大疆社区
大疆社区
1083664628.qq
大疆社区
已累计飞行 70019 米
6 条评论
最新
最早
大疆社区
大疆社区
已累计飞行 131755 米
您重置一下相机参数,看看情况如何,如果还有问题,请截图app界面我看看
2017-9-15
大疆社区
已累计飞行 0 米
是用手机直接给悟升级的吗?我昨天也遇到了这样的问题,手机给它升级结果影像系统模块会有问题。后来用电脑DJI Assistant 2软件直接给它再升级一次就好了,完美解决
2017-9-14
大疆社区
已累计飞行 70019 米
========== 2015.11.18 19:54:11 ===================== Packet: WM610_FW_V01.04.00.10_FACT.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2015.11.18 20:11:05 ===================== Packet: WM610_FW_V01.04.00.10_FACT.bin Result: Abort. The firmware on the SD card is identical to or older than the current firmware on the aircraft. ========== 2017.07.11 21:32:15 ===================== Packet: WM610_FW_V01.11.01.50.bin Upgrading ... Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:07 remo-con disconnect====== Packet: WM610_FW_V01.11.01.50.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2017.07.11 22:02:29 ===================== Packet: WM610_FW_V01.11.01.50.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:06 remo-con disconnect====== Packet: WM610_FW_V01.11.01.50.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:08 remo-con disconnect====== Packet: WM610_FW_V01.11.01.50.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2017.07.11 22:25:58 ===================== Packet: WM610_FW_V01.11.01.50.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:07 remo-con disconnect====== Packet: WM610_FW_V01.11.01.50.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:07 remo-con disconnect====== Packet: WM610_FW_V01.11.01.50.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2017.09.11 17:32:10 ===================== Packet: WM610_FW_V01.11.01.50.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:06 remo-con disconnect====== Packet: WM610_FW_V01.11.01.50.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2017.09.11 17:48:57 ===================== Packet: WM610_FW_V01.11.01.50.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2017.09.11 17:54:03 ===================== Packet: WM610_FW_V01.11.01.50.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2017.09.11 17:55:22 ===================== Packet: WM610_FW_V01.11.01.50.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:06 remo-con disconnect====== Packet: WM610_FW_V01.11.01.50.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2017.09.12 18:57:06 ===================== Packet: WM610_FW_V01.11.01.50.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:06 remo-con disconnect====== Packet: WM610_FW_V01.11.01.50.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2017.09.12 23:37:18 ===================== Packet: WM610_FW_V01.11.01.50.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:06 remo-con disconnect====== Packet: WM610_FW_V01.11.01.50.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:10 remo-con disconnect====== Packet: WM610_FW_V01.11.01.50.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:07 remo-con disconnect====== Packet: WM610_FW_V01.11.01.50.bin Upgrading ... Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:07 remo-con disconnect====== Packet: WM610_FW_V01.11.01.50.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:07 remo-con disconnect====== Packet: WM610_FW_V01.11.01.50.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:07 remo-con disconnect====== Packet: WM610_FW_V01.11.01.50.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again. ========== 2014.01.01 00:00:08 remo-con disconnect====== Packet: WM610_FW_V01.11.01.50.bin Result: Failed. Reboot the aircraft and try to upgrade the firmware again.
2017-9-14
大疆社区
已累计飞行 70019 米
2017-9-14
大疆社区
已累计飞行 70019 米
多次升级失败,能正常连接云台,但是画面漆黑,单独升级读取后无反应,升级失败, 尝试了如下匹配 1、用X3镜头挂到另一台悟,能正常连接控制,但画面漆黑 2、用X3镜头安装到OSMO手柄,一切正常 DJI GO软件最新版本,X3镜头升级了悟最新版本,但没成功,软件显示是最新版本。。。升级失败的文件怎么发给你?
2017-9-14
大疆社区
已累计飞行 131755 米
楼主,您好,请问您是多次升级还是失败吗?请格式化SD卡,重启飞行器,重新升级试试。 有没有尝试插拔一下云台排线位置看是否有松动,重新装一下云台呢? 建议您导出升级失败的log文件,帮您分析失败原因。
2017-9-13
暂无更多评论
