请选择 进入手机版 | 继续访问电脑版
精灵3P 升级一直不成功,黄灯一直闪烁
手机看帖 2 771
不升级不给用,1.11的固件升级包
无语了
Result: Success.
========== 2014.01.01 00:00:13 remo-con disconnect======
Packet: P3X_FW_V01.03.0020.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
Upgrading ...
Result: Success.
========== 2015.09.05 09:07:50 =====================
Result: Abort.
========== 2015.09.05 09:43:24 =====================
Result: Abort.
Packet: P3X_FW_V01.04.0010.bin
Upgrading ...
Result: Success.
Result: Abort.
========== 2015.09.20 09:55:19 =====================
Result: Abort.
========== 2015.10.05 16:47:51 =====================
Result: Abort.
Packet: P3X_FW_V01.09.0060.bin
Upgrading ...
Result: Success.
========== 2016.11.27 19:36:50 =====================
Result: Abort.
========== 2016.11.28 09:49:50 =====================
Upgrading ...
Result: Success.
========== 2016.11.28 11:56:32 =====================
Result: Abort.
========== 2016.11.28 12:18:57 =====================
Result: Abort.
Packet: P3X_FW_V01.10.0090.bin
Upgrading ...
Result: Success.
========== 2017.04.07 19:47:38 =====================
Result: Abort.
========== 2017.04.07 22:17:10 =====================
Result: Abort.
========== 2017.04.08 09:27:52 =====================
Result: Abort.
========== 2017.04.08 10:32:49 =====================
Result: Abort.
========== 2017.04.08 10:52:10 =====================
Result: Abort.
========== 2017.06.12 11:05:40 =====================
Upgrading ...
Result: Success.
========== 2017.06.12 14:58:03 =====================
Result: Abort.
========== 2017.06.12 15:16:42 =====================
Result: Abort.
========== 2017.06.12 15:18:40 =====================
Result: Abort.
========== 2014.01.01 00:00:11 remo-con disconnect======
Packet: P3X_FW_V01.11.0020.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:12 remo-con disconnect======
Result: Abort.
Result: Abort.
Upgrading ...
Result: Success.
Result: Abort.
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
楼主   2017-8-22 2#
每次给这么长一串反馈
春媚  超级版主 2017-8-22 3#
楼主您好,黄灯闪烁说明是没有连接遥控器哦,是正常现象,查看您的升级结果文件,前面是已经升级成功了哦,建议您打开遥控器与飞行器,进入APP-进入相机-通用设置-关于选项 查看一下固件版本,方便的话可以上传截图,我们帮您看看;P3P固件升级教学视频如下,您可根据视频的步骤判断升级是否成功。
