========== 2015.11.09 11:46:32 =====================
Packet: WM610_FC550_FW_V01.00.00.30_1012.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: WM610_FC550_FW_V01.10.01.40.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2014.01.01 00:00:07 remo-con disconnect======
Result: Failed.
========== 2014.01.01 00:00:06 remo-con disconnect======
Result: Failed.
========== 2017.02.16 12:59:25 =====================
========== 2014.01.01 00:00:05 remo-con disconnect======
Packet: WM610_FC550_FW_V01.09.01.30.bin
Result: Failed.
Result: Failed.
