chuhao0
已累计飞行 0 米
发布于
2015-11-30
浏览
1.5k
相关分类
15 条评论
最新
最早
秋香
16
已累计飞行 0 米
建议您把云台的两根连接线重新插拔一下,一根是6Pin一根是8Pin,然后再尝试下
2015-12-1
chuhao0
15
已累计飞行 0 米
我的现在都升级许多次了 而且现在只要打开无人机就会升级 一直失败
2015-12-1
秋香
14
已累计飞行 0 米
这个要继续重新升级试试哦~ 可以尝试换张SD卡试试,先在app里格式化
2015-12-1
chuhao0
13
已累计飞行 0 米
麻烦看下 谢谢啊
2015-12-1
chuhao0
12
已累计飞行 0 米
[00012235][01 00] Firmware upgrade finished successfully. [00012339]Done. [00012375]Packet [C:\P3X_FW_V01.02.0006.bin] resumed, card sn [0xa0ce64b4]. [00012410]Version checking[2]... [00012485][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade. [00012540][03 06][00] v2.1.6.18 -> v2.2.6.8 need upgrade. [00012583][04 00][00] v1.36.0.0 -> v1.38.0.0 need upgrade. [00012634][09 00][00] v1.7.0.3 -> v1.7.0.3 [00012740][11 00][00] v1.6.0.0 -> v1.6.0.0 [00012829][12 00][00] v1.8.0.0 -> v1.8.0.0 [00012895][12 01][00] v1.8.0.0 -> v1.8.0.0 [00012995][12 02][00] v1.8.0.0 -> v1.8.0.0 [00013074][12 03][00] v1.8.0.0 -> v1.8.0.0 [00013206][15 00][00] v1.1.2.0 -> v1.1.2.0 [00013310][17 00][00] v1.1.1.2 -> v1.1.1.6 need upgrade. [00013417][17 01][00] v1.0.2.4 -> v1.0.2.5 need upgrade. [00013475][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade. [00013507][01 00][05] v1.15.3056 -> v1.15.3056 [00013538][01 01][00] v1.6.2736 -> v1.15.3056 need upgrade [00013584][08 00][00] v0.11.0.4 -> v0.11.0.4 [00013612]Done. [00013641]Firmware upgrading[2]... [00013790][01 01] Firmware upgrade start... [00044056][01 01] Firmware upgrade finished successfully. [00044119][17 00] Firmware upgrade start... [00137772][17 00] Firmware upgrade finished successfully. [00137823][17 01] Firmware upgrade start... [00204235][17 01] Firmware upgrade finished successfully. [00204289][03 05] Firmware upgrade start... [00275791][03 05] Firmware upgrade finished successfully. [00276010][03 06] Firmware upgrade start... [00586936][03 06] Firmware upgrade finished successfully. [00589899][19 00] Firmware upgrade start... [00755677][19 00] Firmware upgrade finished successfully. [00755741][04 00] Firmware upgrade start... [00813599][04 00] Firmware upgrade finished successfully. [00813631]Done. [00813665]Version checking[3]... [00813741][03 05][05] v34.2.0.9 -> v34.2.0.9 [00813817][03 06][05] v2.2.6.8 -> v2.2.6.8 [00813863][04 00][05] v1.38.0.0 -> v1.38.0.0 [00813920][09 00][00] v1.7.0.3 -> v1.7.0.3 [00814140][11 00][00] v1.6.0.0 -> v1.6.0.0 [00814230][12 00][00] v1.8.0.0 -> v1.8.0.0 [00814330][12 01][00] v1.8.0.0 -> v1.8.0.0 [00814411][12 02][00] v1.8.0.0 -> v1.8.0.0 [00814486][12 03][00] v1.8.0.0 -> v1.8.0.0 [00814602][15 00][00] v1.1.2.0 -> v1.1.2.0 [00814686][17 00][05] v1.1.1.6 -> v1.1.1.6 [00814806][17 01][05] v1.0.2.5 -> v1.0.2.5 [00814861][19 00][05] v1.0.8.96 -> v1.0.8.96 [00814893][01 00][05] v1.15.3056 -> v1.15.3056 [00814925][01 01][05] v1.15.3056 -> v1.15.3056 [00814971][08 00][00] v0.11.0.4 -> v0.11.0.4 [00815003]Packet upgrade finish successfully. [00077041]========== 2015.08.25 17:11:50. boot(15) ============ [00077076]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00077107]Packet upgrade start... [00077146]Packet checking... [00077185]Done. [00077218]Version checking[1]... [00077296][03 05][00] v34.2.0.9 -> v34.2.0.9 [00077399][03 06][00] v2.2.6.8 -> v2.3.0.10 need upgrade. [00077439][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade. [00077490][09 00][00] v1.7.0.3 -> v1.7.0.3 [00077618][11 00][00] v1.6.1.0 -> v1.7.0.0 need upgrade. [00077706][12 00][00] v1.8.0.0 -> v1.8.0.0 [00077808][12 01][00] v1.8.0.0 -> v1.8.0.0 [00077894][12 02][00] v1.8.0.0 -> v1.8.0.0 [00077986][12 03][00] v1.8.0.0 -> v1.8.0.0 [00078120][15 00][00] v1.1.2.0 -> v1.1.2.0 [00078206][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade. [00078325][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade. [00078373][19 00][00] v1.0.8.96 -> v1.0.8.96 [00078406][01 00][00] v1.15.3056 -> v1.23.3419 need upgrade [00078447][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade [00078495][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade. [00078528]Done. [00080563]Waiting for user ... [00090596]Timeout, start upgrade automatically. [00090664]Firmware upgrading[1]... [00103286][01 00] Firmware upgrade start... [00012219][01 00] Firmware upgrade finished successfully. [00012257]Done. [00012290]Packet [C:\P3X_FW_V01.04.0005.bin] resumed, card sn [0x00ce092e]. [00012418]Packet vlink 01.04.0005 01.03.0020. [00012484]Version checking[2]... [00012556][03 05][00] v34.2.0.9 -> v34.2.0.9 [00012617][03 06][00] v2.2.6.8 -> v2.3.0.10 need upgrade. [00012661][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade. [00012707][09 00][00] v1.7.0.3 -> v1.7.0.3 [00012817][11 00][00] v1.6.1.0 -> v1.7.0.0 need upgrade. [00012887][12 00][00] v1.8.0.0 -> v1.8.0.0 [00012977][12 01][00] v1.8.0.0 -> v1.8.0.0 [00013052][12 02][00] v1.8.0.0 -> v1.8.0.0 [00013135][12 03][00] v1.8.0.0 -> v1.8.0.0 [00013253][15 00][00] v1.1.2.0 -> v1.1.2.0 [00013330][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade. [00013442][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade. [00013506][19 00][00] v1.0.8.96 -> v1.0.8.96 [00013543][01 00][05] v1.23.3419 -> v1.23.3419 [00013578][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade [00013644][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade. [00013677]Done. [00013713]Firmware upgrading[2]... [00013857][01 01] Firmware upgrade start... [00044119][01 01] Firmware upgrade finished successfully. [00044982][08 00] Firmware upgrade start... [00565712][08 00] Firmware upgrade finished successfully. [00565777][17 00] Firmware upgrade start... [00747745][17 00] Firmware upgrade finished successfully. [00747794][17 01] Firmware upgrade start... [00826254][17 01] Firmware upgrade finished successfully. [00826298][11 00] Firmware upgrade start... [00873358][11 00] Firmware upgrade finish failed (step = 4, err = 0xaa, idx = 15, los = 30, ng = 0). [00903585][03 06] Firmware upgrade start... [01246313][03 06] Firmware upgrade finished successfully. [01246376][04 00] Firmware upgrade start... [01303237][04 00] Firmware upgrade finished successfully. [01303274]Done. [01303306]Version checking[3]... [01303375][03 05][00] v34.2.0.9 -> v34.2.0.9 [01303433][03 06][05] v2.3.0.10 -> v2.3.0.10 [01303472][04 00][05] v1.40.0.0 -> v1.40.0.0 [01303521][09 00][00] v1.7.0.3 -> v1.7.0.3 [01303634][11 00][00] v0.0.0.0 -> v1.7.0.0 need upgrade. [01303787][12 00][00] v1.8.0.0 -> v1.8.0.0 [01303862][12 01][00] v1.8.0.0 -> v1.8.0.0 [01303952][12 02][00] v1.8.0.0 -> v1.8.0.0 [01304027][12 03][00] v1.8.0.0 -> v1.8.0.0 [01304151][15 00][00] v1.1.2.0 -> v1.1.2.0 [01304221][17 00][05] v1.1.1.7 -> v1.1.1.7 [01304341][17 01][05] v1.0.2.7 -> v1.0.2.7 [01304402][19 00][00] v1.0.8.96 -> v1.0.8.96 [01304439][01 00][05] v1.23.3419 -> v1.23.3419 [01304475][01 01][05] v1.23.3419 -> v1.23.3419 [01304534][08 00][05] v0.12.0.4 -> v0.12.0.4 [01304570]Done. [01304603]Firmware upgrading[3]... [01304646][11 00] Firmware upgrade start... [01354370][11 00] Firmware upgrade finished successfully. [01354405]Done. [01354443]Version checking[4]... [01354520][03 05][00] v34.2.0.9 -> v34.2.0.9 [01354600][03 06][05] v2.3.0.10 -> v2.3.0.10 [01354646][04 00][05] v1.40.0.0 -> v1.40.0.0 [01354704][09 00][00] v1.7.0.3 -> v1.7.0.3 [01354819][11 00][05] v1.7.0.0 -> v1.7.0.0 [01354895][12 00][00] v1.8.0.0 -> v1.8.0.0 [01354970][12 01][00] v1.8.0.0 -> v1.8.0.0 [01355055][12 02][00] v1.8.0.0 -> v1.8.0.0 [01355140][12 03][00] v1.8.0.0 -> v1.8.0.0 [01355279][15 00][00] v1.1.2.0 -> v1.1.2.0 [01355365][17 00][05] v1.1.1.7 -> v1.1.1.7 [01355485][17 01][05] v1.0.2.7 -> v1.0.2.7 [01355544][19 00][00] v1.0.8.96 -> v1.0.8.96 [01355581][01 00][05] v1.23.3419 -> v1.23.3419 [01355618][01 01][05] v1.23.3419 -> v1.23.3419 [01355666][08 00][05] v0.12.0.4 -> v0.12.0.4 [01355706]Packet upgrade finish successfully. [00012486]========== 2015.08.25 17:42:45. boot(15) ============ [00012524]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00012558]Packet upgrade start... [00012600]Packet checking... [00012639]Packet vlink 01.04.0005 01.03.0020. [00012675]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00012708]Done. [00012745]Version checking[1]... [00012841][03 05][00] v34.2.0.9 -> v34.2.0.9 [00012901][03 06][00] v2.3.0.10 -> v2.3.0.10 [00013035][04 00][00] v1.40.0.0 -> v1.40.0.0 [00013090][09 00][00] v1.7.0.3 -> v1.7.0.3 [00013201][11 00][00] v1.7.0.0 -> v1.7.0.0 [00013279][12 00][00] v1.8.0.0 -> v1.8.0.0 [00013351][12 01][00] v1.8.0.0 -> v1.8.0.0 [00013441][12 02][00] v1.8.0.0 -> v1.8.0.0 [00013515][12 03][00] v1.8.0.0 -> v1.8.0.0 [00013672][15 00][00] v1.1.2.0 -> v1.1.2.0 [00013750][17 00][00] v1.1.1.7 -> v1.1.1.7 [00013865][17 01][00] v1.0.2.7 -> v1.0.2.7 [00013931][19 00][00] v1.0.8.96 -> v1.0.8.96 [00013969][01 00][00] v1.23.3419 -> v1.23.3419 [00014008][01 01][00] v1.23.3419 -> v1.23.3419 [00014066][08 00][00] v0.12.0.4 -> v0.12.0.4 [00014108]Packet upgrade cancelled at version checking. [00012481]========== 2015.08.25 17:49:41. boot(2) ============ [00012525]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00012562]Packet upgrade start... [00012604]Packet checking... [00012642]Packet vlink 01.04.0005 01.03.0020. [00012685]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00012722]Done. [00012760]Version checking[1]... [00012835][03 05][00] v34.2.0.9 -> v34.2.0.9 [00012910][03 06][00] v2.3.0.10 -> v2.3.0.10 [00012952][04 00][00] v1.40.0.0 -> v1.40.0.0 [00013019][09 00][00] v1.7.0.3 -> v1.7.0.3 [00013131][11 00][00] v1.7.0.0 -> v1.7.0.0 [00013224][12 00][00] v1.8.0.0 -> v1.8.0.0 [00013303][12 01][00] v1.8.0.0 -> v1.8.0.0 [00013380][12 02][00] v1.8.0.0 -> v1.8.0.0 [00013469][12 03][00] v1.8.0.0 -> v1.8.0.0 [00013606][15 00][00] v1.1.2.0 -> v1.1.2.0 [00013679][17 00][00] v1.1.1.7 -> v1.1.1.7 [00013801][17 01][00] v1.0.2.7 -> v1.0.2.7 [00013859][19 00][00] v1.0.8.96 -> v1.0.8.96 [00013895][01 00][00] v1.23.3419 -> v1.23.3419 [00013931][01 01][00] v1.23.3419 -> v1.23.3419 [00013982][08 00][00] v0.12.0.4 -> v0.12.0.4 [00014018]Packet upgrade cancelled at version checking. [00012503]========== 2015.08.25 20:41:41. boot(15) ============ [00012538]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00012575]Packet upgrade start... [00012690]Packet checking... [00012728]Packet vlink 01.04.0005 01.03.0020. [00012764]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00012807]Done. [00012844]Version checking[1]... [00012914][03 05][00] v34.2.0.9 -> v34.2.0.9 [00012994][03 06][00] v2.3.0.10 -> v2.3.0.10 [00013042][04 00][00] v1.40.0.0 -> v1.40.0.0 [00013091][09 00][00] v1.7.0.3 -> v1.7.0.3 [00013211][11 00][00] v1.7.0.0 -> v1.7.0.0 [00013306][12 00][00] v1.8.0.0 -> v1.8.0.0 [00013406][12 01][00] v1.8.0.0 -> v1.8.0.0 [00013509][12 02][00] v1.8.0.0 -> v1.8.0.0 [00013605][12 03][00] v1.8.0.0 -> v1.8.0.0 [00013745][15 00][00] v1.1.2.0 -> v1.1.2.0 [00013837][17 00][00] v1.1.1.7 -> v1.1.1.7 [00013959][17 01][00] v1.0.2.7 -> v1.0.2.7 [00014012][19 00][00] v1.0.8.96 -> v1.0.8.96 [00014049][01 00][00] v1.23.3419 -> v1.23.3419 [00014091][01 01][00] v1.23.3419 -> v1.23.3419 [00014137][08 00][00] v0.12.0.4 -> v0.12.0.4 [00014178]Packet upgrade cancelled at version checking. [00012565]========== 2015.08.25 20:46:43. boot(15) ============ [00012601]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00012644]Packet upgrade start... [00012685]Packet checking... [00012724]Packet vlink 01.04.0005 01.03.0020. [00012761]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00012801]Done. [00012840]Version checking[1]... [00012924][03 05][00] v34.2.0.9 -> v34.2.0.9 [00013021][03 06][00] v2.3.0.10 -> v2.3.0.10 [00013064][04 00][00] v1.40.0.0 -> v1.40.0.0 [00013122][09 00][00] v1.7.0.3 -> v1.7.0.3 [00013258][11 00][00] v1.7.0.0 -> v1.7.0.0 [00013356][12 00][00] v1.8.0.0 -> v1.8.0.0 [00013428][12 01][00] v1.8.0.0 -> v1.8.0.0 [00013503][12 02][00] v1.8.0.0 -> v1.8.0.0 [00013601][12 03][00] v1.8.0.0 -> v1.8.0.0 [00013743][15 00][00] v1.1.2.0 -> v1.1.2.0 [00013826][17 00][00] v1.1.1.7 -> v1.1.1.7 [00013947][17 01][00] v1.0.2.7 -> v1.0.2.7 [00014004][19 00][00] v1.0.8.96 -> v1.0.8.96 [00014045][01 00][00] v1.23.3419 -> v1.23.3419 [00014174][01 01][00] v1.23.3419 -> v1.23.3419 [00014260][08 00][00] v0.12.0.4 -> v0.12.0.4 [00014299]Packet upgrade cancelled at version checking. [00012533]========== remo-con disconnect. boot(15) ============ [00012573]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00012610]Packet upgrade start... [00012661]Packet checking... [00012698]Packet vlink 01.04.0005 01.03.0020. [00012736]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00012775]Done. [00012819]Version checking[1]... [00012886][03 05][00] v34.2.0.9 -> v34.2.0.9 [00012967][03 06][00] v2.3.0.10 -> v2.3.0.10 [00013010][04 00][00] v1.40.0.0 -> v1.40.0.0 [00013068][09 00][00] v1.7.0.3 -> v1.7.0.3 [00013182][11 00][00] v1.7.0.0 -> v1.7.0.0 [00013306][12 00][00] v1.8.0.0 -> v1.8.0.0 [00013391][12 01][00] v1.8.0.0 -> v1.8.0.0 [00013482][12 02][00] v1.8.0.0 -> v1.8.0.0 [00013578][12 03][00] v1.8.0.0 -> v1.8.0.0 [00013756][15 00][00] v1.1.2.0 -> v1.1.2.0 [00013833][17 00][00] v1.1.1.7 -> v1.1.1.7 [00013953][17 01][00] v1.0.2.7 -> v1.0.2.7 [00014018][19 00][00] v1.0.8.96 -> v1.0.8.96 [00014055][01 00][00] v1.23.3419 -> v1.23.3419 [00014100][01 01][00] v1.23.3419 -> v1.23.3419 [00014154][08 00][00] v0.12.0.4 -> v0.12.0.4 [00014192]Packet upgrade cancelled at version checking. [00012552]========== 2015.08.26 09:10:48. boot(15) ============ [00012591]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00012628]Packet upgrade start... [00012676]Packet checking... [00012716]Packet vlink 01.04.0005 01.03.0020. [00012752]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00012790]Done. [00012831]Version checking[1]... [00012920][03 05][00] v34.2.0.9 -> v34.2.0.9 [00013001][03 06][00] v2.3.0.10 -> v2.3.0.10 [00013050][04 00][00] v1.40.0.0 -> v1.40.0.0 [00013113][09 00][00] v1.7.0.3 -> v1.7.0.3 [00013243][11 00][00] v1.7.0.0 -> v1.7.0.0 [00013334][12 00][00] v1.8.0.0 -> v1.8.0.0 [00013421][12 01][00] v1.8.0.0 -> v1.8.0.0 [00013575][12 02][00] v1.8.0.0 -> v1.8.0.0 [00013678][12 03][00] v1.8.0.0 -> v1.8.0.0 [00013825][15 00][00] v1.1.2.0 -> v1.1.2.0 [00013910][17 00][00] v1.1.1.7 -> v1.1.1.7 [00014049][17 01][00] v1.0.2.7 -> v1.0.2.7 [00014103][19 00][00] v1.0.8.96 -> v1.0.8.96 [00014143][01 00][00] v1.23.3419 -> v1.23.3419 [00014185][01 01][00] v1.23.3419 -> v1.23.3419 [00014272][08 00][00] v0.12.0.4 -> v0.12.0.4 [00014311]Packet upgrade cancelled at version checking. [00014212]========== 2015.08.27 09:40:00. boot(15) ============ [00014362]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00014470]Packet upgrade start... [00014626]Packet checking... [00014742]Packet vlink 01.04.0005 01.03.0020. [00014849]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00014919]Done. [00015029]Version checking[1]... [00015177][03 05][00] v34.2.0.9 -> v34.2.0.9 [00015337][03 06][00] v2.3.0.10 -> v2.3.0.10 [00015464][04 00][00] v1.40.0.0 -> v1.40.0.0 [00015606][09 00][00] v1.7.0.3 -> v1.7.0.3 [00015836][11 00][00] v1.7.0.0 -> v1.7.0.0 [00015993][12 00][00] v1.8.0.0 -> v1.8.0.0 [00016138][12 01][00] v1.8.0.0 -> v1.8.0.0 [00016326][12 02][00] v1.8.0.0 -> v1.8.0.0 [00016498][12 03][00] v1.8.0.0 -> v1.8.0.0 [00016717][15 00][00] v1.1.2.0 -> v1.1.2.0 [00016886][17 00][00] v1.1.1.7 -> v1.1.1.7 [00017086][17 01][00] v1.0.2.7 -> v1.0.2.7 [00017206][19 00][00] v1.0.8.96 -> v1.0.8.96 [00017312][01 00][00] v1.23.3419 -> v1.23.3419 [00017370][01 01][00] v1.23.3419 -> v1.23.3419 [00017419][08 00][00] v0.12.0.4 -> v0.12.0.4 [00017458]Packet upgrade cancelled at version checking. [00014263]========== 2015.08.27 09:49:43. boot(15) ============ [00014372]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00014478]Packet upgrade start... [00014633]Packet checking... [00014754]Packet vlink 01.04.0005 01.03.0020. [00014864]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00014943]Done. [00015033]Version checking[1]... [00015332][03 05][00] v34.2.0.9 -> v34.2.0.9 [00015508][03 06][00] v2.3.0.10 -> v2.3.0.10 [00015622][04 00][00] v1.40.0.0 -> v1.40.0.0 [00015752][09 00][00] v1.7.0.3 -> v1.7.0.3 [00015950][11 00][00] v1.7.0.0 -> v1.7.0.0 [00016118][12 00][00] v1.8.0.0 -> v1.8.0.0 [00016262][12 01][00] v1.8.0.0 -> v1.8.0.0 [00016442][12 02][00] v1.8.0.0 -> v1.8.0.0 [00016601][12 03][00] v1.8.0.0 -> v1.8.0.0 [00016820][15 00][00] v1.1.2.0 -> v1.1.2.0 [00016976][17 00][00] v1.1.1.7 -> v1.1.1.7 [00017235][17 01][00] v1.0.2.7 -> v1.0.2.7 [00017373][19 00][00] v1.0.8.96 -> v1.0.8.96 [00017472][01 00][00] v1.23.3419 -> v1.23.3419 [00017562][01 01][00] v1.23.3419 -> v1.23.3419 [00017699][08 00][00] v0.12.0.4 -> v0.12.0.4 [00017809]Packet upgrade cancelled at version checking. [00012920]========== 2015.08.27 09:51:04. boot(15) ============ [00012960]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00013007]Packet upgrade start... [00013053]Packet checking... [00013092]Packet vlink 01.04.0005 01.03.0020. [00013131]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00013177]Done. [00013217]Version checking[1]... [00013302][03 05][00] v34.2.0.9 -> v34.2.0.9 [00013398][03 06][00] v2.3.0.10 -> v2.3.0.10 [00013444][04 00][00] v1.40.0.0 -> v1.40.0.0 [00013517][09 00][00] v1.7.0.3 -> v1.7.0.3 [00013639][11 00][00] v1.7.0.0 -> v1.7.0.0 [00013731][12 00][00] v1.8.0.0 -> v1.8.0.0 [00013831][12 01][00] v1.8.0.0 -> v1.8.0.0 [00013931][12 02][00] v1.8.0.0 -> v1.8.0.0 [00014031][12 03][00] v1.8.0.0 -> v1.8.0.0 [00014183][15 00][00] v1.1.2.0 -> v1.1.2.0 [00014266][17 00][00] v1.1.1.7 -> v1.1.1.7 [00014386][17 01][00] v1.0.2.7 -> v1.0.2.7 [00014457][19 00][00] v1.0.8.96 -> v1.0.8.96 [00014497][01 00][00] v1.23.3419 -> v1.23.3419 [00014537][01 01][00] v1.23.3419 -> v1.23.3419 [00014596][08 00][00] v0.12.0.4 -> v0.12.0.4 [00014634]Packet upgrade cancelled at version checking. [00013177]========== 2015.08.27 09:53:23. boot(15) ============ [00013284]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00013329]Packet upgrade start... [00013373]Packet checking... [00013414]Packet vlink 01.04.0005 01.03.0020. [00013458]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00013500]Done. [00013541]Version checking[1]... [00013606][03 05][00] v34.2.0.9 -> v34.2.0.9 [00013706][03 06][00] v2.3.0.10 -> v2.3.0.10 [00013757][04 00][00] v1.40.0.0 -> v1.40.0.0 [00013819][09 00][00] v1.7.0.3 -> v1.7.0.3 [00013946][11 00][00] v1.7.0.0 -> v1.7.0.0 [00014039][12 00][00] v1.8.0.0 -> v1.8.0.0 [00014140][12 01][00] v1.8.0.0 -> v1.8.0.0 [00014240][12 02][00] v1.8.0.0 -> v1.8.0.0 [00014339][12 03][00] v1.8.0.0 -> v1.8.0.0 [00014482][15 00][00] v1.1.2.0 -> v1.1.2.0 [00014594][17 00][00] v1.1.1.7 -> v1.1.1.7 [00014714][17 01][00] v1.0.2.7 -> v1.0.2.7 [00014779][19 00][00] v1.0.8.96 -> v1.0.8.96 [00014823][01 00][00] v1.23.3419 -> v1.23.3419 [00014865][01 01][00] v1.23.3419 -> v1.23.3419 [00014929][08 00][00] v0.12.0.4 -> v0.12.0.4 [00014969]Packet upgrade cancelled at version checking. [00013164]========== remo-con disconnect. boot(15) ============ [00013204]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00013245]Packet upgrade start... [00013293]Packet checking... [00013337]Packet vlink 01.04.0005 01.03.0020. [00013379]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00013453]Done. [00013500]Version checking[1]... [00013584][03 05][00] v34.2.0.9 -> v34.2.0.9 [00013664][03 06][00] v2.3.0.10 -> v2.3.0.10 [00013710][04 00][00] v1.40.0.0 -> v1.40.0.0 [00013778][09 00][00] v1.7.0.3 -> v1.7.0.3 [00013908][11 00][00] v1.7.0.0 -> v1.7.0.0 [00014023][12 00][00] v1.8.0.0 -> v1.8.0.0 [00014125][12 01][00] v1.8.0.0 -> v1.8.0.0 [00014219][12 02][00] v1.8.0.0 -> v1.8.0.0 [00014329][12 03][00] v1.8.0.0 -> v1.8.0.0 [00014466][15 00][00] v1.1.2.0 -> v1.1.2.0 [00014559][17 00][00] v1.1.1.7 -> v1.1.1.7 [00014685][17 01][00] v1.0.2.7 -> v1.0.2.7 [00014838][19 00][00] v1.0.8.96 -> v1.0.8.96 [00014881][01 00][00] v1.23.3419 -> v1.23.3419 [00014934][01 01][00] v1.23.3419 -> v1.23.3419 [00014989][08 00][00] v0.12.0.4 -> v0.12.0.4 [00015033]Packet upgrade cancelled at version checking. [00013234]========== 2015.08.27 10:15:30. boot(15) ============ [00013275]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00013325]Packet upgrade start... [00013373]Packet checking... [00013415]Packet vlink 01.04.0005 01.03.0020. [00013464]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00013506]Done. [00013549]Version checking[1]... [00013635][03 05][00] v34.2.0.9 -> v34.2.0.9 [00013733][03 06][00] v2.3.0.10 -> v2.3.0.10 [00013788][04 00][00] v1.40.0.0 -> v1.40.0.0 [00013845][09 00][00] v1.7.0.3 -> v1.7.0.3 [00013949][11 00][00] v1.7.0.0 -> v1.7.0.0 [00014045][12 00][00] v1.8.0.0 -> v1.8.0.0 [00014143][12 01][00] v1.8.0.0 -> v1.8.0.0 [00014249][12 02][00] v1.8.0.0 -> v1.8.0.0 [00014344][12 03][00] v1.8.0.0 -> v1.8.0.0 [00014497][15 00][00] v1.1.2.0 -> v1.1.2.0 [00014598][17 00][00] v1.1.1.7 -> v1.1.1.7 [00014750][17 01][00] v1.0.2.7 -> v1.0.2.7 [00014805][19 00][00] v1.0.8.96 -> v1.0.8.96 [00014848][01 00][00] v1.23.3419 -> v1.23.3419 [00014894][01 01][00] v1.23.3419 -> v1.23.3419 [00014950][08 00][00] v0.12.0.4 -> v0.12.0.4 [00014992]Packet upgrade cancelled at version checking. [00013135]========== 2015.08.27 10:16:49. boot(15) ============ [00013179]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00013226]Packet upgrade start... [00013273]Packet checking... [00013317]Packet vlink 01.04.0005 01.03.0020. [00013366]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00013410]Done. [00013452]Version checking[1]... [00013531][03 05][00] v34.2.0.9 -> v34.2.0.9 [00013610][03 06][00] v2.3.0.10 -> v2.3.0.10 [00013663][04 00][00] v1.40.0.0 -> v1.40.0.0 [00013735][09 00][00] v1.7.0.3 -> v1.7.0.3 [00013850][11 00][00] v1.7.0.0 -> v1.7.0.0 [00014019][12 00][00] v1.8.0.0 -> v1.8.0.0 [00014095][12 01][00] v1.8.0.0 -> v1.8.0.0 [00014184][12 02][00] v1.8.0.0 -> v1.8.0.0 [00014296][12 03][00] v1.8.0.0 -> v1.8.0.0 [00014453][15 00][00] v1.1.2.0 -> v1.1.2.0 [00014539][17 00][00] v1.1.1.7 -> v1.1.1.7 [00014659][17 01][00] v1.0.2.7 -> v1.0.2.7 [00014714][19 00][00] v1.0.8.96 -> v1.0.8.96 [00014761][01 00][00] v1.23.3419 -> v1.23.3419 [00014810][01 01][00] v1.23.3419 -> v1.23.3419 [00014870][08 00][00] v0.12.0.4 -> v0.12.0.4 [00014913]Packet upgrade cancelled at version checking. [00013201]========== remo-con disconnect. boot(15) ============ [00013243]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00013293]Packet upgrade start... [00013341]Packet checking... [00013386]Packet vlink 01.04.0005 01.03.0020. [00013431]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00013480]Done. [00013521]Version checking[1]... [00013588][03 05][00] v34.2.0.9 -> v34.2.0.9 [00013669][03 06][00] v2.3.0.10 -> v2.3.0.10 [00013720][04 00][00] v1.40.0.0 -> v1.40.0.0 [00013778][09 00][00] v1.7.0.3 -> v1.7.0.3 [00013889][11 00][00] v1.7.0.0 -> v1.7.0.0 [00014006][12 00][00] v1.8.0.0 -> v1.8.0.0 [00014079][12 01][00] v1.8.0.0 -> v1.8.0.0 [00014179][12 02][00] v1.8.0.0 -> v1.8.0.0 [00014260][12 03][00] v1.8.0.0 -> v1.8.0.0 [00014429][15 00][00] v1.1.2.0 -> v1.1.2.0 [00014520][17 00][00] v1.1.1.7 -> v1.1.1.7 [00014669][17 01][00] v1.0.2.7 -> v1.0.2.7 [00014731][19 00][00] v1.0.8.96 -> v1.0.8.96 [00014776][01 00][00] v1.23.3419 -> v1.23.3419 [00014821][01 01][00] v1.23.3419 -> v1.23.3419 [00014883][08 00][00] v0.12.0.4 -> v0.12.0.4 [00014935]Packet upgrade cancelled at version checking. [00012598]========== remo-con disconnect. boot(15) ============ [00012641]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00012685]Packet upgrade start... [00012740]Packet checking... [00012785]Packet vlink 01.04.0005 01.03.0020. [00012907]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00012954]Done. [00012999]Version checking[1]... [00013086][03 05][00] v34.2.0.9 -> v34.2.0.9 [00013165][03 06][00] v2.3.0.10 -> v2.3.0.10 [00013223][04 00][00] v1.40.0.0 -> v1.40.0.0 [00013280][09 00][00] v1.7.0.3 -> v1.7.0.3 [00013405][11 00][00] v1.7.0.0 -> v1.7.0.0 [00013509][12 00][00] v1.8.0.0 -> v1.8.0.0 [00013609][12 01][00] v1.8.0.0 -> v1.8.0.0 [00013726][12 02][00] v1.8.0.0 -> v1.8.0.0 [00013810][12 03][00] v1.8.0.0 -> v1.8.0.0 [00013973][15 00][00] v1.1.2.0 -> v1.1.2.0 [00014070][17 00][00] v1.1.1.7 -> v1.1.1.7 [00014200][17 01][00] v1.0.2.7 -> v1.0.2.7 [00014281][19 00][00] v1.0.8.96 -> v1.0.8.96 [00014326][01 00][00] v1.23.3419 -> v1.23.3419 [00014377][01 01][00] v1.23.3419 -> v1.23.3419 [00014444][08 00][00] v0.12.0.4 -> v0.12.0.4 [00014487]Packet upgrade cancelled at version checking. [00012590]========== remo-con disconnect. boot(15) ============ [00012634]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00012681]Packet upgrade start... [00012734]Packet checking... [00012779]Packet vlink 01.04.0005 01.03.0020. [00012822]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00012868]Done. [00012918]Version checking[1]... [00013003][03 05][00] v34.2.0.9 -> v34.2.0.9 [00013083][03 06][00] v2.3.0.10 -> v2.3.0.10 [00013133][04 00][00] v1.40.0.0 -> v1.40.0.0 [00013192][09 00][00] v1.7.0.3 -> v1.7.0.3 [00013383][11 00][00] v1.7.0.0 -> v1.7.0.0 [00013483][12 00][00] v1.8.0.0 -> v1.8.0.0 [00013572][12 01][00] v1.8.0.0 -> v1.8.0.0 [00013671][12 02][00] v1.8.0.0 -> v1.8.0.0 [00013782][12 03][00] v1.8.0.0 -> v1.8.0.0 [00013935][15 00][00] v1.1.2.0 -> v1.1.2.0 [00014028][17 00][00] v1.1.1.7 -> v1.1.1.7 [00014157][17 01][00] v1.0.2.7 -> v1.0.2.7 [00014212][19 00][00] v1.0.8.96 -> v1.0.8.96 [00014264][01 00][00] v1.23.3419 -> v1.23.3419 [00014310][01 01][00] v1.23.3419 -> v1.23.3419 [00014374][08 00][00] v0.12.0.4 -> v0.12.0.4 [00014505]Packet upgrade cancelled at version checking. [00012603]========== remo-con disconnect. boot(15) ============ [00012649]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00012694]Packet upgrade start... [00012749]Packet checking... [00012796]Packet vlink 01.04.0005 01.03.0020. [00012842]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00012889]Done. [00012934]Version checking[1]... [00013019][03 05][00] v34.2.0.9 -> v34.2.0.9 [00013099][03 06][00] v2.3.0.10 -> v2.3.0.10 [00013149][04 00][00] v1.40.0.0 -> v1.40.0.0 [00013207][09 00][00] v1.7.0.3 -> v1.7.0.3 [00013334][11 00][00] v1.7.0.0 -> v1.7.0.0 [00013428][12 00][00] v1.8.0.0 -> v1.8.0.0 [00013526][12 01][00] v1.8.0.0 -> v1.8.0.0 [00013603][12 02][00] v1.8.0.0 -> v1.8.0.0 [00013692][12 03][00] v1.8.0.0 -> v1.8.0.0 [00013830][15 00][00] v1.1.2.0 -> v1.1.2.0 [00013928][17 00][00] v1.1.1.7 -> v1.1.1.7 [00014044][17 01][00] v1.0.2.7 -> v1.0.2.7 [00014103][19 00][00] v1.0.8.96 -> v1.0.8.96 [00014150][01 00][00] v1.23.3419 -> v1.23.3419 [00014202][01 01][00] v1.23.3419 -> v1.23.3419 [00014278][08 00][00] v0.12.0.4 -> v0.12.0.4 [00014330]Packet upgrade cancelled at version checking. [00012614]========== remo-con disconnect. boot(15) ============ [00012659]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00012704]Packet upgrade start... [00012760]Packet checking... [00012807]Packet vlink 01.04.0005 01.03.0020. [00012853]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00012900]Done. [00012947]Version checking[1]... [00013028][03 05][00] v34.2.0.9 -> v34.2.0.9 [00013108][03 06][00] v2.3.0.10 -> v2.3.0.10 [00013159][04 00][00] v1.40.0.0 -> v1.40.0.0 [00013223][09 00][00] v1.7.0.3 -> v1.7.0.3 [00013328][11 00][00] v1.7.0.0 -> v1.7.0.0 [00013423][12 00][00] v1.8.0.0 -> v1.8.0.0 [00013502][12 01][00] v1.8.0.0 -> v1.8.0.0 [00013602][12 02][00] v1.8.0.0 -> v1.8.0.0 [00013702][12 03][00] v1.8.0.0 -> v1.8.0.0 [00013911][15 00][00] v1.1.2.0 -> v1.1.2.0 [00013997][17 00][00] v1.1.1.7 -> v1.1.1.7 [00014143][17 01][00] v1.0.2.7 -> v1.0.2.7 [00014202][19 00][00] v1.0.8.96 -> v1.0.8.96 [00014256][01 00][00] v1.23.3419 -> v1.23.3419 [00014304][01 01][00] v1.23.3419 -> v1.23.3419 [00014367][08 00][00] v0.12.0.4 -> v0.12.0.4 [00014410]Packet upgrade cancelled at version checking. [00012618]========== remo-con disconnect. boot(15) ============ [00012664]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00012711]Packet upgrade start... [00012770]Packet checking... [00012815]Packet vlink 01.04.0005 01.03.0020. [00012863]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00012916]Done. [00012963]Version checking[1]... [00013055][03 05][00] v34.2.0.9 -> v34.2.0.9 [00013146][03 06][00] v2.3.0.10 -> v2.3.0.10 [00013198][04 00][00] v1.40.0.0 -> v1.40.0.0 [00013280][09 00][00] v1.7.0.3 -> v1.7.0.3 [00013450][11 00][00] v1.7.0.0 -> v1.7.0.0 [00013602][12 00][00] v1.8.0.0 -> v1.8.0.0 [00013699][12 01][00] v1.8.0.0 -> v1.8.0.0 [00013802][12 02][00] v1.8.0.0 -> v1.8.0.0 [00013920][12 03][00] v1.8.0.0 -> v1.8.0.0 [00014067][15 00][00] v1.1.2.0 -> v1.1.2.0 [00014157][17 00][00] v1.1.1.7 -> v1.1.1.7 [00014297][17 01][00] v1.0.2.7 -> v1.0.2.7 [00014356][19 00][00] v1.0.8.96 -> v1.0.8.96 [00014402][01 00][00] v1.23.3419 -> v1.23.3419 [00014450][01 01][00] v1.23.3419 -> v1.23.3419 [00014516][08 00][00] v0.12.0.4 -> v0.12.0.4 [00014562]Packet upgrade cancelled at version checking. [00012625]========== remo-con disconnect. boot(15) ============ [00012671]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00012716]Packet upgrade start... [00012773]Packet checking... [00012818]Packet vlink 01.04.0005 01.03.0020. [00012867]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00012918]Done. [00012964]Version checking[1]... [00013058][03 05][00] v34.2.0.9 -> v34.2.0.9 [00013155][03 06][00] v2.3.0.10 -> v2.3.0.10 [00013307][04 00][00] v1.40.0.0 -> v1.40.0.0 [00013378][09 00][00] v1.7.0.3 -> v1.7.0.3 [00013519][11 00][00] v1.7.0.0 -> v1.7.0.0 [00013623][12 00][00] v1.8.0.0 -> v1.8.0.0 [00013723][12 01][00] v1.8.0.0 -> v1.8.0.0 [00013836][12 02][00] v1.8.0.0 -> v1.8.0.0 [00013950][12 03][00] v1.8.0.0 -> v1.8.0.0 [00014104][15 00][00] v1.1.2.0 -> v1.1.2.0 [00014204][17 00][00] v1.1.1.7 -> v1.1.1.7 [00014364][17 01][00] v1.0.2.7 -> v1.0.2.7 [00014435][19 00][00] v1.0.8.96 -> v1.0.8.96 [00014483][01 00][00] v1.23.3419 -> v1.23.3419 [00014538][01 01][00] v1.23.3419 -> v1.23.3419 [00014600][08 00][00] v0.12.0.4 -> v0.12.0.4 [00014647]Packet upgrade cancelled at version checking. [00012643]========== remo-con disconnect. boot(15) ============ [00012690]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00012742]Packet upgrade start... [00012794]Packet checking... [00012844]Packet vlink 01.04.0005 01.03.0020. [00012895]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00012943]Done. [00012989]Version checking[1]... [00013073][03 05][00] v34.2.0.9 -> v34.2.0.9 [00013173][03 06][00] v2.3.0.10 -> v2.3.0.10 [00013250][04 00][00] v1.40.0.0 -> v1.40.0.0 [00013312][09 00][00] v1.7.0.3 -> v1.7.0.3 [00013432][11 00][00] v1.7.0.0 -> v1.7.0.0 [00013527][12 00][00] v1.8.0.0 -> v1.8.0.0 [00013626][12 01][00] v1.8.0.0 -> v1.8.0.0 [00013727][12 02][00] v1.8.0.0 -> v1.8.0.0 [00013827][12 03][00] v1.8.0.0 -> v1.8.0.0 [00014014][15 00][00] v1.1.2.0 -> v1.1.2.0 [00014122][17 00][00] v1.1.1.7 -> v1.1.1.7 [00014262][17 01][00] v1.0.2.7 -> v1.0.2.7 [00014335][19 00][00] v1.0.8.96 -> v1.0.8.96 [00014384][01 00][00] v1.23.3419 -> v1.23.3419 [00014431][01 01][00] v1.23.3419 -> v1.23.3419 [00014487][08 00][00] v0.12.0.4 -> v0.12.0.4 [00014542]Packet upgrade cancelled at version checking. [00012647]========== 2015.09.04 08:35:48. boot(15) ============ [00012693]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00012853]Packet upgrade start... [00012913]Packet checking... [00012965]Packet vlink 01.04.0005 01.03.0020. [00013013]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00013068]Done. [00013114]Version checking[1]... [00013193][03 05][00] v34.2.0.9 -> v34.2.0.9 [00015778][03 06][00] v2.3.0.10 -> v2.3.0.10 [00015845][04 00][00] v1.40.0.0 -> v1.40.0.0 [00015916][09 00][00] v1.7.0.3 -> v1.7.0.3 [00016053][11 00][00] v1.7.0.0 -> v1.7.0.0 [00016141][12 00][00] v1.8.0.0 -> v1.8.0.0 [00016241][12 01][00] v1.8.0.0 -> v1.8.0.0 [00016343][12 02][00] v1.8.0.0 -> v1.8.0.0 [00016442][12 03][00] v1.8.0.0 -> v1.8.0.0 [00016593][15 00][00] v1.1.2.0 -> v1.1.2.0 [00016681][17 00][00] v1.1.1.7 -> v1.1.1.7 [00016826][17 01][00] v1.0.2.7 -> v1.0.2.7 [00016898][19 00][00] v1.0.8.96 -> v1.0.8.96 [00016947][01 00][00] v1.23.3419 -> v1.23.3419 [00016995][01 01][00] v1.23.3419 -> v1.23.3419 [00017062][08 00][00] v0.12.0.4 -> v0.12.0.4 [00017111]Packet upgrade cancelled at version checking. [00012693]========== remo-con disconnect. boot(15) ============ [00012748]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00012795]Packet upgrade start... [00012853]Packet checking... [00012908]Packet vlink 01.04.0005 01.03.0020. [00012958]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00013007]Done. [00013064]Version checking[1]... [00013138][03 05][00] v34.2.0.9 -> v34.2.0.9 [00013215][03 06][00] v2.3.0.10 -> v2.3.0.10 [00013279][04 00][00] v1.40.0.0 -> v1.40.0.0 [00013347][09 00][00] v1.7.0.3 -> v1.7.0.3 [00013474][11 00][00] v1.7.0.0 -> v1.7.0.0 [00013587][12 00][00] v1.8.0.0 -> v1.8.0.0 [00013694][12 01][00] v1.8.0.0 -> v1.8.0.0 [00013813][12 02][00] v1.8.0.0 -> v1.8.0.0 [00013913][12 03][00] v1.8.0.0 -> v1.8.0.0 [00014068][15 00][00] v1.1.2.0 -> v1.1.2.0 [00014145][17 00][00] v1.1.1.7 -> v1.1.1.7 [00014263][17 01][00] v1.0.2.7 -> v1.0.2.7 [00014335][19 00][00] v1.0.8.96 -> v1.0.8.96 [00014383][01 00][00] v1.23.3419 -> v1.23.3419 [00014509][01 01][00] v1.23.3419 -> v1.23.3419 [00014574][08 00][00] v0.12.0.4 -> v0.12.0.4 [00014625]Packet upgrade cancelled at version checking. [00012691]========== remo-con disconnect. boot(15) ============ [00012748]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00012795]Packet upgrade start... [00012850]Packet checking... [00012910]Packet vlink 01.04.0005 01.03.0020. [00012957]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00013008]Done. [00013062]Version checking[1]... [00013156][03 05][00] v34.2.0.9 -> v34.2.0.9 [00013254][03 06][00] v2.3.0.10 -> v2.3.0.10 [00013310][04 00][00] v1.40.0.0 -> v1.40.0.0 [00013378][09 00][00] v1.7.0.3 -> v1.7.0.3 [00013511][11 00][00] v1.7.0.0 -> v1.7.0.0 [00013626][12 00][00] v1.8.0.0 -> v1.8.0.0 [00013726][12 01][00] v1.8.0.0 -> v1.8.0.0 [00013827][12 02][00] v1.8.0.0 -> v1.8.0.0 [00013926][12 03][00] v1.8.0.0 -> v1.8.0.0 [00014064][15 00][00] v1.1.2.0 -> v1.1.2.0 [00014156][17 00][00] v1.1.1.7 -> v1.1.1.7 [00014301][17 01][00] v1.0.2.7 -> v1.0.2.7 [00014371][19 00][00] v1.0.8.96 -> v1.0.8.96 [00014423][01 00][00] v1.23.3419 -> v1.23.3419 [00014475][01 01][00] v1.23.3419 -> v1.23.3419 [00014541][08 00][00] v0.12.0.4 -> v0.12.0.4 [00014592]Packet upgrade cancelled at version checking. [00012693]========== 2015.09.08 08:47:22. boot(15) ============ [00012747]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00012797]Packet upgrade start... [00012854]Packet checking... [00012909]Packet vlink 01.04.0005 01.03.0020. [00012960]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00013012]Done. [00013066]Version checking[1]... [00013139][03 05][00] v34.2.0.9 -> v34.2.0.9 [00013224][03 06][00] v2.3.0.10 -> v2.3.0.10 [00013277][04 00][00] v1.40.0.0 -> v1.40.0.0 [00013348][09 00][00] v1.7.0.3 -> v1.7.0.3 [00013480][11 00][00] v1.7.0.0 -> v1.7.0.0 [00013571][12 00][00] v1.8.0.0 -> v1.8.0.0 [00013649][12 01][00] v1.8.0.0 -> v1.8.0.0 [00013828][12 02][00] v1.8.0.0 -> v1.8.0.0 [00013929][12 03][00] v1.8.0.0 -> v1.8.0.0 [00014084][15 00][00] v1.1.2.0 -> v1.1.2.0 [00014173][17 00][00] v1.1.1.7 -> v1.1.1.7 [00014346][17 01][00] v1.0.2.7 -> v1.0.2.7 [00014417][19 00][00] v1.0.8.96 -> v1.0.8.96 [00014469][01 00][00] v1.23.3419 -> v1.23.3419 [00014524][01 01][00] v1.23.3419 -> v1.23.3419 [00014595][08 00][00] v0.12.0.4 -> v0.12.0.4 [00014645]Packet upgrade cancelled at version checking. [00012726]========== 2015.09.08 08:54:05. boot(15) ============ [00012777]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00012826]Packet upgrade start... [00012886]Packet checking... [00012938]Packet vlink 01.04.0005 01.03.0020. [00012987]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00013037]Done. [00013092]Version checking[1]... [00013180][03 05][00] v34.2.0.9 -> v34.2.0.9 [00013283][03 06][00] v2.3.0.10 -> v2.3.0.10 [00013339][04 00][00] v1.40.0.0 -> v1.40.0.0 [00013422][09 00][00] v1.7.0.3 -> v1.7.0.3 [00013541][11 00][00] v1.7.0.0 -> v1.7.0.0 [00013652][12 00][00] v1.8.0.0 -> v1.8.0.0 [00013749][12 01][00] v1.8.0.0 -> v1.8.0.0 [00013852][12 02][00] v1.8.0.0 -> v1.8.0.0 [00013949][12 03][00] v1.8.0.0 -> v1.8.0.0 [00014116][15 00][00] v1.1.2.0 -> v1.1.2.0 [00014242][17 00][00] v1.1.1.7 -> v1.1.1.7 [00014369][17 01][00] v1.0.2.7 -> v1.0.2.7 [00014457][19 00][00] v1.0.8.96 -> v1.0.8.96 [00014510][01 00][00] v1.23.3419 -> v1.23.3419 [00014562][01 01][00] v1.23.3419 -> v1.23.3419 [00014627][08 00][00] v0.12.0.4 -> v0.12.0.4 [00014681]Packet upgrade cancelled at version checking. [00013326]========== remo-con disconnect. boot(15) ============ [00013378]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x00ce092e]. [00013425]Packet upgrade start... [00013487]Packet checking... [00013539]Packet vlink 01.04.0005 01.03.0020. [00013589]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00013647]Done. [00013697]Version checking[1]... [00013875][03 05][00] v34.2.0.9 -> v34.2.0.9 [00013975][03 06][00] v2.3.0.10 -> v2.3.0.10 [00014032][04 00][00] v1.40.0.0 -> v1.40.0.0 [00014114][09 00][00] v1.7.0.3 -> v1.7.0.3 [00014254][11 00][00] v1.7.0.0 -> v1.7.0.0 [00014348][12 00][00] v1.8.0.0 -> v1.8.0.0 [00014448][12 01][00] v1.8.0.0 -> v1.8.0.0 [00014548][12 02][00] v1.8.0.0 -> v1.8.0.0 [00014663][12 03][00] v1.8.0.0 -> v1.8.0.0 [00014809][15 00][00] v1.1.2.0 -> v1.1.2.0 [00014903][17 00][00] v1.1.1.7 -> v1.1.1.7 [00015047][17 01][00] v1.0.2.7 -> v1.0.2.7 [00015113][19 00][00] v1.0.8.96 -> v1.0.8.96 [00015166][01 00][00] v1.23.3419 -> v1.23.3419 [00015223][01 01][00] v1.23.3419 -> v1.23.3419 [00015288][08 00][00] v0.12.0.4 -> v0.12.0.4 [00015340]Packet upgrade cancelled at version checking. [00014320]========== remo-con disconnect. boot(15) ============ [00014376]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x00ce092e]. [00014424]Packet upgrade start... [00014478]Packet checking... [00014536]Packet vlink 01.04.0010 01.03.0020. [00014586]Record vlink 01.04.0005 01.03.0020 (flow = 0). [00014635]Done. [00014690]Version checking[1]... [00014767][03 05][00] v34.2.0.9 -> v34.2.0.9 [00014856][03 06][00] v2.3.0.10 -> v2.3.0.13 need upgrade. [00014911][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade. [00014981][09 00][00] v1.7.0.3 -> v1.7.0.3 [00015132][11 00][00] v1.7.0.0 -> v1.7.0.0 [00015241][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade. [00015340][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade. [00015441][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade. [00015540][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade. [00015680][15 00][00] v1.1.2.0 -> v1.1.2.0 [00015781][17 00][00] v1.1.1.7 -> v1.1.1.7 [00015941][17 01][00] v1.0.2.7 -> v1.0.2.7 [00016000][19 00][00] v1.0.8.96 -> v1.0.8.96 [00016052][01 00][00] v1.23.3419 -> v1.23.3419 [00016105][01 01][00] v1.23.3419 -> v1.23.3419 [00016176][08 00][00] v0.12.0.4 -> v0.12.0.4 [00016225]Done. [00018372]Waiting for user ... [00028424]Timeout, start upgrade automatically. [00028528]Firmware upgrading[1]... [00028600][12 00] Firmware upgrade start... [00091766][12 00] Firmware upgrade finished successfully. [00091847][12 01] Firmware upgrade start... [00152243][12 01] Firmware upgrade finished successfully. [00152316][12 02] Firmware upgrade start... [00213633][12 02] Firmware upgrade finished successfully. [00213706][12 03] Firmware upgrade start... [00274450][12 03] Firmware upgrade finished successfully. [00274681][03 06] Firmware upgrade start... [00609154][03 06] Firmware upgrade finished successfully. [00609238][04 00] Firmware upgrade start... [00668328][04 00] Firmware upgrade finished successfully. [00668380]Done. [00668434]Version checking[2]... [00668529][03 05][00] v34.2.0.9 -> v34.2.0.9 [00668609][03 06][05] v2.3.0.13 -> v2.3.0.13 [00668672][04 00][05] v1.41.0.0 -> v1.41.0.0 [00668741][09 00][00] v1.7.0.3 -> v1.7.0.3 [00668850][11 00][00] v1.7.0.0 -> v1.7.0.0 [00668933][12 00][05] v1.10.0.0 -> v1.10.0.0 [00669023][12 01][05] v1.10.0.0 -> v1.10.0.0 [00669123][12 02][05] v1.10.0.0 -> v1.10.0.0 [00669223][12 03][05] v1.10.0.0 -> v1.10.0.0 [00669366][15 00][00] v1.1.2.0 -> v1.1.2.0 [00669453][17 00][00] v1.1.1.7 -> v1.1.1.7 [00669573][17 01][00] v1.0.2.7 -> v1.0.2.7 [00669639][19 00][00] v1.0.8.96 -> v1.0.8.96 [00669690][01 00][00] v1.23.3419 -> v1.23.3419 [00669744][01 01][00] v1.23.3419 -> v1.23.3419 [00669811][08 00][00] v0.12.0.4 -> v0.12.0.4 [00669871]Packet upgrade finish successfully. [00014003]========== 2015.09.08 20:41:31. boot(15) ============ [00014061]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x00ce092e]. [00014112]Packet upgrade start... [00014165]Packet checking... [00014227]Packet vlink 01.04.0010 01.03.0020. [00014275]Record vlink 01.04.0010 01.03.0020 (flow = 0). [00014328]Done. [00014384]Version checking[1]... [00014474][03 05][00] v34.2.0.9 -> v34.2.0.9 [00014637][03 06][00] v2.3.0.13 -> v2.3.0.13 [00014702][04 00][00] v1.41.0.0 -> v1.41.0.0 [00014764][09 00][00] v1.7.0.3 -> v1.7.0.3 [00014896][11 00][00] v1.7.0.0 -> v1.7.0.0 [00014981][12 00][00] v1.10.0.0 -> v1.10.0.0 [00015104][12 01][00] v1.10.0.0 -> v1.10.0.0 [00015204][12 02][00] v1.10.0.0 -> v1.10.0.0 [00015304][12 03][00] v1.10.0.0 -> v1.10.0.0 [00015450][15 00][00] v1.1.2.0 -> v1.1.2.0 [00015545][17 00][00] v1.1.1.7 -> v1.1.1.7 [00015675][17 01][00] v1.0.2.7 -> v1.0.2.7 [00015746][19 00][00] v1.0.8.96 -> v1.0.8.96 [00015800][01 00][00] v1.23.3419 -> v1.23.3419 [00015856][01 01][00] v1.23.3419 -> v1.23.3419 [00015916][08 00][00] v0.12.0.4 -> v0.12.0.4 [00015976]Packet upgrade cancelled at version checking. [00013565]========== remo-con disconnect. boot(15) ============ [00013623]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x00ce092e]. [00013675]Packet upgrade start... [00013739]Packet checking... [00013795]Packet vlink 01.03.0020 01.01.0009. [00013849]Record vlink 01.04.0010 01.03.0020 (flow = 1). [00013902]Done. [00013963]Version checking[1]... [00014063][03 05][00] v34.2.0.9 -> v34.2.0.9 [00014183][03 06][00] v2.3.0.13 -> v2.2.6.19 need upgrade. [00014250][04 00][00] v1.41.0.0 -> v1.40.0.0 need upgrade. [00014322][09 00][00] v1.7.0.3 -> v1.7.0.3 [00014463][11 00][00] v1.7.0.0 -> v1.7.0.0 [00014577][12 00][00] v1.10.0.0 -> v1.8.0.0 [00014677][12 01][00] v1.10.0.0 -> v1.8.0.0 [00014797][12 02][00] v1.10.0.0 -> v1.8.0.0 [00014897][12 03][00] v1.10.0.0 -> v1.8.0.0 [00015041][15 00][00] v1.1.2.0 -> v1.1.2.0 [00015154][17 00][00] v1.1.1.7 -> v1.1.1.7 [00015298][17 01][00] v1.0.2.7 -> v1.0.2.7 [00015383][19 00][00] v1.0.8.96 -> v1.0.8.96 [00015436][01 00][00] v1.23.3419 -> v1.23.3419 [00015490][01 01][00] v1.23.3419 -> v1.23.3419 [00015566][08 00][00] v0.12.0.4 -> v0.12.0.4 [00015619]Done. [00017669]Waiting for user ... [00013593]========== remo-con disconnect. boot(15) ============ [00013728]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x00ce092e]. [00013788]Packet upgrade start... [00013851]Packet checking... [00013907]Packet vlink 01.05.0030 01.04.0010. [00013972]Record vlink 01.04.0010 01.03.0020 (flow = 0). [00014028]Done. [00014090]Version checking[1]... [00014179][03 05][00] v34.2.0.9 -> v34.2.0.9 [00014260][03 06][00] v2.3.0.13 -> v2.4.0.5 need upgrade. [00014322][04 00][00] v1.41.0.0 -> v1.41.0.0 [00014460][11 00][00] v1.7.0.0 -> v1.7.0.0 [00014550][12 00][00] v1.10.0.0 -> v1.10.0.0 [00014649][12 01][00] v1.10.0.0 -> v1.10.0.0 [00014750][12 02][00] v1.10.0.0 -> v1.10.0.0 [00014849][12 03][00] v1.10.0.0 -> v1.10.0.0 [00024209][15 00][00] device not detected. [00024309][17 00][00] v1.1.1.7 -> v1.1.1.7 [00024450][17 01][00] v1.0.2.7 -> v1.0.2.7 [00024529][19 00][00] v1.0.8.96 -> v1.0.8.96 [00024583][01 00][00] v1.23.3419 -> v1.26.4315 need upgrade [00024638][01 01][00] v1.23.3419 -> v1.26.4315 need upgrade [00024712][08 00][00] v0.12.0.4 -> v0.13.0.7 need upgrade. [00024789][09 00][00] v1.7.0.3 -> v2.13.0.0 need upgrade. [00024849]Done. [00026902]Waiting for user ... [00036958]Timeout, start upgrade automatically. [00037072]Firmware upgrading[1]... [00049591][01 00] Firmware upgrade start... [00015129][01 00] Firmware upgrade finished successfully. [00015258]Done. [00015393]Packet [C:\P3X_FW_V01.05.0030.bin] resumed, card sn [0x00ce092e]. [00015556]Packet vlink 01.05.0030 01.04.0010. [00015683]Record vlink 01.04.0010 01.03.0020 (flow = 0). [00015817]Version checking[2]... [00015987][03 05][00] v34.2.0.9 -> v34.2.0.9 [00016192][03 06][00] v2.3.0.13 -> v2.4.0.5 need upgrade. [00016253][04 00][00] v1.41.0.0 -> v1.41.0.0 [00016387][11 00][00] v1.7.0.0 -> v1.7.0.0 [00016490][12 00][00] v1.10.0.0 -> v1.10.0.0 [00016591][12 01][00] v1.10.0.0 -> v1.10.0.0 [00016702][12 02][00] v1.10.0.0 -> v1.10.0.0 [00016812][12 03][00] v1.10.0.0 -> v1.10.0.0 [00016923][15 00][00] v1.1.2.0 -> v1.1.2.0 [00017111][17 00][00] v1.1.1.7 -> v1.1.1.7 [00017311][17 01][00] v1.0.2.7 -> v1.0.2.7 [00017391][19 00][00] v1.0.8.96 -> v1.0.8.96 [00017447][01 00][05] v1.26.4315 -> v1.26.4315 [00017507][01 01][00] v1.23.3419 -> v1.26.4315 need upgrade [00017580][08 00][00] v0.12.0.4 -> v0.13.0.7 need upgrade. [00017650][09 00][00] v1.7.0.3 -> v2.13.0.0 need upgrade. [00017706]Done. [00017762]Firmware upgrading[2]... [00017939][01 01] Firmware upgrade start... [00048230][01 01] Firmware upgrade finished successfully. [00049188][08 00] Firmware upgrade start... [01249188][08 00] Firmware upgrade flag timeout (pkt = 2, fw = 2). [01871128][08 00] Firmware upgrade finished successfully. [01871395][03 06] Firmware upgrade start... [02187795][03 06] Firmware upgrade finished successfully. [02187891][09 00] Firmware upgrade start... [02241417][09 00] Firmware upgrade finished successfully. [02241482]Done. [02241540]Version checking[3]... [02241637][03 05][00] v34.2.0.9 -> v34.2.0.9 [02241717][03 06][05] v2.4.0.5 -> v2.4.0.5 [02241781][04 00][00] v1.41.0.0 -> v1.41.0.0 [02241917][11 00][00] v1.7.0.0 -> v1.7.0.0 [02242027][12 00][00] v1.10.0.0 -> v1.10.0.0 [02242125][12 01][00] v1.10.0.0 -> v1.10.0.0 [02242227][12 02][00] v1.10.0.0 -> v1.10.0.0 [02242325][12 03][00] v1.10.0.0 -> v1.10.0.0 [02247581][15 00][00] device not detected. [02247681][17 00][00] v1.1.1.7 -> v1.1.1.7 [02247822][17 01][00] v1.0.2.7 -> v1.0.2.7 [02247901][19 00][00] v1.0.8.96 -> v1.0.8.96 [02247960][01 00][05] v1.26.4315 -> v1.26.4315 [02248016][01 01][05] v1.26.4315 -> v1.26.4315 [02248091][08 00][05] v0.13.0.7 -> v0.13.0.7 [02248182][09 00][05] v2.13.0.0 -> v2.13.0.0 [02248241]Packet upgrade failed at version checking. [00012743]========== remo-con disconnect. boot(15) ============ [00012798]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x00ce092e]. [00012856]Packet upgrade start... [00012922]Packet checking... [00012980]Packet vlink 01.05.0030 01.04.0010. [00013113]Record vlink 01.04.0010 01.03.0020 (flow = 0). [00013173]Done. [00013235]Version checking[1]... [00013315][03 05][00] v34.2.0.9 -> v34.2.0.9 [00013416][03 06][00] v2.4.0.5 -> v2.4.0.5 [00013483][04 00][00] v1.41.0.0 -> v1.41.0.0 [00013615][11 00][00] v1.7.0.0 -> v1.7.0.0 [00013705][12 00][00] v1.10.0.0 -> v1.10.0.0 [00013804][12 01][00] v1.10.0.0 -> v1.10.0.0 [00013904][12 02][00] v1.10.0.0 -> v1.10.0.0 [00014007][12 03][00] v1.10.0.0 -> v1.10.0.0 [00018967][15 00][00] device not detected. [00019064][17 00][00] v1.1.1.7 -> v1.1.1.7 [00019204][17 01][00] v1.0.2.7 -> v1.0.2.7 [00019287][19 00][00] v1.0.8.96 -> v1.0.8.96 [00019344][01 00][00] v1.26.4315 -> v1.26.4315 [00019403][01 01][00] v1.26.4315 -> v1.26.4315 [00029483][08 00][00] v0.13.0.7 -> v0.13.0.7 [00029566][09 00][00] v2.13.0.0 -> v2.13.0.0 [00029623]Packet upgrade failed at version checking. [00012718]========== remo-con disconnect. boot(15) ============ [00012783]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x00ce092e]. [00012838]Packet upgrade start... [00012905]Packet checking... [00012962]Packet vlink 01.05.0030 01.04.0010. [00013021]Record vlink 01.04.0010 01.03.0020 (flow = 0). [00013083]Done. [00013142]Version checking[1]... [00013241][03 05][00] v34.2.0.9 -> v34.2.0.9 [00013342][03 06][00] v2.4.0.5 -> v2.4.0.5 [00013407][04 00][00] v1.41.0.0 -> v1.41.0.0 [00013541][11 00][00] v1.7.0.0 -> v1.7.0.0 [00013653][12 00][00] v1.10.0.0 -> v1.10.0.0 [00013773][12 01][00] v1.10.0.0 -> v1.10.0.0 [00013895][12 02][00] v1.10.0.0 -> v1.10.0.0 [00014017][12 03][00] v1.10.0.0 -> v1.10.0.0 [00018977][15 00][00] device not detected. [00019093][17 00][00] v1.1.1.7 -> v1.1.1.7 [00019230][17 01][00] v1.0.2.7 -> v1.0.2.7 [00019301][19 00][00] v1.0.8.96 -> v1.0.8.96 [00019359][01 00][00] v1.26.4315 -> v1.26.4315 [00019417][01 01][00] v1.26.4315 -> v1.26.4315 [00029487][08 00][00] v0.13.0.7 -> v0.13.0.7 [00029563][09 00][00] v2.13.0.0 -> v2.13.0.0 [00029713]Packet upgrade failed at version checking. [00012735]========== remo-con disconnect. boot(15) ============ [00012792]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x00ce092e]. [00012857]Packet upgrade start... [00012922]Packet checking... [00012981]Packet vlink 01.05.0030 01.04.0010. [00013041]Record vlink 01.04.0010 01.03.0020 (flow = 0). [00013106]Done. [00013164]Version checking[1]... [00025732][03 05][00] device not detected. [00038292][03 06][00] device not detected. [00038368][04 00][00] v1.41.0.0 -> v1.41.0.0 [00050932][11 00][00] device not detected. [00063493][12 00][00] device not detected. [00076052][12 01][00] device not detected. [00088615][12 02][00] device not detected. [00101174][12 03][00] device not detected. [00113736][15 00][00] device not detected. [00126294][17 00][00] device not detected. [00138857][17 01][00] device not detected. [00151413][19 00][00] device not detected. [00151476][01 00][00] v1.26.4315 -> v1.26.4315 [00151537][01 01][00] v1.26.4315 -> v1.26.4315 [00154109][08 00][00] v0.13.0.7 -> v0.13.0.7 [00166672][09 00][00] device not detected. [00166731]Packet upgrade failed at version checking. [00038751]========== remo-con disconnect. boot(15) ============ [00038809]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x00ce092e]. [00038876]Packet upgrade start... [00038940]Packet checking... [00039005]Packet vlink 01.05.0030 01.04.0010. [00039067]Record vlink 01.04.0010 01.03.0020 (flow = 0). [00039123]Done. [00039189]Version checking[1]... [00051757][03 05][00] device not detected. [00064321][03 06][00] device not detected. [00064391][04 00][00] v1.41.0.0 -> v1.41.0.0 [00076957][11 00][00] device not detected. [00089517][12 00][00] device not detected. [00102082][12 01][00] device not detected. [00114641][12 02][00] device not detected. [00127205][12 03][00] device not detected. [00135864][15 00][00] device not detected. [00148499][17 00][00] device not detected. [00161057][17 01][00] device not detected. [00173617][19 00][00] device not detected. [00173677][01 00][00] v1.26.4315 -> v1.26.4315 [00173744][01 01][00] v1.26.4315 -> v1.26.4315 [00178901][08 00][00] v0.13.0.7 -> v0.13.0.7 [00191459][09 00][00] device not detected. [00191517]Packet upgrade failed at version checking. [00012723]========== remo-con disconnect. boot(15) ============ [00012778]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x00ce092e]. [00012840]Packet upgrade start... [00012908]Packet checking... [00012967]Packet vlink 01.05.0030 01.04.0010. [00013023]Record vlink 01.04.0010 01.03.0020 (flow = 0). [00013091]Done. [00013151]Version checking[1]... [00025716][03 05][00] device not detected. [00038276][03 06][00] device not detected. [00038352][04 00][00] v1.41.0.0 -> v1.41.0.0 [00050916][11 00][00] device not detected. [00063478][12 00][00] device not detected. [00076036][12 01][00] device not detected. [00088600][12 02][00] device not detected. [00101160][12 03][00] device not detected. [00113721][15 00][00] device not detected. [00126277][17 00][00] device not detected. [00138842][17 01][00] device not detected. [00151398][19 00][00] device not detected. [00151461][01 00][00] v1.26.4315 -> v1.26.4315 [00151521][01 01][00] v1.26.4315 -> v1.26.4315 [00151596][08 00][00] v0.13.0.7 -> v0.13.0.7 [00164157][09 00][00] device not detected. [00164214]Packet upgrade failed at version checking. [00012751]========== remo-con disconnect. boot(15) ============ [00012809]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x00ce092e]. [00012866]Packet upgrade start... [00012932]Packet checking... [00012989]Packet vlink 01.04.0010 01.03.0020. [00013052]Record vlink 01.04.0010 01.03.0020 (flow = 0). [00013107]Done. [00013163]Version checking[1]... [00025732][03 05][00] device not detected. [00038292][03 06][00] device not detected. [00038457][04 00][00] v1.41.0.0 -> v1.41.0.0 [00051016][09 00][00] device not detected. [00063574][11 00][00] device not detected. [00076137][12 00][00] device not detected. [00088692][12 01][00] device not detected. [00101253][12 02][00] device not detected. [00113812][12 03][00] device not detected. [00116720][15 00][00] device not detected. [00129282][17 00][00] device not detected. [00141839][17 01][00] device not detected. [00154403][19 00][00] device not detected. [00154463][01 00][00] v1.26.4315 -> v1.23.3419 [00154525][01 01][00] v1.26.4315 -> v1.23.3419 [00157096][08 00][00] v0.13.0.7 -> v0.12.0.4 [00157152]Packet upgrade failed at version checking. [00012757]========== remo-con disconnect. boot(15) ============ [00012816]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x00ce092e]. [00012870]Packet upgrade start... [00012938]Packet checking... [00012996]Packet vlink 01.05.0030 01.04.0010. [00013060]Record vlink 01.04.0010 01.03.0020 (flow = 0). [00013116]Done. [00013176]Version checking[1]... [00025737][03 05][00] device not detected. [00038290][03 06][00] device not detected. [00038361][04 00][00] v1.41.0.0 -> v1.41.0.0 [00050921][11 00][00] device not detected. [00063483][12 00][00] device not detected. [00076041][12 01][00] device not detected. [00088601][12 02][00] device not detected. [00101161][12 03][00] device not detected. [00113730][15 00][00] device not detected. [00126290][17 00][00] device not detected. [00138850][17 01][00] device not detected. [00151410][19 00][00] device not detected. [00151474][01 00][00] v1.26.4315 -> v1.26.4315 [00151533][01 01][00] v1.26.4315 -> v1.26.4315 [00156608][08 00][00] v0.13.0.7 -> v0.13.0.7 [00169170][09 00][00] device not detected. [00169234]Packet upgrade failed at version checking. [00013493]========== remo-con disconnect. boot(15) ============ [00013556]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x00ce092e]. [00013615]Packet upgrade start... [00013753]Packet checking... [00013815]Packet vlink 01.05.0030 01.04.0010. [00013879]Record vlink 01.04.0010 01.03.0020 (flow = 0). [00013938]Done. [00013993]Version checking[1]... [00026561][03 05][00] device not detected. [00039120][03 06][00] device not detected. [00039194][04 00][00] v1.41.0.0 -> v1.41.0.0 [00051754][11 00][00] device not detected. [00012756]========== remo-con disconnect. boot(15) ============ [00012816]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x00ce092e]. [00012875]Packet upgrade start... [00012943]Packet checking... [00013001]Packet vlink 01.05.0030 01.04.0010. [00013066]Record vlink 01.04.0010 01.03.0020 (flow = 0). [00013124]Done. [00013181]Version checking[1]... [00025745][03 05][00] device not detected. [00038302][03 06][00] device not detected. [00038377][04 00][00] v1.41.0.0 -> v1.41.0.0 [00050934][11 00][00] device not detected. [00063496][12 00][00] device not detected. [00076053][12 01][00] device not detected. [00088615][12 02][00] device not detected. [00101174][12 03][00] device not detected. [00113738][15 00][00] device not detected. [00126293][17 00][00] device not detected. [00138855][17 01][00] device not detected. [00151413][19 00][00] device not detected. [00151477][01 00][00] v1.26.4315 -> v1.26.4315 [00151538][01 01][00] v1.26.4315 -> v1.26.4315 [00156602][08 00][00] v0.13.0.7 -> v0.13.0.7 [00169161][09 00][00] device not detected. [00169227]Packet upgrade failed at version checking.
2015-12-1
秋香
11
已累计飞行 0 米
把log上传我帮您看看具体是哪里升挂了
2015-12-1
chuhao0
10
已累计飞行 0 米
我都升级了好多次 总是在红绿闪烁之后几分钟就红灯常亮 然后一直发出滴声 无人机关闭电源还不能立即关闭 怎么解决啊
2015-12-1
秋香
9
已累计飞行 0 米
后面升级显示是失败的
2015-12-1
秋香
8
已累计飞行 0 米
可以把log上传我们具体看看是哪里失败吗?
2015-12-1
chuhao0
7
已累计飞行 0 米
能帮忙解释下 这是什么情况吗?
2015-12-1
查看更多评论
关于作者
已累计飞行 0 米
chuhao0
最新帖子
精灵三的智能跟随
精灵三的智能跟随一直不能使用
大疆官方客服服务态度奇好
