5200171&amp;ptid=372330" target="_blank"><span class="customName">mini3Prouser</span><span class="customShow">Osmo Pocket 3</span><span class="customTime">1-23 09:37</span></a>
<span class="customSpan">等几秒就没了,或者不管直接内八,他自己就会消失了</span></blockquote></div>楼主在2楼讲“起飞准备中”,一般是指IMU预热/初始化中或者电池初始化中,所以,还是耐心等等,不差这点时间
春媚  管理员 1-23 15:22 10#
<div class="quote"><blockquote><a class="nopicture" rel="noopener" href="https://bbs.dji.com/forum.php?mod=redirect&amp;goto=findpost&amp;pid=5199294&amp;ptid=372330" target="_blank"><span class="customName">铭铭F</span><span class="customShow"></span><span class="customTime">1-22 18:58</span></a>
<span class="customSpan">好的,谢谢啦~</span></blockquote></div>不客气哦,有问题可及时联系我们。
楼主  Osmo Mobile SE认证用户 1-23 15:24 11#
<div class="quote"><blockquote><a class="nopicture" rel="noopener" href="https://bbs.dji.com/forum.php?mod=redirect&amp;goto=findpost&amp;pid=5200616&amp;ptid=372330" target="_blank"><span class="customName">春媚</span><span class="customShow">超级版主</span><span class="customTime">1-23 15:22</span></a>
<span class="customSpan">不客气哦,有问题可及时联系我们。</span></blockquote></div>
<div class="quote"><blockquote><a class="nopicture" rel="noopener" href="https://bbs.dji.com/forum.php?mod=redirect&goto=findpost&pid=5200615&ptid=372330" target="_blank"><span class="customName">铭铭F</span><span class="customShow"></span><span class="customTime">1-23 15:22</span></a>
<span class="customSpan">楼主在2楼讲“起飞准备中”,一般是指IMU预热/初始化中或者电池初始化中,所以,还是耐心等等,不差这点时间</span></blockquote></div>
毕竟出来飞时间不多了,这个学期都没飞过。马上小升初了。
电池温度不够
楼主  Osmo Mobile SE认证用户 1-23 18:52 14#
<div class="quote"><blockquote><a class="nopicture" rel="noopener" href="https://bbs.dji.com/forum.php?mod=redirect&goto=findpost&pid=5200756&ptid=372330" target="_blank"><span class="customName">小王爱航拍</span><span class="customShow">DJI Mini 3 Pro(带屏遥控器)</span><span class="customTime">1-23 17:39</span></a>
<span class="customSpan">电池温度不够</span></blockquote></div>应该是这个问题(但是南方这边16度)
<div class="quote"><blockquote><a class="nopicture" rel="noopener" href="https://bbs.dji.com/forum.php?mod=redirect&goto=findpost&pid=5200805&ptid=372330" target="_blank"><span class="customName">铭铭F</span><span class="customShow"></span><span class="customTime">1-23 18:52</span></a>
<span class="customSpan">应该是这个问题(但是南方这边16度)</span></blockquote></div>要18度以上
<span class="customSpan">应该是这个问题(但是南方这边16度)</span></blockquote></div>还有IMU每次开机会初始化的
楼主  Osmo Mobile SE认证用户 1-23 23:54 17#
<div class="quote"><blockquote><a class="nopicture" rel="noopener" href="https://bbs.dji.com/forum.php?mod=redirect&goto=findpost&pid=5200846&ptid=372330" target="_blank"><span class="customName">小王爱航拍</span><span class="customShow">DJI Mini 3 Pro(带屏遥控器)</span><span class="customTime">1-23 19:19</span></a>
<span class="customSpan">还有IMU每次开机会初始化的</span></blockquote></div>第一次碰到这个,所以说好奇嘛
收藏 点赞 评论
