升级1.4似乎失败了?
手机看帖 7 2204
一开始DDDD,算是正常吧,半小时后就一直D……个不停,感觉还有噼里啪啦的声音,后臂黄灯闪烁,云台开始是红绿变化,后面一直叫的时候是一直红灯,是不是失败了?
楼主   2015-9-12 3#
升级失败后是否可以降为1.3.2?
冬瑞  管理员 2015-9-12 4#
楼主您好,相机指示灯为红色表示失败哦,建议您重新升级。可以降到1.3.2的,建议您将SD卡文件备份,格式化SD卡后将升级bin文件放进SD卡进行升级。
楼主   2015-9-12 5#
奇怪的是,我把1.3.2的升级放进去,没有声音,只是黄灯在闪,接着我打开遥控器,结果又正常显示摄像头的视频画面,而且可以正常启动发动机(未安装螺旋桨)。
我已经多次升级1.4了,一直都是这样的情况:先DDDD,黄灯闪烁,云台红绿变化,半小时后一直响,云台红灯。
LOG文件信息:
P3S_FW_LOG_AB.txt
[00011930][01 00] Firmware upgrade finished successfully.
[00012042]Done.
[00012071]Packet [C:\P3S_FW_V01.03.0020.bin] resumed, card sn [0x4f532e30].
[00012103]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012166]Version checking[2]...
[00012233][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00012306][03 06][00] v2.1.6.18 -> v2.2.6.19 need upgrade.
[00012351][04 00][00] v1.36.0.0 -> v1.40.0.0 need upgrade.
[00012390][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012530][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00012605][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012680][12 01][00] v1.8.0.0 -> v1.8.0.0
[00012760][12 02][00] v1.8.0.0 -> v1.8.0.0
[00012842][12 03][00] v1.8.0.0 -> v1.8.0.0
[00012874][15 00][00] v1.1.2.0 -> v1.1.2.0
[00012956][17 00][00] v1.1.1.2 -> v1.1.1.7 need upgrade.
[00013076][17 01][00] v1.0.2.4 -> v1.0.2.7 need upgrade.
[00013131][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00013161][01 00][05] v1.20.3419 -> v1.20.3419
[00013191][01 01][00] v1.7.2735 -> v1.20.3419 need upgrade
[00013219]Done.
[00013249]Firmware upgrading[2]...
[00013390][01 01] Firmware upgrade start...
[00043628][01 01] Firmware upgrade finished successfully.
[00043691][17 00] Firmware upgrade start...
[00157398][17 00] Firmware upgrade finished successfully.
[00157442][17 01] Firmware upgrade start...
[00225807][17 01] Firmware upgrade finished successfully.
[00225848][11 00] Firmware upgrade start...
[00278962][11 00] Firmware upgrade finished successfully.
[00279009][03 05] Firmware upgrade start...
[00354709][03 05] Firmware upgrade finished successfully.
[00354935][03 06] Firmware upgrade start...
[00672777][03 06] Firmware upgrade finished successfully.
[00675771][19 00] Firmware upgrade start...
[00842996][19 00] Firmware upgrade finished successfully.
[00843056][04 00] Firmware upgrade start...
[00900264][04 00] Firmware upgrade finished successfully.
[00900295]Done.
[00900332]Version checking[3]...
[00900410][03 05][05] v34.2.0.9 -> v34.2.0.9
[00900591][03 06][05] v2.2.6.19 -> v2.2.6.19
[00900626][04 00][05] v1.40.0.0 -> v1.40.0.0
[00900670][09 00][00] v1.7.0.3 -> v1.7.0.3
[00900772][11 00][05] v1.7.0.0 -> v1.7.0.0
[00900864][12 00][00] v1.8.0.0 -> v1.8.0.0
[00900944][12 01][00] v1.8.0.0 -> v1.8.0.0
[00901020][12 02][00] v1.8.0.0 -> v1.8.0.0
[00901100][12 03][00] v1.8.0.0 -> v1.8.0.0
[00901133][15 00][00] v1.1.2.0 -> v1.1.2.0
[00901219][17 00][05] v1.1.1.7 -> v1.1.1.7
[00901339][17 01][05] v1.0.2.7 -> v1.0.2.7
[00901390][19 00][05] v1.0.8.96 -> v1.0.8.96
[00901420][01 00][05] v1.20.3419 -> v1.20.3419
[00901450][01 01][05] v1.20.3419 -> v1.20.3419
[00901480]Packet upgrade finish successfully.
[00012197]========== remo-con disconnect. boot(15) ============
[00012228]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0x4f532e30].
[00012259]Packet upgrade start...
[00012295]Packet checking...
[00012326]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012357]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012388]Done.
[00012418]Version checking[1]...
[00012491][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012549][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012738][04 00][00] v1.40.0.0 -> v1.40.0.0
[00012794][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012889][11 00][00] v1.7.0.0 -> v1.7.0.0
[00012968][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013045][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013124][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013198][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013231][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013294][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013399][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013453][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013485][01 00][00] v1.20.3419 -> v1.20.3419
[00013515][01 01][00] v1.20.3419 -> v1.20.3419
[00013546]Packet upgrade cancelled at version checking.
[00011902]========== remo-con disconnect. boot(15) ============
[00011933]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0x4f532e30].
[00011964]Packet upgrade start...
[00011998]Packet checking...
[00012120]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012155]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012188]Done.
[00012227]Version checking[1]...
[00012301][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012385][03 06][00] v2.2.6.19 -> v2.3.0.13 need upgrade.
[00012424][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[00012466][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012585][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00012670][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00012765][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00012850][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00012935][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00012971][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013050][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013185][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013245][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013278][01 00][00] v1.20.3419 -> v1.21.3647 need upgrade
[00013310][01 01][00] v1.20.3419 -> v1.21.3647 need upgrade
[00013344]Done.
[00015376]Waiting for user confirm...
[00025409]Timeout, start upgrade automatically.
[00025483]Firmware upgrading[1]...
[00039977][01 00] Firmware upgrade start...
[00011739][01 00] Firmware upgrade finished successfully.
[00011779]Done.
[00011811]Packet [C:\P3S_FW_V01.04.0010.bin] resumed, card sn [0x4f532e30].
[00011848]Packet vlink 01.04.0010 <-> 01.03.0020.
[00011883]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00011915]Version checking[2]...
[00011987][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012051][03 06][00] v2.2.6.19 -> v2.3.0.13 need upgrade.
[00012090][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[00012136][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012247][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00012321][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00012411][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00012486][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00012561][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00012594][15 00][00] v1.1.2.0 -> v1.1.2.0
[00012736][17 00][00] v1.1.1.7 -> v1.1.1.7
[00012856][17 01][00] v1.0.2.7 -> v1.0.2.7
[00012918][19 00][00] v1.0.8.96 -> v1.0.8.96
[00012952][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00012986][01 01][00] v1.20.3419 -> v1.21.3647 need upgrade
[00013019]Done.
[00013052]Firmware upgrading[2]...
[00013196][01 01] Firmware upgrade start...
[00043446][01 01] Firmware upgrade finished successfully.
[00043496][12 00] Firmware upgrade start...
[00106481][12 00] Firmware upgrade finished successfully.
[00106531][12 01] Firmware upgrade start...
[00170570][12 01] Firmware upgrade finished successfully.
[00170624][12 02] Firmware upgrade start...
[00236298][12 02] Firmware upgrade finished successfully.
[00236348][12 03] Firmware upgrade start...
[00304577][12 03] Firmware upgrade finished successfully.
[00304621][11 00] Firmware upgrade start...
[00353806][11 00] Firmware upgrade finished successfully.
[00354046][03 06] Firmware upgrade start...
[00681569][03 06] Firmware upgrade finished successfully.
[00681631][04 00] Firmware upgrade start...
[00739974][04 00] Firmware upgrade finished successfully.
[00740014]Done.
[00740048]Version checking[3]...
[00740306][03 05][00] v34.2.0.9 -> v34.2.0.9
[00740392][03 06][05] v2.3.0.13 -> v2.3.0.13
[00740431][04 00][05] v1.41.0.0 -> v1.41.0.0
[00740475][09 00][00] v1.7.0.3 -> v1.7.0.3
[00740646][11 00][05] v1.7.0.0 -> v1.7.0.0
[00740726][12 00][05] v1.10.0.0 -> v1.10.0.0
[00740846][12 01][05] v1.10.0.0 -> v1.10.0.0
[00740921][12 02][05] v1.10.0.0 -> v1.10.0.0
[00741020][12 03][05] v1.10.0.0 -> v1.10.0.0
[00741056][15 00][00] v1.1.2.0 -> v1.1.2.0
[00741137][17 00][00] v1.1.1.7 -> v1.1.1.7
[00741256][17 01][00] v1.0.2.7 -> v1.0.2.7
[00741316][19 00][00] v1.0.8.96 -> v1.0.8.96
[00741352][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00741386][01 01][05] v1.21.3647 -> v1.21.3647
[00741419]Done.
[00741458]Firmware upgrading[3]...
[00741491]Done.
[00741525]Version checking[4]...
[00741690][03 05][00] v34.2.0.9 -> v34.2.0.9
[00741747][03 06][05] v2.3.0.13 -> v2.3.0.13
[00741794][04 00][05] v1.41.0.0 -> v1.41.0.0
[00741855][09 00][00] v1.7.0.3 -> v1.7.0.3
[00741967][11 00][05] v1.7.0.0 -> v1.7.0.0
[00742035][12 00][05] v1.10.0.0 -> v1.10.0.0
[00742121][12 01][05] v1.10.0.0 -> v1.10.0.0
[00742220][12 02][05] v1.10.0.0 -> v1.10.0.0
[00742300][12 03][05] v1.10.0.0 -> v1.10.0.0
[00742336][15 00][00] v1.1.2.0 -> v1.1.2.0
[00742416][17 00][00] v1.1.1.7 -> v1.1.1.7
[00742540][17 01][00] v1.0.2.7 -> v1.0.2.7
[00742595][19 00][00] v1.0.8.96 -> v1.0.8.96
[00742628][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00742668][01 01][05] v1.21.3647 -> v1.21.3647
[00742702]Done.
[00742737]Firmware upgrading[4]...
[00742776]Done.
[00742811]Version checking[5]...
[00742867][03 05][00] v34.2.0.9 -> v34.2.0.9
[00742927][03 06][05] v2.3.0.13 -> v2.3.0.13
[00742975][04 00][05] v1.41.0.0 -> v1.41.0.0
[00743036][09 00][00] v1.7.0.3 -> v1.7.0.3
[00743307][11 00][05] v1.7.0.0 -> v1.7.0.0
[00743395][12 00][05] v1.10.0.0 -> v1.10.0.0
[00743486][12 01][05] v1.10.0.0 -> v1.10.0.0
[00743561][12 02][05] v1.10.0.0 -> v1.10.0.0
[00743635][12 03][05] v1.10.0.0 -> v1.10.0.0
[00743670][15 00][00] v1.1.2.0 -> v1.1.2.0
[00743739][17 00][00] v1.1.1.7 -> v1.1.1.7
[00743855][17 01][00] v1.0.2.7 -> v1.0.2.7
[00743915][19 00][00] v1.0.8.96 -> v1.0.8.96
[00743949][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00743988][01 01][05] v1.21.3647 -> v1.21.3647
[00744023]Done.
[00744056]Firmware upgrading[5]...
[00744095]Done.
[00744129]Version checking[6]...
[00744207][03 05][00] v34.2.0.9 -> v34.2.0.9
[00744291][03 06][05] v2.3.0.13 -> v2.3.0.13
[00744348][04 00][05] v1.41.0.0 -> v1.41.0.0
[00744396][09 00][00] v1.7.0.3 -> v1.7.0.3
[00744506][11 00][05] v1.7.0.0 -> v1.7.0.0
[00744597][12 00][05] v1.10.0.0 -> v1.10.0.0
[00744686][12 01][05] v1.10.0.0 -> v1.10.0.0
[00744762][12 02][05] v1.10.0.0 -> v1.10.0.0
[00744836][12 03][05] v1.10.0.0 -> v1.10.0.0
[00744952][15 00][00] v1.1.2.0 -> v1.1.2.0
[00745017][17 00][00] v1.1.1.7 -> v1.1.1.7
[00745136][17 01][00] v1.0.2.7 -> v1.0.2.7
[00745196][19 00][00] v1.0.8.96 -> v1.0.8.96
[00745230][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00745266][01 01][05] v1.21.3647 -> v1.21.3647
[00745307]Packet upgrade failed at firmware upgrade.
[00012080]========== remo-con disconnect. boot(15) ============
[00012113]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0x4f532e30].
[00012149]Packet upgrade start...
[00012187]Packet checking...
[00012230]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012266]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012300]Done.
[00012334]Version checking[1]...
[00012411][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012490][03 06][00] v2.3.0.13 -> v2.3.0.13
[00012540][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012590][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012730][11 00][00] v1.7.0.0 -> v1.7.0.0
[00012824][12 00][00] v1.10.0.0 -> v1.10.0.0
[00012899][12 01][00] v1.10.0.0 -> v1.10.0.0
[00012998][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013090][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013135][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013220][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013339][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013389][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013425][01 00][00] v1.20.3419 -> v1.21.3647 need upgrade
[00013460][01 01][00] v1.21.3647 -> v1.21.3647
[00013494]Done.
[00015528]Waiting for user confirm...
[00025563]Timeout, start upgrade automatically.
[00025634]Firmware upgrading[1]...
[00040619][01 00] Firmware upgrade start...
[00011781]Done.
[00011815]Packet [C:\P3S_FW_V01.04.0010.bin] resumed, card sn [0x4f532e30].
[00011853]Packet vlink 01.04.0010 <-> 01.03.0020.
[00011891]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00011926]Version checking[2]...
[00012175][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012249][03 06][00] v2.3.0.13 -> v2.3.0.13
[00012387][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012448][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012574][11 00][00] v1.7.0.0 -> v1.7.0.0
[00012668][12 00][00] v1.10.0.0 -> v1.10.0.0
[00012769][12 01][00] v1.10.0.0 -> v1.10.0.0
[00012869][12 02][00] v1.10.0.0 -> v1.10.0.0
[00012969][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013008][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013098][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013238][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013289][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013326][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00013362][01 01][00] v1.21.3647 -> v1.21.3647
[00013397]Done.
[00013431]Firmware upgrading[2]...
[00013467]Done.
[00013503]Version checking[3]...
[00013590][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013675][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013716][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013790][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013909][11 00][00] v1.7.0.0 -> v1.7.0.0
[00014003][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014083][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014175][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014258][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014297][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014398][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014518][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014589][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014625][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00014662][01 01][00] v1.21.3647 -> v1.21.3647
[00014696]Done.
[00014734]Firmware upgrading[3]...
[00014770]Done.
[00014806]Version checking[4]...
[00014889][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014975][03 06][00] v2.3.0.13 -> v2.3.0.13
[00015017][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015069][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015190][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015469][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015570][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015669][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015769][12 03][00] v1.10.0.0 -> v1.10.0.0
[00015806][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015899][17 00][00] v1.1.1.7 -> v1.1.1.7
[00016098][17 01][00] v1.0.2.7 -> v1.0.2.7
[00016170][19 00][00] v1.0.8.96 -> v1.0.8.96
[00016208][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00016246][01 01][00] v1.21.3647 -> v1.21.3647
[00016282]Done.
[00016317]Firmware upgrading[4]...
[00016353]Done.
[00016390]Version checking[5]...
[00016474][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016554][03 06][00] v2.3.0.13 -> v2.3.0.13
[00016597][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016648][09 00][00] v1.7.0.3 -> v1.7.0.3
[00016775][11 00][00] v1.7.0.0 -> v1.7.0.0
[00016863][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016938][12 01][00] v1.10.0.0 -> v1.10.0.0
[00017029][12 02][00] v1.10.0.0 -> v1.10.0.0
[00017130][12 03][00] v1.10.0.0 -> v1.10.0.0
[00017171][15 00][00] v1.1.2.0 -> v1.1.2.0
[00017259][17 00][00] v1.1.1.7 -> v1.1.1.7
[00017379][17 01][00] v1.0.2.7 -> v1.0.2.7
[00017429][19 00][00] v1.0.8.96 -> v1.0.8.96
[00017466][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00017508][01 01][00] v1.21.3647 -> v1.21.3647
[00017546]Done.
[00017582]Firmware upgrading[5]...
[00017618]Done.
[00017655]Version checking[6]...
[00017740][03 05][00] v34.2.0.9 -> v34.2.0.9
[00017810][03 06][00] v2.3.0.13 -> v2.3.0.13
[00017854][04 00][00] v1.41.0.0 -> v1.41.0.0
[00017910][09 00][00] v1.7.0.3 -> v1.7.0.3
[00018051][11 00][00] v1.7.0.0 -> v1.7.0.0
[00018143][12 00][00] v1.10.0.0 -> v1.10.0.0
[00018218][12 01][00] v1.10.0.0 -> v1.10.0.0
[00018310][12 02][00] v1.10.0.0 -> v1.10.0.0
[00018409][12 03][00] v1.10.0.0 -> v1.10.0.0
[00018449][15 00][00] v1.1.2.0 -> v1.1.2.0
[00018699][17 00][00] v1.1.1.7 -> v1.1.1.7
[00018839][17 01][00] v1.0.2.7 -> v1.0.2.7
[00018890][19 00][00] v1.0.8.96 -> v1.0.8.96
[00018927][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00018964][01 01][00] v1.21.3647 -> v1.21.3647
[00018999]Packet upgrade failed at firmware upgrade.
[00012149]========== remo-con disconnect. boot(15) ============
[00012186]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0x4f532e30].
[00012313]Packet upgrade start...
[00012359]Packet checking...
[00012400]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012446]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012485]Done.
[00012525]Version checking[1]...
[00012609][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012689][03 06][00] v2.3.0.13 -> v2.3.0.13
[00012742][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012809][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012933][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013023][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013130][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013223][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013330][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013370][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013459][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013579][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013629][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013668][01 00][00] v1.20.3419 -> v1.21.3647 need upgrade
[00013707][01 01][00] v1.21.3647 -> v1.21.3647
[00013753]Done.
[00015790]Waiting for user confirm...
[00025829]Timeout, start upgrade automatically.
[00025907]Firmware upgrading[1]...
[00040531][01 00] Firmware upgrade start...
[00011734][01 00] Firmware upgrade finished successfully.
[00011780]Done.
[00011818]Packet [C:\P3S_FW_V01.04.0010.bin] resumed, card sn [0x4f532e30].
[00011860]Packet vlink 01.04.0010 <-> 01.03.0020.
[00011901]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00011940]Version checking[2]...
[00012019][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012099][03 06][00] v2.3.0.13 -> v2.3.0.13
[00012151][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012197][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012318][11 00][00] v1.7.0.0 -> v1.7.0.0
[00012402][12 00][00] v1.10.0.0 -> v1.10.0.0
[00012493][12 01][00] v1.10.0.0 -> v1.10.0.0
[00012593][12 02][00] v1.10.0.0 -> v1.10.0.0
[00012693][12 03][00] v1.10.0.0 -> v1.10.0.0
[00012735][15 00][00] v1.1.2.0 -> v1.1.2.0
[00012823][17 00][00] v1.1.1.7 -> v1.1.1.7
[00012943][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013078][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013123][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00013163][01 01][00] v1.21.3647 -> v1.21.3647
[00013202]Done.
[00013241]Firmware upgrading[2]...
[00013280]Done.
[00013319]Version checking[3]...
[00013399][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013480][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013525][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013577][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013699][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013812][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013912][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014012][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014112][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014154][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014243][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014373][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014438][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014476][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00014515][01 01][00] v1.21.3647 -> v1.21.3647
[00014555]Done.
[00014594]Firmware upgrading[3]...
[00014633]Done.
[00014672]Version checking[4]...
[00014759][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014840][03 06][00] v2.3.0.13 -> v2.3.0.13
[00014891][04 00][00] v1.41.0.0 -> v1.41.0.0
[00014958][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015079][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015173][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015273][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015373][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015473][12 03][00] v1.10.0.0 -> v1.10.0.0
[00015514][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015602][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015723][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015817][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015857][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00015897][01 01][00] v1.21.3647 -> v1.21.3647
[00015937]Done.
[00015976]Firmware upgrading[4]...
[00016015]Done.
[00016054]Version checking[5]...
[00016141][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016219][03 06][00] v2.3.0.13 -> v2.3.0.13
[00016266][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016418][09 00][00] v1.7.0.3 -> v1.7.0.3
[00016538][11 00][00] v1.7.0.0 -> v1.7.0.0
[00016633][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016739][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016834][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016939][12 03][00] v1.10.0.0 -> v1.10.0.0
[00016981][15 00][00] v1.1.2.0 -> v1.1.2.0
[00017068][17 00][00] v1.1.1.7 -> v1.1.1.7
[00017188][17 01][00] v1.0.2.7 -> v1.0.2.7
[00017258][19 00][00] v1.0.8.96 -> v1.0.8.96
[00017298][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00017339][01 01][00] v1.21.3647 -> v1.21.3647
[00017379]Done.
[00017419]Firmware upgrading[5]...
[00017459]Done.
[00017505]Version checking[6]...
[00017599][03 05][00] v34.2.0.9 -> v34.2.0.9
[00017679][03 06][00] v2.3.0.13 -> v2.3.0.13
[00017733][04 00][00] v1.41.0.0 -> v1.41.0.0
[00017797][09 00][00] v1.7.0.3 -> v1.7.0.3
[00017919][11 00][00] v1.7.0.0 -> v1.7.0.0
[00018028][12 00][00] v1.10.0.0 -> v1.10.0.0
[00018103][12 01][00] v1.10.0.0 -> v1.10.0.0
[00018219][12 02][00] v1.10.0.0 -> v1.10.0.0
[00018303][12 03][00] v1.10.0.0 -> v1.10.0.0
[00018346][15 00][00] v1.1.2.0 -> v1.1.2.0
[00018443][17 00][00] v1.1.1.7 -> v1.1.1.7
[00018573][17 01][00] v1.0.2.7 -> v1.0.2.7
[00018638][19 00][00] v1.0.8.96 -> v1.0.8.96
[00018678][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00018718][01 01][00] v1.21.3647 -> v1.21.3647
[00018758]Packet upgrade failed at firmware upgrade.
[00011980]========== remo-con disconnect. boot(15) ============
[00012021]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0x4f532e30].
[00012061]Packet upgrade start...
[00012107]Packet checking...
[00012151]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012191]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012237]Done.
[00012278]Version checking[1]...
[00012343][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012427][03 06][00] v2.3.0.13 -> v2.3.0.13
[00012474][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012532][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012643][11 00][00] v1.7.0.0 -> v1.7.0.0
[00012827][12 00][00] v1.10.0.0 -> v1.10.0.0
[00012911][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013001][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013076][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013126][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013216][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013333][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013391][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013432][01 00][00] v1.20.3419 -> v1.21.3647 need upgrade
[00013472][01 01][00] v1.21.3647 -> v1.21.3647
[00013512]Done.
[00015558]Waiting for user confirm...
[00025599]Timeout, start upgrade automatically.
[00025683]Firmware upgrading[1]...
[00040357][01 00] Firmware upgrade start...
[00011784]Done.
[00011825]Packet [C:\P3S_FW_V01.04.0010.bin] resumed, card sn [0x4f532e30].
[00011870]Packet vlink 01.04.0010 <-> 01.03.0020.
[00011911]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00011953]Version checking[2]...
[00012026][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012092][03 06][00] v2.3.0.13 -> v2.3.0.13
[00012147][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012195][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012307][11 00][00] v1.7.0.0 -> v1.7.0.0
[00012396][12 00][00] v1.10.0.0 -> v1.10.0.0
[00012476][12 01][00] v1.10.0.0 -> v1.10.0.0
[00012756][12 02][00] v1.10.0.0 -> v1.10.0.0
[00012837][12 03][00] v1.10.0.0 -> v1.10.0.0
[00012881][15 00][00] v1.1.2.0 -> v1.1.2.0
[00012956][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013076][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013136][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013178][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00013220][01 01][00] v1.21.3647 -> v1.21.3647
[00013262]Done.
[00013303]Firmware upgrading[2]...
[00013345]Done.
[00013386]Version checking[3]...
[00013472][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013547][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013592][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013655][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013772][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013941][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014040][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014116][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014197][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014241][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014316][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014438][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014496][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014539][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00014582][01 01][00] v1.21.3647 -> v1.21.3647
[00014624]Done.
[00014666]Firmware upgrading[3]...
[00014706]Done.
[00014748]Version checking[4]...
[00014827][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014907][03 06][00] v2.3.0.13 -> v2.3.0.13
[00014962][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015016][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015126][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015196][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015277][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015386][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015477][12 03][00] v1.10.0.0 -> v1.10.0.0
[00015522][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015616][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015739][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015977][19 00][00] v1.0.8.96 -> v1.0.8.96
[00016019][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00016062][01 01][00] v1.21.3647 -> v1.21.3647
[00016104]Done.
[00016148]Firmware upgrading[4]...
[00016192]Done.
[00016235]Version checking[5]...
[00016307][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016387][03 06][00] v2.3.0.13 -> v2.3.0.13
[00016435][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016496][09 00][00] v1.7.0.3 -> v1.7.0.3
[00016607][11 00][00] v1.7.0.0 -> v1.7.0.0
[00016707][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016795][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016881][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016961][12 03][00] v1.10.0.0 -> v1.10.0.0
[00017006][15 00][00] v1.1.2.0 -> v1.1.2.0
[00017077][17 00][00] v1.1.1.7 -> v1.1.1.7
[00017196][17 01][00] v1.0.2.7 -> v1.0.2.7
[00017255][19 00][00] v1.0.8.96 -> v1.0.8.96
[00017372][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00017415][01 01][00] v1.21.3647 -> v1.21.3647
[00017459]Done.
[00017508]Firmware upgrading[5]...
[00017550]Done.
[00017592]Version checking[6]...
[00017673][03 05][00] v34.2.0.9 -> v34.2.0.9
[00017749][03 06][00] v2.3.0.13 -> v2.3.0.13
[00017797][04 00][00] v1.41.0.0 -> v1.41.0.0
[00017856][09 00][00] v1.7.0.3 -> v1.7.0.3
[00017972][11 00][00] v1.7.0.0 -> v1.7.0.0
[00018056][12 00][00] v1.10.0.0 -> v1.10.0.0
[00018141][12 01][00] v1.10.0.0 -> v1.10.0.0
[00018221][12 02][00] v1.10.0.0 -> v1.10.0.0
[00018296][12 03][00] v1.10.0.0 -> v1.10.0.0
[00018342][15 00][00] v1.1.2.0 -> v1.1.2.0
[00018437][17 00][00] v1.1.1.7 -> v1.1.1.7
[00018556][17 01][00] v1.0.2.7 -> v1.0.2.7
[00018616][19 00][00] v1.0.8.96 -> v1.0.8.96
[00018660][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00018703][01 01][00] v1.21.3647 -> v1.21.3647
[00018747]Packet upgrade failed at firmware upgrade.
[00012000]========== remo-con disconnect. boot(15) ============
[00012044]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0x4f532e30].
[00012087]Packet upgrade start...
[00012137]Packet checking...
[00012181]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012232]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012273]Done.
[00012315]Version checking[1]...
[00012406][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012485][03 06][00] v2.3.0.13 -> v2.3.0.13
[00012543][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012605][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012846][11 00][00] v1.7.0.0 -> v1.7.0.0
[00012939][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013039][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013139][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013240][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013286][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013395][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013695][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013786][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013830][01 00][00] v1.20.3419 -> v1.21.3647 need upgrade
[00013874][01 01][00] v1.21.3647 -> v1.21.3647
[00014013]Done.
[00016058]Waiting for user confirm...
[00026101]Timeout, start upgrade automatically.
[00026191]Firmware upgrading[1]...
[00040781][01 00] Firmware upgrade start...
[00011721][01 00] Firmware upgrade finished successfully.
[00011767]Done.
[00011814]Packet [C:\P3S_FW_V01.04.0010.bin] resumed, card sn [0x4f532e30].
[00011862]Packet vlink 01.04.0010 <-> 01.03.0020.
[00011908]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00011951]Version checking[2]...
[00012034][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012115][03 06][00] v2.3.0.13 -> v2.3.0.13
[00012165][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012233][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012354][11 00][00] v1.7.0.0 -> v1.7.0.0
[00012447][12 00][00] v1.10.0.0 -> v1.10.0.0
[00012547][12 01][00] v1.10.0.0 -> v1.10.0.0
[00012647][12 02][00] v1.10.0.0 -> v1.10.0.0
[00012747][12 03][00] v1.10.0.0 -> v1.10.0.0
[00012793][15 00][00] v1.1.2.0 -> v1.1.2.0
[00012877][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013017][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013073][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013124][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00013168][01 01][00] v1.21.3647 -> v1.21.3647
[00013210]Done.
[00013254]Firmware upgrading[2]...
[00013299]Done.
[00013343]Version checking[3]...
[00013434][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013514][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013571][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013633][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013756][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013855][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014123][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014222][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014322][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014369][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014462][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014612][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014673][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014718][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00014762][01 01][00] v1.21.3647 -> v1.21.3647
[00014888]Done.
[00014932]Firmware upgrading[3]...
[00014976]Done.
[00015021]Version checking[4]...
[00015115][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015194][03 06][00] v2.3.0.13 -> v2.3.0.13
[00015246][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015313][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015455][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015543][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015643][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015742][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015842][12 03][00] v1.10.0.0 -> v1.10.0.0
[00015891][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015998][17 00][00] v1.1.1.7 -> v1.1.1.7
[00016117][17 01][00] v1.0.2.7 -> v1.0.2.7
[00016179][19 00][00] v1.0.8.96 -> v1.0.8.96
[00016225][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00016269][01 01][00] v1.21.3647 -> v1.21.3647
[00016312]Done.
[00016357]Firmware upgrading[4]...
[00016401]Done.
[00016446]Version checking[5]...
[00016533][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016618][03 06][00] v2.3.0.13 -> v2.3.0.13
[00016669][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016732][09 00][00] v1.7.0.3 -> v1.7.0.3
[00016854][11 00][00] v1.7.0.0 -> v1.7.0.0
[00016947][12 00][00] v1.10.0.0 -> v1.10.0.0
[00017047][12 01][00] v1.10.0.0 -> v1.10.0.0
[00017148][12 02][00] v1.10.0.0 -> v1.10.0.0
[00017248][12 03][00] v1.10.0.0 -> v1.10.0.0
[00017294][15 00][00] v1.1.2.0 -> v1.1.2.0
[00017403][17 00][00] v1.1.1.7 -> v1.1.1.7
[00017703][17 01][00] v1.0.2.7 -> v1.0.2.7
[00017793][19 00][00] v1.0.8.96 -> v1.0.8.96
[00017838][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00017884][01 01][00] v1.21.3647 -> v1.21.3647
[00017927]Done.
[00017976]Firmware upgrading[5]...
[00018021]Done.
[00018066]Version checking[6]...
[00018155][03 05][00] v34.2.0.9 -> v34.2.0.9
[00018235][03 06][00] v2.3.0.13 -> v2.3.0.13
[00018286][04 00][00] v1.41.0.0 -> v1.41.0.0
[00018353][09 00][00] v1.7.0.3 -> v1.7.0.3
[00018474][11 00][00] v1.7.0.0 -> v1.7.0.0
[00018582][12 00][00] v1.10.0.0 -> v1.10.0.0
[00018787][12 01][00] v1.10.0.0 -> v1.10.0.0
[00018891][12 02][00] v1.10.0.0 -> v1.10.0.0
[00019008][12 03][00] v1.10.0.0 -> v1.10.0.0
[00019055][15 00][00] v1.1.2.0 -> v1.1.2.0
[00019138][17 00][00] v1.1.1.7 -> v1.1.1.7
[00019278][17 01][00] v1.0.2.7 -> v1.0.2.7
[00019357][19 00][00] v1.0.8.96 -> v1.0.8.96
[00019404][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00019451][01 01][00] v1.21.3647 -> v1.21.3647
[00019496]Packet upgrade failed at firmware upgrade.
[00012216]========== remo-con disconnect. boot(15) ============
[00012263]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0x4f532e30].
[00012309]Packet upgrade start...
[00012358]Packet checking...
[00012406]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012462]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012508]Done.
[00012554]Version checking[1]...
[00012636][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012721][03 06][00] v2.3.0.13 -> v2.2.6.19
[00012776][04 00][00] v1.41.0.0 -> v1.40.0.0
[00012840][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012976][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013076][12 00][00] v1.10.0.0 -> v1.8.0.0
[00013185][12 01][00] v1.10.0.0 -> v1.8.0.0
[00013285][12 02][00] v1.10.0.0 -> v1.8.0.0
[00013386][12 03][00] v1.10.0.0 -> v1.8.0.0
[00013435][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013536][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013662][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013721][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013776][01 00][00] v1.20.3419 -> v1.20.3419
[00013824][01 01][00] v1.21.3647 -> v1.20.3419
[00013871]Packet upgrade cancelled at version checking.
[00012017]========== remo-con disconnect. boot(15) ============
[00012063]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0x4f532e30].
[00012108]Packet upgrade start...
[00012157]Packet checking...
[00012204]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012260]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012483]Done.
[00012529]Version checking[1]...
[00012678][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012778][03 06][00] v2.3.0.13 -> v2.3.0.13
[00012834][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012902][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013037][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013122][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013212][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013311][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013411][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013460][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013543][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013661][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013727][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013774][01 00][00] v1.20.3419 -> v1.21.3647 need upgrade
[00013822][01 01][00] v1.21.3647 -> v1.21.3647
[00013870]Done.
[00015915]Waiting for user confirm...
[00025961]Timeout, start upgrade automatically.
[00026057]Firmware upgrading[1]...
[00040688][01 00] Firmware upgrade start...
[00011790]Done.
[00011837]Packet [C:\P3S_FW_V01.04.0010.bin] resumed, card sn [0x4f532e30].
[00011887]Packet vlink 01.04.0010 <-> 01.03.0020.
[00011936]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00011982]Version checking[2]...
[00012061][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012141][03 06][00] v2.3.0.13 -> v2.3.0.13
[00012193][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012264][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012382][11 00][00] v1.7.0.0 -> v1.7.0.0
[00012470][12 00][00] v1.10.0.0 -> v1.10.0.0
[00012570][12 01][00] v1.10.0.0 -> v1.10.0.0
[00012670][12 02][00] v1.10.0.0 -> v1.10.0.0
[00012750][12 03][00] v1.10.0.0 -> v1.10.0.0
[00012799][15 00][00] v1.1.2.0 -> v1.1.2.0
[00012885][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013024][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013084][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013299][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00013347][01 01][00] v1.21.3647 -> v1.21.3647
[00013392]Done.
[00013439]Firmware upgrading[2]...
[00013485]Done.
[00013538]Version checking[3]...
[00013621][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013820][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013876][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013944][09 00][00] v1.7.0.3 -> v1.7.0.3
[00014061][11 00][00] v1.7.0.0 -> v1.7.0.0
[00014150][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014250][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014349][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014430][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014479][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014584][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014704][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014785][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014830][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00014884][01 01][00] v1.21.3647 -> v1.21.3647
[00014932]Done.
[00014979]Firmware upgrading[3]...
[00015026]Done.
[00015072]Version checking[4]...
[00015160][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015240][03 06][00] v2.3.0.13 -> v2.3.0.13
[00015297][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015364][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015480][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015589][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015690][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015814][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015914][12 03][00] v1.10.0.0 -> v1.10.0.0
[00015965][15 00][00] v1.1.2.0 -> v1.1.2.0
[00016045][17 00][00] v1.1.1.7 -> v1.1.1.7
[00016165][17 01][00] v1.0.2.7 -> v1.0.2.7
[00016244][19 00][00] v1.0.8.96 -> v1.0.8.96
[00016291][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00016339][01 01][00] v1.21.3647 -> v1.21.3647
[00016387]Done.
[00016433]Firmware upgrading[4]...
[00016642]Done.
[00016691]Version checking[5]...
[00016799][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016880][03 06][00] v2.3.0.13 -> v2.3.0.13
[00016943][04 00][00] v1.41.0.0 -> v1.41.0.0
[00017004][09 00][00] v1.7.0.3 -> v1.7.0.3
[00017140][11 00][00] v1.7.0.0 -> v1.7.0.0
[00017240][12 00][00] v1.10.0.0 -> v1.10.0.0
[00017325][12 01][00] v1.10.0.0 -> v1.10.0.0
[00017414][12 02][00] v1.10.0.0 -> v1.10.0.0
[00017514][12 03][00] v1.10.0.0 -> v1.10.0.0
[00017640][15 00][00] v1.1.2.0 -> v1.1.2.0
[00017733][17 00][00] v1.1.1.7 -> v1.1.1.7
[00017870][17 01][00] v1.0.2.7 -> v1.0.2.7
[00017945][19 00][00] v1.0.8.96 -> v1.0.8.96
[00017992][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00018040][01 01][00] v1.21.3647 -> v1.21.3647
[00018089]Done.
[00018139]Firmware upgrading[5]...
[00018188]Done.
[00018237]Version checking[6]...
[00018321][03 05][00] v34.2.0.9 -> v34.2.0.9
[00018421][03 06][00] v2.3.0.13 -> v2.3.0.13
[00018477][04 00][00] v1.41.0.0 -> v1.41.0.0
[00018565][09 00][00] v1.7.0.3 -> v1.7.0.3
[00018680][11 00][00] v1.7.0.0 -> v1.7.0.0
[00018789][12 00][00] v1.10.0.0 -> v1.10.0.0
[00018891][12 01][00] v1.10.0.0 -> v1.10.0.0
[00018989][12 02][00] v1.10.0.0 -> v1.10.0.0
[00019091][12 03][00] v1.10.0.0 -> v1.10.0.0
[00019143][15 00][00] v1.1.2.0 -> v1.1.2.0
[00019229][17 00][00] v1.1.1.7 -> v1.1.1.7
[00019381][17 01][00] v1.0.2.7 -> v1.0.2.7
[00019444][19 00][00] v1.0.8.96 -> v1.0.8.96
[00019492][01 00][02] v1.20.3419 -> v1.21.3647 need upgrade
[00019542][01 01][00] v1.21.3647 -> v1.21.3647
[00019590]Packet upgrade failed at firmware upgrade.
P3S_FW_RESULT_AB.txt
Result: Success.
========== 2014.01.01 00:00:11 remo-con disconnect======
Packet: P3S_FW_V01.03.0020.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
Packet: P3S_FW_V01.04.0010.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
========== 2014.01.01 00:00:12 remo-con disconnect======
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Result: Abort.
Upgrading ...
Result: Failed.
升级几次的结果都是一样的,要如何才能升级成功啊?
石榴姐  管理员 2015-9-12 6#
1791778@qq.com 发表于 2015-9-12 00:48
奇怪的是,我把1.3.2的升级放进去,没有声音,只是黄灯在闪,接着我打开遥控器,结果又正常显示摄像头的视 ...
楼主你现在启动飞机连接app查看到的是什么版本的固件?app是否有提示固件更新?
楼主   2015-9-12 7#
app版本2.0.2
飞机的固件是1.3.20+
昨天晚上还提示要升级固件,今天刚刚开机却提示固件版本已是最新
现在开机黄灯在闪烁,间隔比升级时的闪烁间隔要久
楼主   2015-9-13 8#
怎么没人了。
楼主   2015-9-14 9#
已发邮件至客服。
收藏 点赞 评论
