大疆精灵3A相机升级成功 但是飞行器升级错误
手机看帖 6 2971
老师好
我的大疆精灵3A相机升级成功 都是飞行器升级错误
3次了 都这样
app2.4.2 】
遥控器1.5.70
固件1.4.10
显示   模块自检、  飞行器需要升级,请参考服务页面的固件升级的教学视频
         飞行器升级 错误
         解决办法:请按照正确的升级步骤,重新尝试
tsopin.tw@gmail  Mavic Pro认证用户 2015-12-4 3#
沒行器版本是舊的, 新的是 1.5.003. 升級後記得要做 IMU校正, 遙控也做校正. 也要進入 APP檢查設定, 因為有些會被回復回出廠值.
楼主  Phantom 3 Advanced认证用户 2015-12-4 4#
app    2.4.2
遥控器 1.5.70
固件   1.4.10这是我的显示 还是没有成功
楼主  Phantom 3 Advanced认证用户 2015-12-4 5#
P3S_FW_V01.05.0030.bin我就是下的这个 我的飞机是Phantom 3 Advanced
楼主  Phantom 3 Advanced认证用户 2015-12-4 6#
========== 2015.08.28 14:13:55 =====================
Packet: P3S_FW_V01.03.0020.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3S_FW_V01.04.0010.bin
Upgrading ...
========== 2015.10.31 19:52:57 =====================
========== 2015.10.31 19:54:19 =====================
========== 2015.10.31 19:56:16 =====================
Upgrading ...
Result: Success.
========== 2015.12.03 20:12:52 =====================
Packet: P3S_FW_V01.05.0030.bin
Upgrading ...
Result: Failed.
========== 2015.12.03 20:15:23 =====================
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
========== 2014.01.01 00:00:11 remo-con disconnect======
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2015.12.03 20:33:39 =====================
Result: Abort.
========== 2015.12.03 20:39:32 =====================
Upgrading ...
Result: Failed.
========== 2015.12.03 21:16:46 =====================
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
========== 2015.12.04 06:05:09 =====================
Upgrading ...
Result: Success.
========== 2015.12.04 06:30:12 =====================
Upgrading ...
Result: Failed.
升级后的文件显示
楼主  Phantom 3 Advanced认证用户 2015-12-4 7#
升级没有一次成功
楼主  Phantom 3 Advanced认证用户 2015-12-4 8#
肿么没有人回信,郁闷中,,,,,,,,,,,,
收藏 点赞 评论
