大疆社区
大疆社区
太极陈
已累计飞行 0 米
7 条评论
最新
最早
大疆社区
大疆社区
已累计飞行 0 米
再次升级试试,卡内出现这一组数据。 ========== 2014.01.01 00:00:12 remo-con disconnect====== Packet: P3X_FW_V01.09.0060.bin Upgrading ... Result: Success. ========== 2014.01.01 00:00:12 remo-con disconnect====== Packet: P3X_FW_V01.09.0060.bin Upgrading ... Result: Success. ========== 2016.11.13 08:04:38 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.11.13 08:09:22 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.11.13 08:12:16 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.11.14 07:52:48 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.11.14 07:54:30 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.11.14 07:59:55 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.11.14 08:05:06 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.11.14 08:40:58 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.11.23 12:39:30 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.11.23 16:59:18 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.11.23 17:11:19 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.11.27 13:04:52 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.11.27 13:06:34 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.11.27 14:29:48 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.11.27 14:45:50 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.11.27 15:20:39 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.11.27 15:42:06 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.11.27 16:13:22 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.11.27 16:24:08 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.12.06 17:00:40 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.12.08 09:15:48 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.12.09 11:29:22 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.12.09 14:22:29 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.12.09 14:37:48 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.12.09 14:39:16 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.12.09 14:51:05 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.12.09 15:17:24 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.12.09 15:19:22 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.12.09 15:26:01 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.12.09 16:22:50 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2016.12.09 16:24:23 ===================== Packet: P3X_FW_V01.09.0060.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2014.01.01 00:00:11 remo-con disconnect====== Packet: P3X_FW_V01.10.0090.bin Upgrading ... ========== 2017.04.15 09:35:50 ===================== Packet: P3X_FW_V01.10.0090.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2017.05.11 07:11:18 ===================== Packet: P3X_FW_V01.10.0090.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2017.05.11 07:13:52 ===================== Packet: P3X_FW_V01.10.0090.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2017.05.11 07:14:53 ===================== Packet: P3X_FW_V01.10.0090.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2017.05.11 07:16:45 ===================== Packet: P3X_FW_V01.10.0090.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2017.05.11 07:19:34 ===================== Packet: P3X_FW_V01.10.0090.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2014.01.01 00:00:11 remo-con disconnect====== Packet: P3X_FW_V01.10.0090.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2014.01.01 00:00:12 remo-con disconnect====== Packet: P3X_FW_V01.10.0090.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft.
2017-6-26
大疆社区
已累计飞行 0 米
正常了吗
2017-6-21
大疆社区
已累计飞行 89040 米
路过 学习
2017-6-15
大疆社区
已累计飞行 3844 米
系统要校准
2017-6-14
大疆社区
已累计飞行 0 米
谢谢,我试试看
2017-6-14
大疆社区
已累计飞行 0 米
imu需要校准一下了。找一个水平的地方校准
2017-6-14
大疆社区
已累计飞行 0 米
等了几十分钟,可以起飞,用完一块电池,换了新电池,还是显示IMU正在初始化?
2017-6-14
暂无更多评论
关于作者
已累计飞行 0 米
大疆社区
太极陈
暂无关联认证的设备
