大疆社区
大疆社区
I'm K
大疆社区
已累计飞行 0 米
5 条评论
最新
最早
大疆社区
大疆社区
已累计飞行 131755 米
您说的情况应该是升级失败后的提示,您有没有试着再次升级呢? 先格式化SD卡,再下载最新的固件进行升级,具体方法可以看看这个视频: https://www.skypixel.com/videos/ ... 3-870b-5f64162d9b7c
2016-10-31
大疆社区
已累计飞行 0 米
好的谢谢,以下是升级结果txt: 但是完全没法升级成功,现在连app也连不上了 Result: Success. ========== 2014.01.01 00:00:08 remo-con disconnect====== Packet: WM610_FW_V01.09.01.30.bin Upgrading ... Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:08 remo-con disconnect====== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:09 remo-con disconnect====== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:09 remo-con disconnect====== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:09 remo-con disconnect====== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:08 remo-con disconnect====== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:08 remo-con disconnect====== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:08 remo-con disconnect====== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:09 remo-con disconnect====== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:09 remo-con disconnect====== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:08 remo-con disconnect====== Packet: WM610_FW_V01.08.01.00.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:09 remo-con disconnect====== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:07 remo-con disconnect====== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2016.08.23 11:19:34 ===================== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2016.08.23 11:32:56 ===================== Packet: WM610_FW_V01.09.01.30.bin ========== 2014.01.01 00:00:06 remo-con disconnect====== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:06 remo-con disconnect====== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:06 remo-con disconnect====== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2016.08.23 19:10:56 ===================== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2016.08.24 12:58:12 ===================== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2016.08.24 13:11:30 ===================== Packet: WM610_FW_V01.09.01.30.bin ========== 2016.08.25 11:51:12 ===================== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2016.08.25 11:55:09 ===================== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2016.08.25 16:21:27 ===================== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2016.08.25 16:23:05 ===================== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:07 remo-con disconnect====== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2016.09.19 19:34:08 ===================== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:07 remo-con disconnect====== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:06 remo-con disconnect====== Packet: WM610_FW_V01.03.00.00.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:07 remo-con disconnect====== Packet: WM610_FW_V01.08.01.00.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:07 remo-con disconnect====== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:06 remo-con disconnect====== Packet: WM610_FW_V01.09.01.30.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again.
2016-10-31
大疆社区
已累计飞行 131755 米
您在升级之前有没有格式化一下sd卡呢? 您可以把升级后的log文件传上来我看看
2016-10-30
大疆社区
已累计飞行 0 米
上午我把读卡器也换了,还是无法解决…操作完全按官网视频教程步骤
2016-10-30
大疆社区
已累计飞行 0 米
同样遇到过这种情况,最后是换了读卡器解决的问题。
2016-10-29
暂无更多评论
