fans7c4c86f9
已累计飞行 0 米
log文件在哪里啊
发布于
2017-5-25
浏览
942
相关分类
3 条评论
最新
最早
夏清
4
已累计飞行 131755 米
2017-5-26
fans7c4c86f9
已累计飞行 0 米
[00013455]Delete history success. [00013768]========== remo-con disconnect. boot(15) ============ [00013867]Packet [C:\P3S_FW_V01.10.0090.bin] detected, card sn [0xda645d6e]. [00013974]Packet upgrade start... [00014074]Packet checking... [00014187]Packet vlink 01.10.0090 <-> 01.10.0090. [00014292]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 0). [00014393]Done. [00014498]Version checking[1]... [00014655][03 05][00] v34.2.0.9 -> v34.2.0.9 [00014815][03 06][00] v2.4.20.28 -> v2.4.20.28 [00014926][04 00][00] v1.48.0.0 -> v1.48.0.0 [00015099][11 00][00] v2.0.0.33 -> v1.8.0.0, firmware v2.0.0.33 not support. [00015206][11 00][00] v2.0.0.33 -> v1.8.0.0 [00015382][11 01][00] v2.0.0.33 -> v2.0.0.33 [00015548][12 00][00] v1.11.0.0 -> v1.11.0.0 [00015706][12 01][00] v1.11.0.0 -> v1.11.0.0 [00015866][12 02][00] v1.11.0.0 -> v1.11.0.0 [00016048][12 03][00] v1.11.0.0 -> v1.11.0.0 [00048658][15 00][00] device not detected. [00048823][17 00][00] v1.1.1.7 -> v1.1.1.7 [00049003][17 01][00] v1.0.2.7 -> v1.0.2.7 [00049114][19 00][00] v255.255.255.254 -> v1.0.8.96 [00049227][01 00][00] v1.25.5432 -> v1.25.5432 [00049336][01 01][00] v1.25.5432 -> v1.25.5432 [00049457][09 00][00] v3.0.0.10 -> v3.0.0.10 [00049560]Packet upgrade failed at version checking. [00013798]========== remo-con disconnect. boot(15) ============ [00013903]Packet [C:\P3S_FW_V01.10.0090.bin] detected, card sn [0xda645d6e]. [00014008]Packet upgrade start... [00014121]Packet checking... [00014229]Packet vlink 01.10.0090 <-> 01.10.0090. [00014332]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 0). [00014437]Done. [00014545]Version checking[1]... [00014690][03 05][00] v34.2.0.9 -> v34.2.0.9 [00014843][03 06][00] v2.4.20.28 -> v2.4.20.28 [00014962][04 00][00] v1.48.0.0 -> v1.48.0.0 [00015123][11 00][00] v2.0.0.33 -> v1.8.0.0, firmware v2.0.0.33 not support. [00015229][11 00][00] v2.0.0.33 -> v1.8.0.0 [00015420][11 01][00] v2.0.0.33 -> v2.0.0.33 [00015596][12 00][00] v1.11.0.0 -> v1.11.0.0 [00015920][12 01][00] v1.11.0.0 -> v1.11.0.0 [00016092][12 02][00] v1.11.0.0 -> v1.11.0.0 [00016254][12 03][00] v1.11.0.0 -> v1.11.0.0 [00016369][15 00][00] v1.1.2.0 -> v1.1.2.0 [00016506][17 00][00] v1.1.1.7 -> v1.1.1.7 [00016707][17 01][00] v1.0.2.7 -> v1.0.2.7 [00016822][19 00][00] v255.255.255.254 -> v1.0.8.96 [00016929][01 00][00] v1.25.5432 -> v1.25.5432 [00017034][01 01][00] v1.25.5432 -> v1.25.5432 [00017170][09 00][00] v3.0.0.10 -> v3.0.0.10 [00017276]Packet upgrade cancelled at version checking. [00015445]========== 2017.05.22 22:46:56. boot(15) ============ [00015559]Packet [C:\P3S_FW_V01.10.0090.bin] detected, card sn [0xda645d6e]. [00015666]Packet upgrade start... [00015780]Packet checking... [00015890]Packet vlink 01.10.0090 <-> 01.10.0090. [00016002]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 0). [00016101]Done. [00016213]Version checking[1]... [00016380][03 05][00] v34.2.0.9 -> v34.2.0.9 [00016540][03 06][00] v2.4.20.28 -> v2.4.20.28 [00016660][04 00][00] v1.48.0.0 -> v1.48.0.0 [00016840][11 00][00] v2.0.0.33 -> v1.8.0.0, firmware v2.0.0.33 not support. [00016942][11 00][00] v2.0.0.33 -> v1.8.0.0 [00017111][11 01][00] v2.0.0.33 -> v2.0.0.33 [00017281][12 00][00] v1.11.0.0 -> v1.11.0.0 [00017472][12 01][00] v1.11.0.0 -> v1.11.0.0 [00017638][12 02][00] v1.11.0.0 -> v1.11.0.0 [00017800][12 03][00] v1.11.0.0 -> v1.11.0.0 [00050405][15 00][00] device not detected. [00050558][17 00][00] v1.1.1.7 -> v1.1.1.7 [00050758][17 01][00] v1.0.2.7 -> v1.0.2.7 [00050888][19 00][00] v255.255.255.254 -> v1.0.8.96 [00051003][01 00][00] v1.25.5432 -> v1.25.5432 [00051106][01 01][00] v1.25.5432 -> v1.25.5432 [00051242][09 00][00] v3.0.0.10 -> v3.0.0.10 [00051353]Packet upgrade failed at version checking. [00013008]========== remo-con disconnect. boot(15) ============ [00013121]Packet [C:\P3S_FW_V01.09.0060.bin] detected, card sn [0xda645d6e]. [00013226]Packet upgrade start... [00013336]Packet checking... [00013608]Packet vlink 01.09.0060 <-> 01.08.0080. [00013716]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 6). [00013827]Packet upgrade failed at packet checking. [00015448]========== 2017.05.22 22:58:49. boot(15) ============ [00015555]Packet [C:\P3S_FW_V01.09.0060.bin] detected, card sn [0xda645d6e]. [00015663]Packet upgrade start... [00015796]Packet checking... [00015904]Packet vlink 01.09.0060 <-> 01.08.0080. [00016022]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 6). [00016133]Packet upgrade failed at packet checking. [00013307]========== remo-con disconnect. boot(15) ============ [00013420]Packet [C:\P3S_FW_V01.10.0090.bin] detected, card sn [0xda645d6e]. [00013522]Packet upgrade start... [00013629]Packet checking... [00013732]Packet vlink 01.10.0090 <-> 01.10.0090. [00013834]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 0). [00013941]Done. [00014038]Version checking[1]... [00014191][03 05][00] v34.2.0.9 -> v34.2.0.9 [00014347][03 06][00] v2.4.20.28 -> v2.4.20.28 [00014463][04 00][00] v1.48.0.0 -> v1.48.0.0 [00014625][11 00][00] v2.0.0.33 -> v1.8.0.0, firmware v2.0.0.33 not support. [00014729][11 00][00] v2.0.0.33 -> v1.8.0.0 [00014926][11 01][00] v2.0.0.33 -> v2.0.0.33 [00015099][12 00][00] v1.11.0.0 -> v1.11.0.0 [00015261][12 01][00] v1.11.0.0 -> v1.11.0.0 [00015420][12 02][00] v1.11.0.0 -> v1.11.0.0 [00015582][12 03][00] v1.11.0.0 -> v1.11.0.0 [00048185][15 00][00] device not detected. [00048356][17 00][00] v1.1.1.7 -> v1.1.1.7 [00048556][17 01][00] v1.0.2.7 -> v1.0.2.7 [00048687][19 00][00] v255.255.255.254 -> v1.0.8.96 [00048793][01 00][00] v1.25.5432 -> v1.25.5432 [00048895][01 01][00] v1.25.5432 -> v1.25.5432 [00049006][09 00][00] v3.0.0.10 -> v3.0.0.10 [00049112]Packet upgrade failed at version checking. [00015936]========== remo-con disconnect. boot(15) ============ [00016037]Packet [C:\P3S_FW_V01.10.0090.bin] detected, card sn [0xda645d6e]. [00016142]Packet upgrade start... [00016263]Packet checking... [00016471]Packet vlink 01.10.0090 <-> 01.10.0090. [00016588]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 0). [00016691]Done. [00016795]Version checking[1]... [00016926][03 05][00] v34.2.0.9 -> v34.2.0.9 [00017067][03 06][00] v2.4.20.28 -> v2.4.20.28 [00017184][04 00][00] v1.48.0.0 -> v1.48.0.0 [00017350][11 00][00] v2.0.0.33 -> v1.8.0.0, firmware v2.0.0.33 not support. [00017455][11 00][00] v2.0.0.33 -> v1.8.0.0 [00017629][11 01][00] v2.0.0.33 -> v2.0.0.33 [00017793][12 00][00] v1.11.0.0 -> v1.11.0.0 [00017946][12 01][00] v1.11.0.0 -> v1.11.0.0 [00018111][12 02][00] v1.11.0.0 -> v1.11.0.0 [00018266][12 03][00] v1.11.0.0 -> v1.11.0.0 [00050867][15 00][00] device not detected. [00051021][17 00][00] v1.1.1.7 -> v1.1.1.7 [00051216][17 01][00] v1.0.2.7 -> v1.0.2.7 [00051354][19 00][00] v255.255.255.254 -> v1.0.8.96 [00051464][01 00][00] v1.25.5432 -> v1.25.5432 [00051563][01 01][00] v1.25.5432 -> v1.25.5432 [00051693][09 00][00] v3.0.0.10 -> v3.0.0.10 [00051797]Packet upgrade failed at version checking. [00016033]========== 2017.05.22 23:13:00. boot(15) ============ [00016152]Packet [C:\P3S_FW_V01.10.0090.bin] detected, card sn [0xda645d6e]. [00016274]Packet upgrade start... [00016382]Packet checking... [00016493]Packet vlink 01.10.0090 <-> 01.10.0090. [00016599]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 0). [00016704]Done. [00016810]Version checking[1]... [00016984][03 05][00] v34.2.0.9 -> v34.2.0.9 [00017138][03 06][00] v2.4.20.28 -> v2.4.20.28 [00017277][04 00][00] v1.48.0.0 -> v1.48.0.0 [00017436][11 00][00] v2.0.0.33 -> v1.8.0.0, firmware v2.0.0.33 not support. [00017535][11 00][00] v2.0.0.33 -> v1.8.0.0 [00017737][11 01][00] v2.0.0.33 -> v2.0.0.33 [00017909][12 00][00] v1.11.0.0 -> v1.11.0.0 [00018090][12 01][00] v1.11.0.0 -> v1.11.0.0 [00018256][12 02][00] v1.11.0.0 -> v1.11.0.0 [00018410][12 03][00] v1.11.0.0 -> v1.11.0.0 [00051028][15 00][00] device not detected. [00051189][17 00][00] v1.1.1.7 -> v1.1.1.7 [00051588][17 01][00] v1.0.2.7 -> v1.0.2.7 [00051740][19 00][00] v255.255.255.254 -> v1.0.8.96 [00051859][01 00][00] v1.25.5432 -> v1.25.5432 [00051966][01 01][00] v1.25.5432 -> v1.25.5432 [00052105][09 00][00] v3.0.0.10 -> v3.0.0.10 [00052215]Packet upgrade failed at version checking. [00011724]========== remo-con disconnect. boot(15) ============ [00011826]Packet [C:\P3S_FW_V01.10.0090.bin] detected, card sn [0xda645d6e]. [00011932]Packet upgrade start... [00012044]Packet checking... [00012150]Packet vlink 01.10.0090 <-> 01.10.0090. [00012247]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 0). [00012351]Done. [00012453]Version checking[1]... [00012583][03 05][00] v34.2.0.9 -> v34.2.0.9 [00012723][03 06][00] v2.4.20.28 -> v2.4.20.28 [00012831][04 00][00] v1.48.0.0 -> v1.48.0.0 [00013003][11 00][00] v2.0.0.33 -> v1.8.0.0, firmware v2.0.0.33 not support. [00013100][11 00][00] v2.0.0.33 -> v1.8.0.0 [00013284][11 01][00] v2.0.0.33 -> v2.0.0.33 [00013436][12 00][00] v1.11.0.0 -> v1.11.0.0 [00013597][12 01][00] v1.11.0.0 -> v1.11.0.0 [00013757][12 02][00] v1.11.0.0 -> v1.11.0.0 [00013892][12 03][00] v1.11.0.0 -> v1.11.0.0 [00046496][15 00][00] device not detected. [00046654][17 00][00] v1.1.1.7 -> v1.1.1.7 [00046830][17 01][00] v1.0.2.7 -> v1.0.2.7 [00046950][19 00][00] v255.255.255.254 -> v1.0.8.96 [00047054][01 00][00] v1.25.5432 -> v1.25.5432 [00047161][01 01][00] v1.25.5432 -> v1.25.5432 [00047269][09 00][00] v3.0.0.10 -> v3.0.0.10 [00047376]Packet upgrade failed at version checking. [00014339]========== remo-con disconnect. boot(15) ============ [00014447]Packet [C:\P3S_FW_V01.09.0060.bin] detected, card sn [0xda645d6e]. [00014552]Packet upgrade start... [00014657]Packet checking... [00014764]Packet vlink 01.09.0060 <-> 01.08.0080. [00014863]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 6). [00014967]Packet upgrade failed at packet checking. [00015518]========== 2017.05.22 23:25:12. boot(15) ============ [00015740]Packet [C:\P3S_FW_V01.09.0060.bin] detected, card sn [0xda645d6e]. [00015856]Packet upgrade start... [00015984]Packet checking... [00016088]Packet vlink 01.09.0060 <-> 01.08.0080. [00016197]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 6). [00016301]Packet upgrade failed at packet checking. [00014660]========== 2017.05.23 08:49:52. boot(15) ============ [00014780]Packet [C:\P3S_FW_V01.10.0090.bin] detected, card sn [0xda645d6e]. [00014892]Packet upgrade start... [00014997]Packet checking... [00015107]Packet vlink 01.10.0090 <-> 01.10.0090. [00015222]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 0). [00015324]Done. [00015435]Version checking[1]... [00015597][03 05][00] v34.2.0.9 -> v34.2.0.9 [00015759][03 06][00] v2.4.20.28 -> v2.4.20.28 [00015872][04 00][00] v1.48.0.0 -> v1.48.0.0 [00016080][11 00][00] v2.0.0.33 -> v1.8.0.0, firmware v2.0.0.33 not support. [00016191][11 00][00] v2.0.0.33 -> v1.8.0.0 [00016379][11 01][00] v2.0.0.33 -> v2.0.0.33 [00016539][12 00][00] v1.11.0.0 -> v1.11.0.0 [00016709][12 01][00] v1.11.0.0 -> v1.11.0.0 [00016887][12 02][00] v1.11.0.0 -> v1.11.0.0 [00017056][12 03][00] v1.11.0.0 -> v1.11.0.0 [00047670][15 00][00] device not detected. [00047847][17 00][00] v1.1.1.7 -> v1.1.1.7 [00048064][17 01][00] v1.0.2.7 -> v1.0.2.7 [00048194][19 00][00] v255.255.255.254 -> v1.0.8.96 [00048304][01 00][00] v1.25.5432 -> v1.25.5432 [00048421][01 01][00] v1.25.5432 -> v1.25.5432 [00048553][09 00][00] v3.0.0.10 -> v3.0.0.10 [00048659]Packet upgrade failed at version checking. [00015484]========== 2017.05.23 08:51:07. boot(15) ============ [00015597]Packet [C:\P3S_FW_V01.10.0090.bin] detected, card sn [0xda645d6e]. [00015707]Packet upgrade start... [00015835]Packet checking... [00015950]Packet vlink 01.10.0090 <-> 01.10.0090. [00016053]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 0). [00016164]Done. [00016266]Version checking[1]... [00016434][03 05][00] v34.2.0.9 -> v34.2.0.9 [00016593][03 06][00] v2.4.20.28 -> v2.4.20.28 [00016893][04 00][00] v1.48.0.0 -> v1.48.0.0 [00017073][11 00][00] v2.0.0.33 -> v1.8.0.0, firmware v2.0.0.33 not support. [00017182][11 00][00] v2.0.0.33 -> v1.8.0.0 [00017376][11 01][00] v2.0.0.33 -> v2.0.0.33 [00017542][12 00][00] v1.11.0.0 -> v1.11.0.0 [00017705][12 01][00] v1.11.0.0 -> v1.11.0.0 [00017889][12 02][00] v1.11.0.0 -> v1.11.0.0 [00018056][12 03][00] v1.11.0.0 -> v1.11.0.0 [00050671][15 00][00] device not detected. [00050840][17 00][00] v1.1.1.7 -> v1.1.1.7 [00051050][17 01][00] v1.0.2.7 -> v1.0.2.7 [00051189][19 00][00] v255.255.255.254 -> v1.0.8.96 [00051292][01 00][00] v1.25.5432 -> v1.25.5432 [00051397][01 01][00] v1.25.5432 -> v1.25.5432 [00051527][09 00][00] v3.0.0.10 -> v3.0.0.10 [00051628]Packet upgrade failed at version checking. [00013287]========== remo-con disconnect. boot(15) ============ [00013391]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xda645d6e]. [00013489]Packet upgrade start... [00013598]Packet checking... [00013710]Packet vlink 01.03.0020 <-> 01.01.0009. [00013811]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 6). [00013924]Packet upgrade failed at packet checking. [00013729]========== remo-con disconnect. boot(15) ============ [00013825]Packet [C:\P3S_FW_V01.10.0090.bin] detected, card sn [0x26d3574e]. [00013935]Packet upgrade start... [00014038]Packet checking... [00014155]Packet vlink 01.10.0090 <-> 01.10.0090. [00014263]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 0). [00014361]Done. [00014466]Version checking[1]... [00014616][03 05][00] v34.2.0.9 -> v34.2.0.9 [00014758][03 06][00] v2.4.20.28 -> v2.4.20.28 [00014863][04 00][00] v1.48.0.0 -> v1.48.0.0 [00015038][11 00][00] v2.0.0.33 -> v1.8.0.0, firmware v2.0.0.33 not support. [00015145][11 00][00] v2.0.0.33 -> v1.8.0.0 [00015316][11 01][00] v2.0.0.33 -> v2.0.0.33 [00015489][12 00][00] v1.11.0.0 -> v1.11.0.0 [00015650][12 01][00] v1.11.0.0 -> v1.11.0.0 [00015810][12 02][00] v1.11.0.0 -> v1.11.0.0 [00016122][12 03][00] v1.11.0.0 -> v1.11.0.0 [00016228][15 00][00] v1.1.2.0 -> v1.1.2.0 [00016388][17 00][00] v1.1.1.7 -> v1.1.1.7 [00016570][17 01][00] v1.0.2.7 -> v1.0.2.7 [00016695][19 00][00] v255.255.255.254 -> v1.0.8.96 [00016797][01 00][00] v1.25.5432 -> v1.25.5432 [00016899][01 01][00] v1.25.5432 -> v1.25.5432 [00017017][09 00][00] v3.0.0.10 -> v3.0.0.10 [00017122]Packet upgrade cancelled at version checking. [00012724]========== remo-con disconnect. boot(15) ============ [00012829]Packet [C:\P3S_FW_V01.10.0090.bin] detected, card sn [0x26d3574e]. [00012928]Packet upgrade start... [00013032]Packet checking... [00013133]Packet vlink 01.10.0090 <-> 01.10.0090. [00013240]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 0). [00013352]Done. [00013457]Version checking[1]... [00013601][03 05][00] v34.2.0.9 -> v34.2.0.9 [00013763][03 06][00] v2.4.20.28 -> v2.4.20.28 [00013880][04 00][00] v1.48.0.0 -> v1.48.0.0 [00014047][11 00][00] v2.0.0.33 -> v1.8.0.0, firmware v2.0.0.33 not support. [00014153][11 00][00] v2.0.0.33 -> v1.8.0.0 [00014342][11 01][00] v2.0.0.33 -> v2.0.0.33 [00014516][12 00][00] v1.11.0.0 -> v1.11.0.0 [00014676][12 01][00] v1.11.0.0 -> v1.11.0.0 [00014836][12 02][00] v1.11.0.0 -> v1.11.0.0 [00014996][12 03][00] v1.11.0.0 -> v1.11.0.0 [00015097][15 00][00] v1.1.2.0 -> v1.1.2.0 [00015247][17 00][00] v1.1.1.7 -> v1.1.1.7 [00015430][17 01][00] v1.0.2.7 -> v1.0.2.7 [00015560][19 00][00] v255.255.255.254 -> v1.0.8.96 [00015666][01 00][00] v1.25.5432 -> v1.25.5432 [00015766][01 01][00] v1.25.5432 -> v1.25.5432 [00015902][09 00][00] v3.0.0.10 -> v3.0.0.10 [00016004]Packet upgrade cancelled at version checking. [00012885]========== remo-con disconnect. boot(15) ============ [00012986]Packet [C:\P3S_FW_V01.10.0090.bin] detected, card sn [0x26d3574e]. [00013087]Packet upgrade start... [00013195]Packet checking... [00013304]Packet vlink 01.10.0090 <-> 01.10.0090. [00013407]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 0). [00013611]Done. [00013718]Version checking[1]... [00013881][03 05][00] v34.2.0.9 -> v34.2.0.9 [00014042][03 06][00] v2.4.20.28 -> v2.4.20.28 [00014152][04 00][00] v1.48.0.0 -> v1.48.0.0 [00014342][11 00][00] v2.0.0.33 -> v1.8.0.0, firmware v2.0.0.33 not support. [00014442][11 00][00] v2.0.0.33 -> v1.8.0.0 [00014602][11 01][00] v2.0.0.33 -> v2.0.0.33 [00014772][12 00][00] v1.11.0.0 -> v1.11.0.0 [00014931][12 01][00] v1.11.0.0 -> v1.11.0.0 [00015091][12 02][00] v1.11.0.0 -> v1.11.0.0 [00015254][12 03][00] v1.11.0.0 -> v1.11.0.0 [00015359][15 00][00] v1.1.2.0 -> v1.1.2.0 [00015507][17 00][00] v1.1.1.7 -> v1.1.1.7 [00015688][17 01][00] v1.0.2.7 -> v1.0.2.7 [00015816][19 00][00] v255.255.255.254 -> v1.0.8.96 [00015917][01 00][00] v1.25.5432 -> v1.25.5432 [00016026][01 01][00] v1.25.5432 -> v1.25.5432 [00016157][09 00][00] v3.0.0.10 -> v3.0.0.10 [00016261]Packet upgrade cancelled at version checking. [00012975]========== 2017.05.25 22:33:19. boot(15) ============ [00013078]Packet [C:\P3S_FW_V01.10.0090.bin] detected, card sn [0x26d3574e]. [00013178]Packet upgrade start... [00013290]Packet checking... [00013402]Packet vlink 01.10.0090 <-> 01.10.0090. [00013506]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 0). [00013618]Done. [00013726]Version checking[1]... [00013865][03 05][00] v34.2.0.9 -> v34.2.0.9 [00014022][03 06][00] v2.4.20.28 -> v2.4.20.28 [00014152][04 00][00] v1.48.0.0 -> v1.48.0.0 [00014305][11 00][00] v2.0.0.33 -> v1.8.0.0, firmware v2.0.0.33 not support. [00014421][11 00][00] v2.0.0.33 -> v1.8.0.0 [00014585][11 01][00] v2.0.0.33 -> v2.0.0.33 [00014733][12 00][00] v1.11.0.0 -> v1.11.0.0 [00014891][12 01][00] v1.11.0.0 -> v1.11.0.0 [00015058][12 02][00] v1.11.0.0 -> v1.11.0.0 [00015235][12 03][00] v1.11.0.0 -> v1.11.0.0 [00047837][15 00][00] device not detected. [00048000][17 00][00] v1.1.1.7 -> v1.1.1.7 [00048191][17 01][00] v1.0.2.7 -> v1.0.2.7 [00048326][19 00][00] v255.255.255.254 -> v1.0.8.96 [00048604][01 00][00] v1.25.5432 -> v1.25.5432 [00048713][01 01][00] v1.25.5432 -> v1.25.5432 [00048867][09 00][00] v3.0.0.10 -> v3.0.0.10 [00048977]Packet upgrade failed at version checking.
2017-5-26
pidong_
已累计飞行 79919 米
楼主说的是飞行器的升级Log文件吗?在飞行器相机的存储卡根目录。
2017-5-26
暂无更多评论
关于作者
已累计飞行 0 米
fans7c4c86f9
暂无关联认证的设备
最新帖子
log文件在哪里啊
请帮我看下是否升级成功
请帮忙查下3a保修日期
