悟1升级最新固件失败,求解。升级前连过OSMO,附升级文件
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2014.01.01 00:00:06 remo-con disconnect======
Packet: WM610_FW_V01.09.01.10.bin
Result: Failed.
Result: Failed.
Result: Failed.
========== 2014.01.01 00:00:05 remo-con disconnect======
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the device.
========== 2016.06.30 22:28:32 =====================
Result: Abort.
Result: Abort.
========== 2016.06.30 22:42:24 =====================
Result: Failed.
Result: Failed.
Result: Abort.
========== 2016.06.30 22:59:02 =====================
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
坐等解答,急!
