请选择 进入手机版 | 继续访问电脑版
关于安卓手机fcc的开启,这是我在国外论坛找到文档
手机看帖 1 2770
        首先说明一下,大疆作为一个工程师文化很强的企业,技术实力是毋庸置疑的。之所以在国内限制fcc mode这种黑科技,完全是出于守法的原因,这也就是为什么最先进的技术永远先给军事目的使用的道理,技术是一把双刃剑,强大的同时也威胁着我们的安全,因此生性谨慎的我是绝对不会去尝试这些东西的。
       其次,我也只是放出来一小段破解过程。以及一些图片,我自己没去测试过,也绝对不会去测试,更不会把里面的app放给大家。
      以下是说明文档,大家纯当看戏玩。图片视屏以及文档里提到的程式不提供了,不勾引大家。
      天空千万里,安全一公里。航拍把祸闯,亲人两行泪。
MAVIC2, How to use FCC transmission mode in Europe (max distance 8km) instead of the European CE mode (<1km..)
In Europe, the American FCC (high power) mode is not allowed but this mode (FCC) has 4x more power than the European CE mode.
So it allows the drone to travel much longer without losing contact with the Remote Control.
How to do it:
0) You must have the djiGO4 latest version (v4.33 or any other) already installed and logged in your Account and synchronized with the Drone before.
1) install the android app"dji go 4 red (force FCC) .apk" that comes with this file.
2) call up the program "DJI Go red" you have just installed (red DJI icon). Login with your account.
   NOTE: this is NOT a modified version of DJIGO4 it it ORIGINAL DJIgo4 V4.1.3 older version where the config files still were unencrypted.
         Thats why we use this version. it is not a virus, scams,etc. Youcan use original v4.1.3 if you want. Just have to put another name in it.
   This version will create a configuration directory on Android that we need.
NOTE: After that I NEVER let the Internet ON when using the drone. I dont want DJI to know I am changing the parameters and possibly cancelling my account..
      I NEVER LET internet enabled when using any version of DJI GO...
      It still works fine with internet ON but I prefer it off all the time.
牋3) Now Close the DJIGO RED program. He has already created the necessary definitions.
4) Copy the file ".DJI.configs" to the directory "/android/data/dji.go.boost/files" (this is the directory of DJI Go4 changed to allow FCC.) We have just copied the FCC definitions to force it)
5) Copy the file ".DJI.configs" to the directory "/android/data/dji.go.4/files" (this is the normal DJI Go4 directory)
6) Now Turn on the Remote Control and the Drone and let the RC pair with the Drone.
   call now  DJI GO RED. 牋?
   Now choose the DJI MAVIC PRO drone and enter the Connect to the Aircraft mode.
es, I know, mavic 2 does not appear, no problem .. Choose the Mavic PRO drone, it's just to enable FCC mode ..
   DO NOT turn off the drone and remote control.. If you do so it will loose the FCC status. Leave the drone and RC running.
7) Exit now from DJIgo RED. At this moment it is already in FCC mode !! ..
8) Now call the normal original DJIGO4. let yourself connect with the drone. It should be in FCC mode !! ..
To check if you are in FCC mode go to "Options-> HDD -> Image Transmission Settings" and check that the 1 km line is above -90 dB
if it's because it's in FCC mode !!
See the photo and video that comes with this file to see how.
Good flights in FCC mode !!
pfeijao
航拍自由  Mavic Pro铂金版认证用户 2019-3-11 2#
有關FCC文章視頻网上大把,開FCC只是每人的个人喜愛而已,其關鍵是能保証減低飛机失聯失控的機率而已,守法也是每人應守的義務,不是説你拿著菜刀就會劈人的......
已累计飞行3799米
收藏 点赞 评论
