Result: Success.
========== 2015.06.24 10:31:20 =====================
Packet: P3X_FW_V01.02.0006.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2015.06.24 10:36:11 =====================
Result: Abort.
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3X_FW_V01.04.0010.bin
Upgrading ...
Result: Success.
========== 2015.09.26 16:59:08 =====================
Packet: P3X_FW_V01.03.0020.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:13 remo-con disconnect======
Packet: P3X_FW_V01.08.0080.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2014.01.01 00:00:11 remo-con disconnect======
Result: Failed.
Packet: P3X_FW_V01.07.0060.bin
Result: Failed.
========== 2016.05.20 10:11:15 =====================
Result: Failed.
========== 2016.05.20 10:53:02 =====================
Result: Failed.
Result: Failed.
Result: Failed.
========== 2014.01.01 00:00:14 remo-con disconnect======
Result: Failed.
========== 2016.05.20 11:07:03 =====================
Result: Failed.
========== 2016.05.20 11:30:12 =====================
Upgrading ...
Result: Failed.
========== 2016.05.20 11:33:58 =====================
Result: Failed.
Upgrading ...
Result: Failed.
