机甲大师SDK编程怎样同时启动多个识别功能?
手机看帖 0 37
代码如下:
from robomaster import robot
line = []
# 重编callback回调函数
def on_detect_line(line_info):
    number = len(line_info)
    line.clear()
    line_type = line_info[0]
    # print('line_type', line_type)
    for i in range(1, number):
        x, y, ceta, c = line_info
        line.append([x, y, ceta, c])
persons = []
def on_detect_person(person_info):
    number = len(person_info)
    persons.clear()
    for i in range(0, number):
        x, y, w, h = person_info
        persons.append([x, y, w, h])
        # print("person: x:{0}, y:{1}, w:{2}, h:{3}".format(x, y, w, h))
if __name__ == '__main__':
    # 初始化
    ep_robot = robot.Robot()
    # 直连模式
    ep_robot.initialize(conn_type="ap")
    # 机器人版本
    ep_version = ep_robot.get_version()
    print("Robot Version: {0}".format(ep_version))
    # 云台跟随底盘
    ep_robot.set_robot_mode(mode=robot.CHASSIS_LEAD)
    # 云台向下旋转10度
    ep_gimbal = ep_robot.gimbal
    ep_gimbal.moveto(pitch=0, yaw=0).wait_for_completed()
    ep_gimbal.move(pitch=-10, yaw=0).wait_for_completed()
    # 初始化麦轮
    ep_chassis = ep_robot.chassis
    # 启动视觉识别
    ep_vision = ep_robot.vision
    # 启动摄像头
    ep_camera = ep_robot.camera
    ep_camera.start_video_stream(display=False)
    # 启动线识别
    ep_vision.sub_detect_info(name="line", color="blue", callback=on_detect_line)
    # 启动人识别
    ep_vision.sub_detect_info(name="person", callback=on_detect_person)
    # threading1 = threading.Thread(target=ep_vision.sub_detect_info, args=('line', 'blue', on_detect_line))
    # threading1.start()
    # time.sleep(2)
    # print(line)
    # threading2 = threading.Thread(target=ep_vision.sub_detect_info, args=('person', '', on_detect_person))
    # threading2.start()
    # time.sleep(2)
    # 这里不管启动不启动多线程,后边都只能输出一个数据。而且启动行人识别后,机器还总有提示声音(怎么去除)。哪位大佬可以帮帮我,怎样在SDK中同时启用多个识别功能啊??非常感谢!!  在模块编程里面转换出来的python代码也不能直接用,有没有API代码转换SDK代码的教程?
    while True:
        print(persons)
        print(line)
收藏 点赞 评论
