昨天联系客服 重新升级 后生成的!
Delete history success.
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2014.01.01 00:00:42 remo-con disconnect======
Packet: P3S_FW_V01.11.0020.bin
Result: Failed.
========== 2014.01.01 00:00:12 remo-con disconnect======
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2014.01.01 00:00:13 remo-con disconnect======
Result: Abort.
Result: Abort.
========== 2017.07.09 19:39:37 =====================
Result: Failed.
========== 2017.07.09 20:02:04 =====================
Result: Failed.
Result: Abort.
Result: Failed.
Result: Abort.
========== 2014.01.01 00:01:27 remo-con disconnect======
Result: Failed.
========== 2014.01.01 00:04:28 remo-con disconnect======
Result: Failed.
Result: Failed.
========== 2017.07.14 14:31:25 =====================
Result: Failed.
========== 2017.07.14 14:41:18 =====================
Result: Failed.
========== 2017.07.14 14:55:40 =====================
Result: Failed.
========== 2017.07.14 15:01:52 =====================
Result: Failed.
========== 2017.07.26 17:49:46 =====================
Result: Abort.
========== 2017.07.26 17:58:27 =====================
Result: Abort.
========== 2017.08.09 11:36:17 =====================
Result: Abort.
========== 2017.10.26 16:19:20 =====================
Result: Failed.
========== 2017.10.26 16:22:50 =====================
Result: Failed.
========== 2017.10.26 16:26:27 =====================
Result: Failed.
========== 2017.10.26 16:40:06 =====================
Result: Failed.
========== 2017.10.26 16:44:38 =====================
Result: Failed.
========== 2017.10.26 17:19:41 =====================
Result: Failed.
========== 2017.10.26 17:23:32 =====================
Result: Failed.
========== 2014.01.01 00:00:09 remo-con disconnect======
Result: Failed.
