请选择 进入手机版 | 继续访问电脑版
Tello 与 Arduino
手机看帖 1 4871
https://github.com/akshayvernekar/telloArduino
telloArduino
This is a Arduino library for controlling DJI tello through ESP32
This library controls the tello by sending commands via UDP as mentioned in the SDK documenatation in below link https://www.ryzerobotics.com/tello/downloads
How to use the library ?
To download , enter "git clone https://github.com/akshayvernekar/telloArduino.git" in the terminal(Mac/linux) or command prompt(Windows) or click the DOWNLOAD ZIP button .
Place the "tello" folder in your arduinosketchfolder/libraries/ folder. You may need to create the libraries subfolder if its your first library. Restart the IDE.
In your Arduino Playground application go to Sketch > Include Library > choose "tello" from Contributed Libraries section to include this library in your skecth. Go to examples\tello_example.ino for example usage .
API usage
// 1. Create the object
Tello tello
// 2. Initialise the Object after your device gets the IP address
tello.init()
// 3 .Once the object is initalised you can use the various fubnctions to send commands to tello.
Using the example:
Replace the 'networkName' and 'networkPswd' with the SSID and password of your drone .
webmarste   2019-11-22 2#
这个是啥编程软件?
已累计飞行257980米
