The firmware on the SD card is identical to or older than the current firmwar...
升级完成后,卡内的TXT文件就老是报这个问题,The firmware on the SD card is identical to or older than the current firmware on the aircraft.这是啥意思?而且时间老是2014.1.1,具体的就是========== 2014.01.01 00:00:11 remo-con disconnect======Packet: P3X_FW_V01.02.0006.bin
Result: Abort.
有这个是不是表明飞行器升级成功?失败?或者是不用升级了?请专家解答!
