1.2升到1.3失败 再升到1.4的TXT文件
Result: Success.
========== 2015.09.08 10:52:02 =====================
Packet: P3S_FW_V01.04.0010.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2015.09.08 10:56:26 =====================
Result: Abort.
========== 2014.01.01 00:00:11 remo-con disconnect======
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2015.09.08 13:32:14 =====================
Result: Abort.
========== 2015.09.08 13:34:45 =====================
Result: Failed.
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3S_FW_V01.03.0020.bin
Upgrading ...
Result: Failed.
Packet: P3S_FW_V01.02.0008.bin
Result: Abort.
The current firmware does not support downgrade. Use a different version of firmware to downgrade the target version.
Result: Abort.
Upgrading ...
Result: Success.
Result: Failed.
========== 2015.09.16 17:20:10 =====================
Result: Failed.
Upgrading ...
Result: Failed.
========== 2014.01.01 00:00:13 remo-con disconnect======
Result: Abort.
Result: Abort.
========== 2015.09.17 11:03:17 =====================
Result: Abort.
========== 2015.09.17 11:09:35 =====================
Result: Abort.
========== 2015.09.17 11:12:51 =====================
Result: Failed.
