Result: Success.
========== 2014.01.01 00:00:04 remo-con disconnect======
Packet: WM610_FW_V01.03.00.00.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
Upgrading ...
Result: Success.
Result: Abort.
Upgrading ...
Result: Success.
Result: Abort.
========== 2015.08.08 12:01:37 =====================
========== 2015.08.10 11:09:48 =====================
Result: Abort.
Packet: WM610_FW_V01.04.00.10.bin
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
Result: Abort.
Packet: WM610_FW_V01.09.01.30.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2014.01.01 00:00:06 remo-con disconnect======
Result: Failed.
========== 2014.01.01 00:00:07 remo-con disconnect======
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
========== 2016.11.29 17:13:52 =====================
Result: Failed.
Result: Failed.
Upgrading ...
Result: Failed.
Result: Failed.
Result: Abort.
Upgrading ...
Result: Success.
Result: Abort.
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Upgrading ...
Result: Failed.
Result: Failed.
