大疆社区
大疆社区
固件升级连续失败, device not detected
no1caresme
SD卡里只有一个升级文件,开始正常云台声音:滴、滴、滴........,2分钟后,云台声音变成滴--滴、滴,滴--滴、滴......,2分钟后,声音变成“滴”一个长声音不变,相机灯呈红色长亮。
我尝试了不同的bin文件,也格式化过SD卡,也把电池拔出冷却15分钟,各种办法始终都是失败的。
========== 2014.01.01 00:00:13 remo-con disconnect======
Packet: P3X_FW_V01.04.0010.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Upgrading ...
Result: Failed.
========== 2015.09.08 17:03:26 =====================
Result: Failed.
Result: Failed.
Result: Failed.
Packet: P3X_FW_V01.03.0020.bin
Result: Failed.
Result: Failed.
========== 2015.09.08 17:44:53 =====================
Result: Failed.
========== 2015.09.08 17:48:04 =====================
Result: Failed.
========== 2014.01.01 00:00:14 remo-con disconnect======
Packet: P3X_FW_V01.04.0005.bin
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
========== 2015.09.08 18:39:54 =====================
Result: Failed.
========== 2015.09.08 19:13:29 =====================
Result: Failed.
Result: Failed.
========== 2014.01.01 00:00:15 remo-con disconnect======
Result: Failed.
========== 2015.09.08 19:41:04 =====================
Result: Failed.
========== 2015.09.08 19:42:43 =====================
Result: Failed.
Packet: P3X_FW_V01.01.0009.bin
Result: Failed.
========== 2015.09.08 20:17:53 =====================
Result: Failed.
Packet: P3X_FW_V01.01.1003.bin
Result: Corrupted.
Firmware bin file is corrupted, download it again from the DJI offical website.
Result: Corrupted.
Result: Failed.
========== 2015.09.08 21:05:34 =====================
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
log文件如下:
[00012239][01 00] Firmware upgrade finished successfully.
[00012348]Done.
[00012448]Packet [C:\P3X_FW_V01.04.0010.bin] resumed, card sn [0x70ce1c3a].
[00012587]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012723]Version checking[2]...
[00012874][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00013009][03 06][00] v2.1.9.1 -> v2.3.0.13 need upgrade.
[00013118][04 00][00] v1.36.0.0 -> v1.41.0.0 need upgrade.
[00013224][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013395][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00013470][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013549][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013626][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013705][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013845][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013919][17 00][00] v1.1.1.2 -> v1.1.1.7 need upgrade.
[00014020][17 01][00] v1.0.2.4 -> v1.0.2.7 need upgrade.
[00014064][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00014104][01 00][05] v1.23.3419 -> v1.23.3419
[00014137][01 01][00] v1.5.2735 -> v1.23.3419 need upgrade
[00014178][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00014211]Done.
[00014260]Firmware upgrading[2]...
[00014406][01 01] Firmware upgrade start...
[00044664][01 01] Firmware upgrade finished successfully.
[00045522][08 00] Firmware upgrade start...
[00014502]========== remo-con disconnect. boot(15) ============
[00014537]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x70ce1c3a].
[00014571]Packet upgrade start...
[00014616]Packet checking...
[00014650]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014713]Done.
[00014746]Version checking[1]...
[00014802][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00014862][03 06][00] v2.1.9.1 -> v2.3.0.13 need upgrade.
[00014901][04 00][00] v1.36.0.0 -> v1.41.0.0 need upgrade.
[00014952][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015042][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00015113][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00015202][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00015377][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00015453][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00027991][15 00][00] device not detected.
[00028067][17 00][00] v1.1.1.2 -> v1.1.1.7 need upgrade.
[00028187][17 01][00] v1.0.2.4 -> v1.0.2.7 need upgrade.
[00028272][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00028309][01 00][00] v1.23.3419 -> v1.23.3419
[00028343][01 01][00] v1.23.3419 -> v1.23.3419
[00040878][08 00][00] device not detected.
[00040909]Done.
[00042949]Waiting for user confirm...
[00052981]Timeout, start upgrade automatically.
[00053048]Firmware upgrading[1]...
[00053100][12 00] Firmware upgrade start...
[00122113][12 00] Firmware upgrade finished successfully.
[00122166][12 01] Firmware upgrade start...
[00184601][12 01] Firmware upgrade finished successfully.
[00184650][12 02] Firmware upgrade start...
[00250329][12 02] Firmware upgrade finished successfully.
[00250379][12 03] Firmware upgrade start...
[00315923][12 03] Firmware upgrade finished successfully.
[00315979][17 00] Firmware upgrade start...
[00417189][17 00] Firmware upgrade finished successfully.
[00417236][17 01] Firmware upgrade start...
[00488513][17 01] Firmware upgrade finished successfully.
[00488565][11 00] Firmware upgrade start...
[00537706][11 00] Firmware upgrade finished successfully.
[00537754][03 05] Firmware upgrade start...
[00608080][03 05] Firmware upgrade finished successfully.
[00608320][03 06] Firmware upgrade start...
[00949463][03 06] Firmware upgrade finished successfully.
[00952090][19 00] Firmware upgrade start...
[00962430][19 00] stop streaming timeout, continue upgrade.
[01106807][19 00] start streaming timeout, continue upgrade.
[01136849][19 00] Firmware upgrade finished successfully.
[01136915][04 00] Firmware upgrade start...
[01195405][04 00] Firmware upgrade finished successfully.
[01195446]Done.
[01195478]Version checking[2]...
[01195558][03 05][05] v34.2.0.9 -> v34.2.0.9
[01195718][03 06][05] v2.3.0.13 -> v2.3.0.13
[01195760][04 00][05] v1.41.0.0 -> v1.41.0.0
[01195826][09 00][00] v1.7.0.3 -> v1.7.0.3
[01195939][11 00][05] v1.7.0.0 -> v1.7.0.0
[01196007][12 00][05] v1.10.0.0 -> v1.10.0.0
[01196092][12 01][05] v1.10.0.0 -> v1.10.0.0
[01196171][12 02][05] v1.10.0.0 -> v1.10.0.0
[01196249][12 03][05] v1.10.0.0 -> v1.10.0.0
[01208791][15 00][00] device not detected.
[01208862][17 00][05] v1.1.1.7 -> v1.1.1.7
[01208986][17 01][05] v1.0.2.7 -> v1.0.2.7
[01209047][19 00][05] v1.0.8.96 -> v1.0.8.96
[01209082][01 00][00] v1.23.3419 -> v1.23.3419
[01209121][01 01][00] v1.23.3419 -> v1.23.3419
[01221658][08 00][00] device not detected.
[01221692]Packet upgrade failed at version checking.
[00014446]========== remo-con disconnect. boot(15) ============
[00014483]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x70ce1c3a].
[00014517]Packet upgrade start...
[00014555]Packet checking...
[00014596]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014662]Done.
[00014697]Version checking[1]...
[00014757][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014817][03 06][00] v2.3.0.13 -> v2.3.0.13
[00014856][04 00][00] v1.41.0.0 -> v1.41.0.0
[00014906][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015036][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00015110][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015186][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015277][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015356][12 03][00] v1.10.0.0 -> v1.10.0.0
[00027896][15 00][00] device not detected.
[00027986][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028106][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028166][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028201][01 00][00] v1.23.3419 -> v1.23.3419
[00028250][01 01][00] v1.23.3419 -> v1.23.3419
[00040790][08 00][00] device not detected.
[00040824]Done.
[00042858]Waiting for user confirm...
[00052892]Timeout, start upgrade automatically.
[00052969]Firmware upgrading[1]...
[00053015][11 00] Firmware upgrade start...
[00103736][11 00] Firmware upgrade finished successfully.
[00103775]Done.
[00103812]Version checking[2]...
[00103882][03 05][00] v34.2.0.9 -> v34.2.0.9
[00103942][03 06][00] v2.3.0.13 -> v2.3.0.13
[00103981][04 00][00] v1.41.0.0 -> v1.41.0.0
[00104051][09 00][00] v1.7.0.3 -> v1.7.0.3
[00104161][11 00][05] v1.7.0.0 -> v1.7.0.0
[00104257][12 00][00] v1.10.0.0 -> v1.10.0.0
[00104335][12 01][00] v1.10.0.0 -> v1.10.0.0
[00104412][12 02][00] v1.10.0.0 -> v1.10.0.0
[00104486][12 03][00] v1.10.0.0 -> v1.10.0.0
[00117027][15 00][00] device not detected.
[00117091][17 00][00] v1.1.1.7 -> v1.1.1.7
[00117206][17 01][00] v1.0.2.7 -> v1.0.2.7
[00117291][19 00][00] v1.0.8.96 -> v1.0.8.96
[00117327][01 00][00] v1.23.3419 -> v1.23.3419
[00117368][01 01][00] v1.23.3419 -> v1.23.3419
[00129903][08 00][00] device not detected.
[00129938]Packet upgrade failed at version checking.
[00014630]========== 2015.09.08 17:03:27. boot(15) ============
[00014667]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x70ce1c3a].
[00014704]Packet upgrade start...
[00014749]Packet checking...
[00014788]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014854]Done.
[00014891]Version checking[1]...
[00014964][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015049][03 06][00] v2.3.0.13 -> v2.3.0.13
[00015095][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015148][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015265][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015358][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015439][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015512][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015592][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028129][15 00][00] device not detected.
[00028212][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028356][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028413][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028457][01 00][00] v1.23.3419 -> v1.23.3419
[00028493][01 01][00] v1.23.3419 -> v1.23.3419
[00041035][08 00][00] device not detected.
[00041069]Packet upgrade failed at version checking.
[00014629]========== remo-con disconnect. boot(15) ============
[00014666]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x70ce1c3a].
[00014705]Packet upgrade start...
[00014752]Packet checking...
[00014791]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014858]Done.
[00014893]Version checking[1]...
[00015024][03 06][00] v2.3.0.13 -> v2.3.0.13
[00015066][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015133][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015248][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015337][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015417][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015504][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015583][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028122][15 00][00] device not detected.
[00028193][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028333][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028393][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028436][01 00][00] v1.23.3419 -> v1.23.3419
[00028472][01 01][00] v1.23.3419 -> v1.23.3419
[00041008][08 00][00] device not detected.
[00041046]Packet upgrade failed at version checking.
[00014633]========== remo-con disconnect. boot(15) ============
[00014670]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x70ce1c3a].
[00014709]Packet upgrade start...
[00014754]Packet checking...
[00014793]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014862]Done.
[00014899]Version checking[1]...
[00014984][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015065][03 06][00] v2.3.0.13 -> v2.3.0.13
[00015110][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015163][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015284][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015388][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015492][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015589][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015684][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028227][15 00][00] device not detected.
[00028309][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028435][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028484][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028594][01 00][00] v1.23.3419 -> v1.23.3419
[00028641][01 01][00] v1.23.3419 -> v1.23.3419
[00041179][08 00][00] device not detected.
[00041218]Packet upgrade failed at version checking.
[00014639]========== remo-con disconnect. boot(15) ============
[00014678]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x70ce1c3a].
[00014717]Packet upgrade start...
[00014764]Packet checking...
[00014800]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014870]Done.
[00014907]Version checking[1]...
[00014980][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015061][03 06][00] v2.3.0.13 -> v2.2.6.19
[00015112][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015165][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015281][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015381][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015474][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015581][12 02][00] v1.10.0.0 -> v1.8.0.0
[00015675][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028311][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028436][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028486][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028524][01 00][00] v1.23.3419 -> v1.23.3419
[00028564][01 01][00] v1.23.3419 -> v1.23.3419
[00041114][08 00][00] device not detected.
[00041155]Packet upgrade failed at version checking.
[00014650]========== remo-con disconnect. boot(15) ============
[00014686]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x70ce1c3a].
[00014725]Packet upgrade start...
[00014772]Packet checking...
[00014814]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014883]Done.
[00014925]Version checking[1]...
[00014987][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015067][03 06][00] v2.3.0.13 -> v2.2.6.19
[00015117][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015176][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015307][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015406][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015506][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015681][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028311][15 00][00] device not detected.
[00028402][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028542][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028602][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028642][01 00][00] v1.23.3419 -> v1.23.3419
[00028681][01 01][00] v1.23.3419 -> v1.23.3419
[00041221][08 00][00] device not detected.
[00041260]Packet upgrade failed at version checking.
[00014661]========== 2015.09.08 17:44:54. boot(15) ============
[00014700]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x70ce1c3a].
[00014739]Packet upgrade start...
[00014789]Packet checking...
[00014829]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014898]Done.
[00014947]Version checking[1]...
[00015009][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015069][03 06][00] v2.3.0.13 -> v2.2.6.19
[00015119][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015178][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015289][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015363][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015463][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015543][12 02][00] v1.10.0.0 -> v1.8.0.0
[00015618][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028159][15 00][00] device not detected.
[00028238][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028403][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028446][01 00][00] v1.23.3419 -> v1.23.3419
[00028484][01 01][00] v1.23.3419 -> v1.23.3419
[00041025][08 00][00] device not detected.
[00041063]Packet upgrade failed at version checking.
[00015190]========== 2015.09.08 17:48:05. boot(15) ============
[00015228]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x70ce1c3a].
[00015272]Packet upgrade start...
[00015315]Packet checking...
[00015355]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015424]Done.
[00015460]Version checking[1]...
[00015553][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015630][03 06][00] v2.3.0.13 -> v2.2.6.19
[00015677][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015728][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015853][11 00][00] v1.7.0.0 -> v1.7.0.0
[00016017][12 00][00] v1.10.0.0 -> v1.8.0.0
[00016117][12 01][00] v1.10.0.0 -> v1.8.0.0
[00016197][12 02][00] v1.10.0.0 -> v1.8.0.0
[00016317][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028857][15 00][00] device not detected.
[00028957][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029077][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029148][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029187][01 00][00] v1.23.3419 -> v1.23.3419
[00029233][01 01][00] v1.23.3419 -> v1.23.3419
[00041776][08 00][00] device not detected.
[00041817]Packet upgrade failed at version checking.
[00014667]========== remo-con disconnect. boot(15) ============
[00014709]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x70ce1c3a].
[00014751]Packet upgrade start...
[00014796]Packet checking...
[00014839]Packet vlink 01.04.0005 <-> 01.03.0020.
[00014910]Done.
[00014952]Version checking[1]...
[00015018][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015097][03 06][00] v2.3.0.13 -> v2.3.0.10
[00015144][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015201][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015338][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015431][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015586][12 02][00] v1.10.0.0 -> v1.8.0.0
[00015671][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028211][15 00][00] device not detected.
[00028327][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028446][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028501][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028542][01 00][00] v1.23.3419 -> v1.23.3419
[00028580][01 01][00] v1.23.3419 -> v1.23.3419
[00041132][08 00][00] device not detected.
[00041173]Packet upgrade failed at version checking.
[00014665]========== remo-con disconnect. boot(15) ============
[00014705]Packet [C:\P3X_FW_V01.04.0005.bin] detected, card sn [0x70ce1c3a].
[00014747]Packet upgrade start...
[00014791]Packet checking...
[00014835]Packet vlink 01.04.0005 <-> 01.03.0020.
[00014906]Done.
[00014955]Version checking[1]...
[00015118][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015198][03 06][00] v2.3.0.13 -> v2.3.0.10
[00015261][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015322][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015440][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015532][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015612][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015712][12 02][00] v1.10.0.0 -> v1.8.0.0
[00015812][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028356][15 00][00] device not detected.
[00028447][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028578][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028663][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028706][01 00][00] v1.23.3419 -> v1.23.3419
[00028748][01 01][00] v1.23.3419 -> v1.23.3419
[00041297][08 00][00] device not detected.
[00041337]Packet upgrade failed at version checking.
[00014770]========== remo-con disconnect. boot(15) ============
[00014804]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x92ac838d].
[00014839]Packet upgrade start...
[00014875]Packet checking...
[00014908]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014977]Done.
[00015008]Version checking[1]...
[00015068][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015129][03 06][00] v2.3.0.13 -> v2.2.6.19
[00015167][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015217][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015328][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015408][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015487][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015562][12 02][00] v1.10.0.0 -> v1.8.0.0
[00015641][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028175][15 00][00] device not detected.
[00028258][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028379][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028437][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028471][01 00][00] v1.23.3419 -> v1.23.3419
[00028505][01 01][00] v1.23.3419 -> v1.23.3419
[00041042][08 00][00] device not detected.
[00041076]Packet upgrade failed at version checking.
[00015300]========== remo-con disconnect. boot(15) ============
[00015385]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x70ce1c3a].
[00015517]Packet upgrade start...
[00015566]Packet checking...
[00015616]Packet vlink 01.04.0010 <-> 01.03.0020.
[00015688]Done.
[00015730]Version checking[1]...
[00015815][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015894][03 06][00] v2.3.0.13 -> v2.3.0.13
[00015943][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016003][09 00][00] v1.7.0.3 -> v1.7.0.3
[00016115][11 00][00] v1.7.0.0 -> v1.7.0.0
[00016208][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016343][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016423][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016508][12 03][00] v1.10.0.0 -> v1.10.0.0
[00029053][15 00][00] device not detected.
[00029144][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029266][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029323][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029366][01 00][00] v1.23.3419 -> v1.23.3419
[00029408][01 01][00] v1.23.3419 -> v1.23.3419
[00041950][08 00][00] device not detected.
[00041994]Packet upgrade failed at version checking.
[00015801]========== 2015.09.08 18:39:54. boot(15) ============
[00015840]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x70ce1c3a].
[00015889]Packet upgrade start...
[00015932]Packet checking...
[00015974]Packet vlink 01.04.0010 <-> 01.03.0020.
[00016048]Done.
[00016089]Version checking[1]...
[00016161][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016220][03 06][00] v2.3.0.13 -> v2.3.0.13
[00016266][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016329][09 00][00] v1.7.0.3 -> v1.7.0.3
[00016441][11 00][00] v1.7.0.0 -> v1.7.0.0
[00016529][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016605][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016694][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016794][12 03][00] v1.10.0.0 -> v1.10.0.0
[00029334][15 00][00] device not detected.
[00029407][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029538][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029594][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029633][01 00][00] v1.23.3419 -> v1.23.3419
[00029673][01 01][00] v1.23.3419 -> v1.23.3419
[00042215][08 00][00] device not detected.
[00042334]Packet upgrade failed at version checking.
[00201319]========== 2015.09.08 19:13:30. boot(15) ============
[00201368]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x70ce1c3a].
[00201414]Packet upgrade start...
[00201464]Packet checking...
[00201516]Packet vlink 01.04.0010 <-> 01.03.0020.
[00201592]Done.
[00201639]Version checking[1]...
[00201741][03 05][00] v34.2.0.9 -> v34.2.0.9
[00201839][03 06][00] v2.3.0.13 -> v2.3.0.13
[00201890][04 00][00] v1.41.0.0 -> v1.41.0.0
[00201953][09 00][00] v1.7.0.3 -> v1.7.0.3
[00202079][11 00][00] v1.7.0.0 -> v1.7.0.0
[00202208][12 00][00] v1.10.0.0 -> v1.10.0.0
[00202307][12 01][00] v1.10.0.0 -> v1.10.0.0
[00202407][12 02][00] v1.10.0.0 -> v1.10.0.0
[00202507][12 03][00] v1.10.0.0 -> v1.10.0.0
[00215051][15 00][00] device not detected.
[00215131][17 00][00] v1.1.1.7 -> v1.1.1.7
[00215233][17 01][00] v1.0.2.7 -> v1.0.2.7
[00215303][19 00][00] v1.0.8.96 -> v1.0.8.96
[00215353][01 00][00] v1.23.3419 -> v1.23.3419
[00215397][01 01][00] v1.23.3419 -> v1.23.3419
[00227942][08 00][00] device not detected.
[00227985]Packet upgrade failed at version checking.
[00014549]========== remo-con disconnect. boot(15) ============
[00014597]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x70ce1c3a].
[00014641]Packet upgrade start...
[00014687]Packet checking...
[00014731]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014810]Done.
[00014855]Version checking[1]...
[00014933][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015006][03 06][00] v2.3.0.13 -> v2.3.0.13
[00015062][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015120][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015226][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015295][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015385][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015485][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015560][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028103][15 00][00] device not detected.
[00028195][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028337][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028500][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028544][01 00][00] v1.23.3419 -> v1.23.3419
[00028589][01 01][00] v1.23.3419 -> v1.23.3419
[00041140][08 00][00] device not detected.
[00041184]Packet upgrade failed at version checking.
[00014546]========== remo-con disconnect. boot(15) ============
[00014592]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x70ce1c3a].
[00014633]Packet upgrade start...
[00014679]Packet checking...
[00014722]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014798]Done.
[00014843]Version checking[1]...
[00014932][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015009][03 06][00] v2.3.0.13 -> v2.2.6.19
[00015065][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015121][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015231][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015343][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015415][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015515][12 02][00] v1.10.0.0 -> v1.8.0.0
[00015607][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028153][15 00][00] device not detected.
[00028261][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028381][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028462][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028504][01 00][00] v1.23.3419 -> v1.23.3419
[00028547][01 01][00] v1.23.3419 -> v1.23.3419
[00041106][08 00][00] device not detected.
[00041148]Packet upgrade failed at version checking.
[00015117]========== 2015.09.08 19:41:04. boot(15) ============
[00015158]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x70ce1c3a].
[00015200]Packet upgrade start...
[00015253]Packet checking...
[00015293]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015366]Done.
[00015407]Version checking[1]...
[00015490][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015569][03 06][00] v2.3.0.13 -> v2.2.6.19
[00015623][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015673][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015789][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015878][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015979][12 01][00] v1.10.0.0 -> v1.8.0.0
[00016158][12 02][00] v1.10.0.0 -> v1.8.0.0
[00016238][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028787][15 00][00] device not detected.
[00028878][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029019][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029073][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029120][01 00][00] v1.23.3419 -> v1.23.3419
[00029165][01 01][00] v1.23.3419 -> v1.23.3419
[00041708][08 00][00] device not detected.
[00041750]Packet upgrade failed at version checking.
[00014568]========== 2015.09.08 19:42:43. boot(15) ============
[00014607]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x70ce1c3a].
[00014651]Packet upgrade start...
[00014696]Packet checking...
[00014744]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014816]Done.
[00014859]Version checking[1]...
[00014938][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015018][03 06][00] v2.3.0.13 -> v2.2.6.19
[00015071][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015142][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015258][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015352][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015457][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015552][12 02][00] v1.10.0.0 -> v1.8.0.0
[00015652][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028195][15 00][00] device not detected.
[00028328][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028447][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028503][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028546][01 00][00] v1.23.3419 -> v1.23.3419
[00028590][01 01][00] v1.23.3419 -> v1.23.3419
[00041134][08 00][00] device not detected.
[00041177]Packet upgrade failed at version checking.
[00014590]========== remo-con disconnect. boot(15) ============
[00014632]Packet [C:\P3X_FW_V01.01.0009.bin] detected, card sn [0x70ce1c3a].
[00014680]Packet upgrade start...
[00014730]Packet checking...
[00014780]Packet vlink 01.01.0000 <-> 01.01.0000.
[00014857]Done.
[00014900]Version checking[1]...
[00014987][03 05][00] v34.2.0.9 -> v34.2.0.8
[00015067][03 06][00] v2.3.0.13 -> v2.1.6.18
[00015123][04 00][00] v1.41.0.0 -> v1.36.0.0
[00015277][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015387][11 00][00] v1.7.0.0 -> v1.6.0.0
[00015476][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015567][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015676][12 02][00] v1.10.0.0 -> v1.8.0.0
[00015767][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028314][15 00][00] device not detected.
[00028396][17 00][00] v1.1.1.7 -> v1.1.1.2
[00028537][17 01][00] v1.0.2.7 -> v1.0.2.4
[00028599][19 00][00] v1.0.8.96 -> v1.0.8.59
[00028644][01 00][00] v1.23.3419 -> v1.6.2736
[00028691][01 01][00] v1.23.3419 -> v1.5.2735
[00041241][08 00][00] device not detected.
[00041291]Packet upgrade failed at version checking.
[00014603]========== 2015.09.08 20:17:54. boot(15) ============
[00014648]Packet [C:\P3X_FW_V01.01.0009.bin] detected, card sn [0x70ce1c3a].
[00014691]Packet upgrade start...
[00014738]Packet checking...
[00014789]Packet vlink 01.01.0000 <-> 01.01.0000.
[00014862]Done.
[00014905]Version checking[1]...
[00015001][03 05][00] v34.2.0.9 -> v34.2.0.8
[00015085][03 06][00] v2.3.0.13 -> v2.1.6.18
[00015135][04 00][00] v1.41.0.0 -> v1.36.0.0
[00015199][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015347][11 00][00] v1.7.0.0 -> v1.6.0.0
[00015451][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015555][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015656][12 02][00] v1.10.0.0 -> v1.8.0.0
[00015753][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028296][15 00][00] device not detected.
[00028388][17 00][00] v1.1.1.7 -> v1.1.1.2
[00028529][17 01][00] v1.0.2.7 -> v1.0.2.4
[00028687][01 01][00] v1.23.3419 -> v1.5.2735
[00041232][08 00][00] device not detected.
[00041281]Packet upgrade failed at version checking.
[00014594]========== remo-con disconnect. boot(15) ============
[00014639]Packet [C:\P3X_FW_V01.01.1003.bin] detected, card sn [0x70ce1c3a].
[00014687]Packet upgrade start...
[00014736]Packet checking...
[00014788]Packet upgrade failed at packet checking.
[00015117]========== remo-con disconnect. boot(15) ============
[00015164]Packet [C:\P3X_FW_V01.01.1003.bin] detected, card sn [0x70ce1c3a].
[00015214]Packet upgrade start...
[00015269]Packet checking...
[00015320]Packet upgrade failed at packet checking.
[00014632]========== remo-con disconnect. boot(15) ============
[00014677]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x70ce1c3a].
[00014723]Packet upgrade start...
[00014778]Packet checking...
[00014824]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014898]Done.
[00014950]Version checking[1]...
[00015037][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015121][03 06][00] v2.3.0.13 -> v2.2.6.19
[00015169][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015236][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015360][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015445][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015545][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015748][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028293][15 00][00] device not detected.
[00028385][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028531][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028596][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028641][01 00][00] v1.23.3419 -> v1.23.3419
[00028686][01 01][00] v1.23.3419 -> v1.23.3419
[00041233][08 00][00] device not detected.
[00041283]Packet upgrade failed at version checking.
[00225352]========== 2015.09.08 21:05:35. boot(15) ============
[00225398]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x70ce1c3a].
[00225448]Packet upgrade start...
[00225498]Packet checking...
[00225544]Packet vlink 01.03.0020 <-> 01.01.0009.
[00225619]Done.
[00225664]Version checking[1]...
[00225737][03 05][00] v34.2.0.9 -> v34.2.0.9
[00225816][03 06][00] v2.3.0.13 -> v2.2.6.19
[00225874][04 00][00] v1.41.0.0 -> v1.40.0.0
[00225945][09 00][00] v1.7.0.3 -> v1.7.0.3
[00226061][11 00][00] v1.7.0.0 -> v1.7.0.0
[00226150][12 00][00] v1.10.0.0 -> v1.8.0.0
[00226230][12 01][00] v1.10.0.0 -> v1.8.0.0
[00226410][12 02][00] v1.10.0.0 -> v1.8.0.0
[00226510][12 03][00] v1.10.0.0 -> v1.8.0.0
[00239057][15 00][00] device not detected.
[00239165][17 00][00] v1.1.1.7 -> v1.1.1.7
[00239305][17 01][00] v1.0.2.7 -> v1.0.2.7
[00239369][19 00][00] v1.0.8.96 -> v1.0.8.96
[00239418][01 00][00] v1.23.3419 -> v1.23.3419
[00239469][01 01][00] v1.23.3419 -> v1.23.3419
[00252015][08 00][00] device not detected.
[00252064]Packet upgrade failed at version checking.
[00014950]========== remo-con disconnect. boot(15) ============
[00015072]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x92ac838d].
[00015122]Packet upgrade start...
[00015167]Packet checking...
[00015213]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015293]Done.
[00015336]Version checking[1]...
[00015403][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015483][03 06][00] v2.3.0.13 -> v2.2.6.19
[00015533][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015593][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015704][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015804][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015893][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015983][12 02][00] v1.10.0.0 -> v1.8.0.0
[00016083][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028634][15 00][00] device not detected.
[00028714][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028836][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028894][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028944][01 00][00] v1.23.3419 -> v1.23.3419
[00028986][01 01][00] v1.23.3419 -> v1.23.3419
[00041530][08 00][00] device not detected.
[00041574]Packet upgrade failed at version checking.
[00015125]========== remo-con disconnect. boot(15) ============
[00015231]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x92ac838d].
[00015354]Packet upgrade start...
[00015400]Packet checking...
[00015450]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015524]Done.
[00015567]Version checking[1]...
[00015655][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015732][03 06][00] v2.3.0.13 -> v2.2.6.19
[00015794][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015961][09 00][00] v1.7.0.3 -> v1.7.0.3
[00016155][11 00][00] v1.7.0.0 -> v1.7.0.0
[00016248][12 00][00] v1.10.0.0 -> v1.8.0.0
[00016348][12 01][00] v1.10.0.0 -> v1.8.0.0
[00016447][12 02][00] v1.10.0.0 -> v1.8.0.0
[00016547][12 03][00] v1.10.0.0 -> v1.8.0.0
[00029106][15 00][00] device not detected.
[00029198][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029324][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029383][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029431][01 00][00] v1.23.3419 -> v1.23.3419
[00029485][01 01][00] v1.23.3419 -> v1.23.3419
[00042030][08 00][00] device not detected.
[00042075]Packet upgrade failed at version checking.
[00015139]========== remo-con disconnect. boot(15) ============
[00015259]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x92ac838d].
[00015382]Packet upgrade start...
[00015433]Packet checking...
[00015479]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015556]Done.
[00015604]Version checking[1]...
[00015680][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015760][03 06][00] v2.3.0.13 -> v2.2.6.19
[00015811][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015869][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015980][11 00][00] v1.7.0.0 -> v1.7.0.0
[00016074][12 00][00] v1.10.0.0 -> v1.8.0.0
[00016174][12 01][00] v1.10.0.0 -> v1.8.0.0
[00016274][12 02][00] v1.10.0.0 -> v1.8.0.0
[00016349][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028896][15 00][00] device not detected.
[00028990][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029111][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029170][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029216][01 00][00] v1.23.3419 -> v1.23.3419
[00029265][01 01][00] v1.23.3419 -> v1.23.3419
[00041817][08 00][00] device not detected.
[00041861]Packet upgrade failed at version checking.
发布于2015-09-08
浏览2.1k
8 条评论
最热
最新
最早
大疆社区
说说你的想法,让评论更有深度~
暂无更多评论
关于作者
大疆社区
no1caresme
暂无关联认证的设备
