请选择 进入手机版 | 继续访问电脑版
DJI GO 4最新版是不是和Oreo存在兼容性问题?
手机看帖 8 326
不管是官网下载还是Google Play下载的4.2.20版,安装完以后打开都闪退,装回4.2.16又没事
一加5(A5000),H2OS 5.1.1,Android 8.1.0 (O_MR1)
logcat日志:
07-12 19:13:07.728 11021 11021 W zygote  : Using default instruction set features for ARM CPU variant (cortex-a9) using conservative defaults
07-12 19:13:07.737 11021 11034 I zygote  : The ClassLoaderContext is a special shared library.
07-12 19:13:07.743 11021 11021 I zygote  : The ClassLoaderContext is a special shared library.
07-12 19:13:07.800  3833  3833 D RecyclerViewWrapper: onWindowVisibilityChanged:8
07-12 19:13:07.815 11021 11021 W zygote  : Opening an oat file without a class loader. Are you using the deprecated DexFile APIs?
07-12 19:13:07.816 11021 11021 W zygote  : Skipping duplicate class check due to unsupported classloader
07-12 19:13:07.816 11021 11021 W zygote  : Opening an oat file without a class loader. Are you using the deprecated DexFile APIs?
07-12 19:13:07.819 11021 11021 W zygote  : Skipping duplicate class check due to unsupported classloader
07-12 19:13:07.954 11037 11037 W Zygote  : child_detach_binder close binder
07-12 19:13:07.969 11021 11021 F libc    : Fatal signal 11 (SIGSEGV), code 1, fault addr 0x10c in tid 11021 (dji.go.v4), pid 11021 (dji.go.v4)
07-12 19:13:07.988  3268  3358 D HeadsetStateMachine: Disconnected process message: 10, size: 0
07-12 19:13:07.994 11043 11043 I crash_dump32: obtaining output fd from tombstoned, type: kDebuggerdTombstone
07-12 19:13:07.994   980   980 I /system/bin/tombstoned: received crash request for pid 11021
07-12 19:13:07.995 11043 11043 I crash_dump32: performing dump of process 11021 (target tid = 11021)
07-12 19:13:07.995 11043 11043 F DEBUG   : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 19:13:07.995 11043 11043 F DEBUG   : Build fingerprint: 'OnePlus/OnePlus5/OnePlus5:8.1.0/OPM1.171019.011/05230242:user/release-keys'
07-12 19:13:07.995 11043 11043 F DEBUG   : Revision: '0'
07-12 19:13:07.995 11043 11043 F DEBUG   : ABI: 'arm'
07-12 19:13:07.995 11043 11043 F DEBUG   : pid: 11021, tid: 11021, name: dji.go.v4  >>> dji.go.v4 <<<
07-12 19:13:07.995 11043 11043 F DEBUG   : signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x10c
07-12 19:13:07.995 11043 11043 F DEBUG   : Cause: null pointer dereference
07-12 19:13:07.995 11043 11043 F DEBUG   :     r0 00000005  r1 00000006  r2 00000008  r3 00000000
07-12 19:13:07.995 11043 11043 F DEBUG   :     r4 ea5339f4  r5 00000000  r6 00000009  r7 00000003
07-12 19:13:07.995 11043 11043 F DEBUG   :     r8 fffadf24  r9 caf2cb01  sl 0000001b  fp caf62df0
07-12 19:13:07.995 11043 11043 F DEBUG   :     ip 00000004  sp fffadda8  lr 00000001  pc caf2ede4  cpsr 800d0030
07-12 19:13:07.999 11040 11040 W dex2oat : 'verify-none' is an obsolete compiler filter name that will be removed in future releases, please use 'assume-verified' instead.
07-12 19:13:07.999 11040 11040 W dex2oat : Using default instruction set features for ARM CPU variant (default) using conservative defaults
07-12 19:13:08.001 11040 11040 I dex2oat : /system/bin/dex2oat --compiler-filter=verify-none
07-12 19:13:08.020  2566  2566 D StatusBar: useDarkText:false, lockDarkText:false, useDarkTheme:true
07-12 19:13:08.051 11043 11043 F DEBUG   :
07-12 19:13:08.051 11043 11043 F DEBUG   : backtrace:
07-12 19:13:08.051 11043 11043 F DEBUG   :     #00 pc 00021de4  /data/app/dji.go.v4-CPPtOwqzw39phvD86xlMtA==/lib/arm/libDexHelper.so (p192C764E95AC152928EF9CB126B13F67+623)
07-12 19:13:08.051 11043 11043 F DEBUG   :     #01 pc 0001ff73  /data/app/dji.go.v4-CPPtOwqzw39phvD86xlMtA==/lib/arm/libDexHelper.so (p1FF4A913261A38513E7E92A00B9918C6+1034)
07-12 19:13:08.051 11043 11043 F DEBUG   :     #02 pc 0001b791  /data/app/dji.go.v4-CPPtOwqzw39phvD86xlMtA==/lib/arm/libDexHelper.so (_Z33pE450264C1142BA30A70A67454B537678I33pBDCCF89303907111188C054F80E2878AIPFvvEEJEEvT_DpOT0_+12)
07-12 19:13:08.051 11043 11043 F DEBUG   :     #03 pc 0001d963  /data/app/dji.go.v4-CPPtOwqzw39phvD86xlMtA==/lib/arm/libDexHelper.so (JNI_OnLoad+8602)
07-12 19:13:08.051 11043 11043 F DEBUG   :     #04 pc 0025773b  /system/lib/libart.so (art::JavaVMExt::LoadNativeLibrary(_JNIEnv*, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char>> const&, _jobject*, _jstring*, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char>>*)+1910)
07-12 19:13:08.051 11043 11043 F DEBUG   :     #05 pc 000031ab  /system/lib/libopenjdkjvm.so (JVM_NativeLoad+194)
07-12 19:13:08.051 11043 11043 F DEBUG   :     #06 pc 0025b4e9  /system/framework/arm/boot-core-oj.oat (offset 0x1ce000) (java.lang.Runtime.nativeLoad+160)
07-12 19:13:08.051 11043 11043 F DEBUG   :     #07 pc 0025aef3  /system/framework/arm/boot-core-oj.oat (offset 0x1ce000) (java.lang.Runtime.doLoad+170)
07-12 19:13:08.051 11043 11043 F DEBUG   :     #08 pc 0025cbe9  /system/framework/arm/boot-core-oj.oat (offset 0x1ce000) (java.lang.Runtime.loadLibrary0+816)
07-12 19:13:08.051 11043 11043 F DEBUG   :     #09 pc 00277209  /system/framework/arm/boot-core-oj.oat (offset 0x1ce000) (java.lang.System.loadLibrary+88)
07-12 19:13:08.051 11043 11043 F DEBUG   :     #10 pc 000ee575  /system/lib/libart.so (offset 0x31a000)
07-12 19:13:08.141   980   980 E /system/bin/tombstoned: Tombstone written to: /data/tombstones/tombstone_04
07-12 19:13:08.143  1410 11045 W ActivityManager:   Force finishing activity dji.go.v4/dji.pilot.main.activity.DJILauncherActivity
07-12 19:13:08.143  1410  2400 I BootReceiver: Copying /data/tombstones/tombstone_04 to DropBox (SYSTEM_TOMBSTONE)
07-12 19:13:08.134 11047 11047 W kworker/u16:5: type=1400 audit(0.0:430): avc: denied { execute_no_trans } for path="/system/bin/coredump.sh" dev="sde21" ino=592 scontext=u:r:kernel:s0 tcontext=u:object_r:core_dump_exec:s0 tclass=file permissive=0
07-12 19:13:08.146  1410  2397 I ActivityManager: Showing crash dialog for package dji.go.v4 u0
07-12 19:13:08.147  1410  2396 D RestartProcessManager: Duration is too short, ignore : 436 in dji.go.v4
07-12 19:13:08.150  3717  4319 D OPReportService: addMonitorFolder onEvent path=data_app_native_crash@2018-07-12-19_13_08_149.txt, event:128
07-12 19:13:08.158  3717  4319 D OPReportService: addMonitorFolder onEvent path=SYSTEM_TOMBSTONE@2018-07-12-19_13_08_158.txt.gz, event:128
07-12 19:13:08.166  1410  2799 I ActivityManager: Process dji.go.v4 (pid 11021) has died: vis  +99TOP
07-12 19:13:08.166  1410  2799 D ActivityManager: Process dji.go.v4 has 0 services
07-12 19:13:08.166  1410  2398 W zygote64: kill(-11021, 9) failed: No such process
07-12 19:13:08.166   706   706 I Zygote  : Process 11021 exited due to signal (11)
07-12 19:13:08.172  1410  2398 W zygote64: kill(-11021, 9) failed: No such process
07-12 19:13:08.176  2566  2566 D StatusBar: useDarkText:false, lockDarkText:false, useDarkTheme:true
07-12 19:13:08.178  1410  2398 W zygote64: kill(-11021, 9) failed: No such process
07-12 19:13:08.178  1410  2398 I zygote64: Successfully killed process cgroup uid 10121 pid 11021 in 11ms
清風  Osmo Mobile 2认证用户 7-12 21:54 2#
我也是一加5手机
小贼  Phantom 4 Pro V2.0认证用户 7-13 06:39 3#
4.2.20这个版本问题很大。比如图传花屏。。。所以只好用4.2.16
骨子里的骄傲  Osmo Mobile 2认证用户 7-13 15:49 4#
测试列表好像没有这个型号:
iOS 版本 v4.2.12.
需要 iOS 9.0 或更高版本。兼容 iPhone 5s, iPhone SE, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s Plus, iPhone 7, iPhone 7 Plus, iPhone 8, iPhone 8 Plus, iPhone X, iPad Air, iPad Air Wi-Fi + Cellular, iPad Air 2, iPad Air 2 Wi-Fi + Cellular, iPad mini 4 and iPad mini 4 Wi-Fi + Cellular. 此 App 已针对 iPhone 8、 iPhone 8 Plus优化 。
Android 版本v4.2.8.
需要 Android 4.4.0 或更高版本。兼容Samsung S8, Samsung S7 edge, Samsung S7, Samsung S6, Samsung S5, Samsung NOTE4, Samsung tabs 705c, Ascend Mate 9, Ascend Mate 7, Huawei Honor 8, Huawei P8 Max, Vivo X7, Xiaomi 5, Google Nexus 6p, Nexus 9, Google Nexus 7 II, LG V20。
*支持的设备列表会持续更新和增加。
夏清  超级版主 7-13 17:23 5#
楼主您好,非常抱歉给您带来的不便。您提供的信息我们已反馈给相关工作人员进行查看。
另外,如4楼所说,也建议您尝试使用兼容性列表上的移动设备哦,手机的兼容性或者性能等也会影响APP的使用的。
后续如有其它任何问题,欢迎您随时联系我们。
微信关注“大疆服务”,获取最全面的大疆产品教学视频,及时的售后服务动态,最实用的飞行指引和专业的技术支持,都在这里
楼主  Mavic Pro认证用户 7-17 12:07 6#
夏清超级版主2018-7-13 17:23
问题是同样使用环境下用4.2.16一切正常,4.2.20和4.2.21却直接闪退,卸载之后安装4.2.16并运行,出现splash以后会弹出权限请求通知。
卸载后安装4.2.20和4.2.21并运行,出现splash后直接闪退,看日志感觉是开发组调整了底层运行库的运行依赖造成对资源包校验失败造成的。
感觉你们DJI的APP开发组也该拿几个程序员出来斩头祭天了,越更新毛病越多,QC都辞职跑路了么
夏清  超级版主 7-17 14:43 7#
AbraxasViMavic Pro2018-7-17 12:07
楼主您好,非常抱歉给您带来的不便,麻烦您通过这个链接:https://adhoc.djiservice.org/sho ... -2-21-test-zv-mdnq2
重新下载安装试下,如有任何问题,欢迎您随时联系我们。
楼主  Mavic Pro认证用户 7-22 11:45 8#
夏清超级版主2018-7-17 14:43
楼主您好,非常抱歉给您带来的不便,麻烦您通过这个链接:https://adhoc.djiservice.org/show_app/AndroidApp/s-dji-go-4-4-2-21-test-zv-mdnq2
这个测试版又正常了。搞得现在不敢随意更新了
夏清  超级版主 7-24 15:56 9#
AbraxasViMavic Pro2018-7-22 11:45
好的,感谢您的回复,后续如有任何其他问题,欢迎您随时联系我们。
已累计飞行16610米
收藏 点赞 评论
