请选择 进入手机版 | 继续访问电脑版
为什么不给精灵加装一个紧急降落伞
手机看帖 7 2647
你好  我很好奇为什么不给我们的精灵加装一个紧急降落伞呢 ,这个技术要求不会太高吧 强烈建议大僵公司好好琢磨一下
飞天小小米   2015-12-22 2#
是啊。。。
装个降落伞防止摔坏砸到人,好处挺多
但是估计是结构设计,重量等因素导致无法做到的。。
如果能装降落伞,那装个气球不是更好
dickie@thinking  Phantom 3 Advanced认证用户 2015-12-23 3#
外國有給P3用的降落傘,一有事就自動彈出來,不過要160美金,DJI也有一個給專業機用的DJI DropSafe高空下落缓速系统
TTonyy  Osmo认证用户 2015-12-23 4#
坐等石榴和秋香姐的高见~
611301202  Mavic Mini认证用户 2015-12-23 5#
dickie@thinking 发表于 2015-12-23 09:15
外國有給P3用的降落傘,一有事就自動彈出來,不過要160美金,DJI也有一個給專業機用的DJI DropSafe高空下落 ...
精灵机器太小,承重力不够,所以估计加不了降落伞,而且DJI DropSafe是给大机架用的,不适合小的精灵
dickie@thinking  Phantom 3 Advanced认证用户 2015-12-23 6#
我說那個是適合p3用的,正在集資,已經可以pre-order了Aerial photography drones are highly useful pieces of technology that help us to broaden our visual horizons. However, popular consumer drones, from companies such as DJI, can cost well over a thousand dollars – something you certainly want to be careful with while flying. A new product on Kickstarter, SmartChutes, believes that they can help you to protect your drone in the event of a catastrophic mechanical failure or pilot error.
Nothing can be more terrifying than watching your expensive new gadget come crashing down from the skies. SmartChutes is a drone parachute recovery system that will automatically deploy in the event your drone is launched into a free fall. The company claims that the “system can detect an emergency and deploy a parachute in less than 350ms”. The system also includes flip and roll protection if your device tilts more than 90 degrees.
SmartChutes describes the installation process as simply installing two bolts onto the existing factory landing skid mount. When you are ready to fly, turn on the SmartChutes Flight Sensor and wait 15 seconds before take off. The company recommends operating above 50 meters for the system to work effectively
jynj  Phantom 3 Advanced认证用户 2015-12-23 7#
这个是不是一次性用品?
楼主  Mavic 2 Pro认证用户 2015-12-24 8#
jynj 发表于 2015-12-23 21:20
这个是不是一次性用品?
据说可以重复使用
已累计飞行36719米
收藏 点赞 评论
