我的悟1pro 从买了一直没有用过,放在家里,今天拿出来飞飞呢,遥控器开机,机身开机,遥控器一直提示无信号,就是遥控器与机身机不上,我在论坛搜索一遍说是遥控器重新对频试试, 试了也没用!
最后我想着是不是机身的版本与遥控器对不上原因呀(遥控上没有提示机身升级的事),我就在大疆网上下载了一个悟1的,没有考虑到 我的这个是 pro x5,就升级了,10分钟后相机机就开始连续蜂鸣声叫个不停,我就关了机,重新打开,遥控器与主机连上了,,可是相机是黑屏(开机相册也自检,左右摇头的),最后在论坛里查到 说是要对应固件升级,我这个时候才发现 我这刚才用的升级固件版本是 悟1 的,,而我的是 悟1 pro x5版,,我又重新下载的 x5版 ,升级,相册还是峰鸣不断,
以上就是我升级遇到的问题,,现在相机没办法用,,求助官方 这个怎么解决呢??
========== 2015.11.20 19:24:23 =====================
Packet: WM610_FC550_FW_V01.00.00.30_1012.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2014.01.01 00:00:11 remo-con disconnect======
Packet: WM610_FC550_FW_V01.01.00.40_FCam.bin
Upgrading ...
Result: Success.
Result: Abort.
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: WM610_FC550_FW_V01.11.01.50.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2019.03.02 20:40:41 =====================
Result: Failed.
========== 2019.03.02 20:56:18 =====================
Result: Failed.
========== 2019.03.02 21:24:53 =====================
Result: Failed.
========== 2014.01.01 00:00:06 remo-con disconnect======
Result: Failed.
========== 2014.01.01 00:00:08 remo-con disconnect======
Result: Failed.
Result: Failed.
========== 2019.03.02 21:42:06 =====================
Result: Failed.
