========== 2014.01.01 00:00:03 remo-con disconnect======
Packet: OSMO_FW_V01.00.00.24.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:06 remo-con disconnect======
Packet: OSMO_FW_V01.00.01.19.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:09 remo-con disconnect======
Packet: OSMO_FW_V01.02.01.60.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:11 remo-con disconnect======
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2014.01.01 00:00:10 remo-con disconnect======
Result: Abort.
Packet: OSMO_FW_V01.04.01.80.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:08 remo-con disconnect======
Result: Abort.
========== 2015.12.26 11:26:16 =====================
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
========== 2014.01.01 00:00:07 remo-con disconnect======
Result: Abort.
Result: Abort.
Packet: OSMO_FW_V01.06.02.10.bin
Upgrading ...
Result: Success.
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the device.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
The current firmware does not support downgrade. Use a different version of firmware to downgrade the target version.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
========== 2014.01.01 00:00:05 remo-con disconnect======
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
