请选择 进入手机版 | 继续访问电脑版
大疆的仙女妹妹看过来
手机看帖 8 1458
我的精灵P3P升级1.6固件失败,怎么重新升级或降级都无法完成,现在的状况是APP显示“没有图传信号”,但APP其它功能正常,也可以启动及控制飞机。
我这种情况是不是只能还能自己解决吗?LOG文件中显示有:设备不能被发现,难道是图传模块挂了?(注:升级前一切功能正常
下面是升级状态文件:
Result: Success.
========== 2014.01.01 00:00:14 remo-con disconnect======
Packet: P3X_FW_V01.02.0006.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2014.01.01 00:00:13 remo-con disconnect======
Packet: P3X_FW_V01.03.0020.bin
Upgrading ...
Result: Success.
Result: Abort.
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
Result: Abort.
Packet: P3X_FW_V01.04.0010.bin
Upgrading ...
Result: Success.
Result: Abort.
========== 2014.01.01 00:00:15 remo-con disconnect======
Packet: P3X_FW_V01.05.0030.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Result: Failed.
Packet: P3X_FW_V01.06.0040.bin
Upgrading ...
Result: Failed.
Result: Failed.
Result: Failed.
========== 2014.01.01 00:00:16 remo-con disconnect======
Result: Failed.
Upgrading ...
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
========== 2015.12.27 23:52:20 =====================
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Upgrading ...
Result: Failed.
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Result: Failed.
Upgrading ...
Result: Failed.
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
楼主  Inspire 1 V2.0认证用户 2015-12-28 2#
LOG文件
[00014251][01 00] Firmware upgrade finished successfully.
[00014367]Done.
[00014403]Packet [C:\P3X_FW_V01.02.0006.bin] resumed, card sn [0x98a5e888].
[00014444]Version checking[2]...
[00014522][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00014602][03 06][00] v2.1.6.7 -> v2.2.6.8 need upgrade.
[00014651][04 00][00] v1.36.0.0 -> v1.38.0.0 need upgrade.
[00014706][09 00][00] v1.7.0.3 -> v1.7.0.3
[00014821][11 00][00] v1.6.0.0 -> v1.6.0.0
[00014912][12 00][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00014991][12 01][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00015071][12 02][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00015158][12 03][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00015277][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015347][17 00][00] v1.1.1.2 -> v1.1.1.6 need upgrade.
[00015466][17 01][00] v1.0.2.4 -> v1.0.2.5 need upgrade.
[00015531][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00015573][01 00][05] v1.15.3056 -> v1.15.3056
[00015609][01 01][00] v1.6.2736 -> v1.15.3056 need upgrade
[00015657][08 00][00] v0.11.0.4 -> v0.11.0.4
[00015697]Done.
[00015735]Firmware upgrading[2]...
[00015887][01 01] Firmware upgrade start...
[00046154][01 01] Firmware upgrade finished successfully.
[00046206][12 00] Firmware upgrade start...
[00110902][12 00] Firmware upgrade finished successfully.
[00110954][12 01] Firmware upgrade start...
[00181727][12 01] Firmware upgrade finished successfully.
[00181778][12 02] Firmware upgrade start...
[00246912][12 02] Firmware upgrade finished successfully.
[00246964][12 03] Firmware upgrade start...
[00312129][12 03] Firmware upgrade finished successfully.
[00312187][17 00] Firmware upgrade start...
[00445217][17 00] Firmware upgrade finished successfully.
[00445265][17 01] Firmware upgrade start...
[00520741][17 01] Firmware upgrade finished successfully.
[00520790][03 05] Firmware upgrade start...
[00589416][03 05] Firmware upgrade finished successfully.
[00589649][03 06] Firmware upgrade start...
[00898767][03 06] Firmware upgrade finished successfully.
[00901949][19 00] Firmware upgrade start...
[01068974][19 00] Firmware upgrade finished successfully.
[01069041][04 00] Firmware upgrade start...
[01126742][04 00] Firmware upgrade finished successfully.
[01126778]Done.
[01126819]Version checking[3]...
[01126892][03 05][05] v34.2.0.9 -> v34.2.0.9
[01126977][03 06][05] v2.2.6.8 -> v2.2.6.8
[01127020][04 00][05] v1.38.0.0 -> v1.38.0.0
[01127082][09 00][00] v1.7.0.3 -> v1.7.0.3
[01127197][11 00][00] v1.6.0.0 -> v1.6.0.0
[01127331][12 00][05] v1.8.0.0 -> v1.8.0.0
[01127407][12 01][05] v1.8.0.0 -> v1.8.0.0
[01127497][12 02][05] v1.8.0.0 -> v1.8.0.0
[01127597][12 03][05] v1.8.0.0 -> v1.8.0.0
[01127747][15 00][00] v1.1.2.0 -> v1.1.2.0
[01127822][17 00][05] v1.1.1.6 -> v1.1.1.6
[01127943][17 01][05] v1.0.2.5 -> v1.0.2.5
[01128003][19 00][05] v1.0.8.96 -> v1.0.8.96
[01128039][01 00][05] v1.15.3056 -> v1.15.3056
[01128077][01 01][05] v1.15.3056 -> v1.15.3056
[01128124][08 00][00] v0.11.0.4 -> v0.11.0.4
[01128160]Packet upgrade finish successfully.
[00014589]========== remo-con disconnect. boot(15) ============
[00014627]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x98a5e888].
[00014663]Packet upgrade start...
[00014706]Packet checking...
[00014740]Done.
[00014776]Version checking[1]...
[00014838][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014922][03 06][00] v2.2.6.8 -> v2.2.6.8
[00014968][04 00][00] v1.38.0.0 -> v1.38.0.0
[00015024][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015138][11 00][00] v1.6.0.0 -> v1.6.0.0
[00015227][12 00][00] v1.8.0.0 -> v1.8.0.0
[00015306][12 01][00] v1.8.0.0 -> v1.8.0.0
[00015423][12 02][00] v1.8.0.0 -> v1.8.0.0
[00015507][12 03][00] v1.8.0.0 -> v1.8.0.0
[00015657][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015727][17 00][00] v1.1.1.6 -> v1.1.1.6
[00015847][17 01][00] v1.0.2.5 -> v1.0.2.5
[00015904][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015941][01 00][00] v1.15.3056 -> v1.15.3056
[00015978][01 01][00] v1.15.3056 -> v1.15.3056
[00016119][08 00][00] v0.11.0.4 -> v0.11.0.4
[00016160]Packet upgrade cancelled at version checking.
[00012538]========== remo-con disconnect. boot(15) ============
[00012574]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x98a5e888].
[00012611]Packet upgrade start...
[00012658]Packet checking...
[00012695]Done.
[00012732]Version checking[1]...
[00012817][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012898][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00012944][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00012998][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013122][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00013207][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013287][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013372][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013472][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013593][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013687][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00013827][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00013879][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013914][01 00][00] v1.15.3056 -> v1.23.3419 need upgrade
[00013955][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade
[00014004][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00014043]Done.
[00016082]Waiting for user confirm...
[00026118]Timeout, start upgrade automatically.
[00026188]Firmware upgrading[1]...
[00038299][01 00] Firmware upgrade start...
[00012140][01 00] Firmware upgrade finished successfully.
[00012181]Done.
[00012222]Packet [C:\P3X_FW_V01.03.0020.bin] resumed, card sn [0x98a5e888].
[00012265]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012335]Version checking[2]...
[00012427][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012507][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00012554][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00012602][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012727][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00012821][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012921][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013023][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013201][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013328][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013415][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00013535][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00013602][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013641][01 00][05] v1.23.3419 -> v1.23.3419
[00013685][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade
[00013736][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00013778]Done.
[00013815]Firmware upgrading[2]...
[00013960][01 01] Firmware upgrade start...
[00044237][01 01] Firmware upgrade finished successfully.
[00045104][08 00] Firmware upgrade start...
[00560212][08 00] Firmware upgrade finished successfully.
[00560272][17 00] Firmware upgrade start...
[00647678][17 00] Firmware upgrade finished successfully.
[00647728][17 01] Firmware upgrade start...
[00711761][17 01] Firmware upgrade finished successfully.
[00711811][11 00] Firmware upgrade start...
[00760137][11 00] Firmware upgrade finished successfully.
[00760359][03 06] Firmware upgrade start...
[01085672][03 06] Firmware upgrade finished successfully.
[01085743][04 00] Firmware upgrade start...
[01143781][04 00] Firmware upgrade finished successfully.
[01143817]Done.
[01143857]Version checking[3]...
[01143936][03 05][00] v34.2.0.9 -> v34.2.0.9
[01143992][03 06][05] v2.2.6.19 -> v2.2.6.19
[01144035][04 00][05] v1.40.0.0 -> v1.40.0.0
[01144106][09 00][00] v1.7.0.3 -> v1.7.0.3
[01144276][11 00][05] v1.7.0.0 -> v1.7.0.0
[01144351][12 00][00] v1.8.0.0 -> v1.8.0.0
[01144430][12 01][00] v1.8.0.0 -> v1.8.0.0
[01144506][12 02][00] v1.8.0.0 -> v1.8.0.0
[01144595][12 03][00] v1.8.0.0 -> v1.8.0.0
[01144728][15 00][00] v1.1.2.0 -> v1.1.2.0
[01144800][17 00][05] v1.1.1.7 -> v1.1.1.7
[01144920][17 01][05] v1.0.2.7 -> v1.0.2.7
[01144986][19 00][00] v1.0.8.96 -> v1.0.8.96
[01145026][01 00][05] v1.23.3419 -> v1.23.3419
[01145069][01 01][05] v1.23.3419 -> v1.23.3419
[01145126][08 00][05] v0.12.0.4 -> v0.12.0.4
[01145254]Packet upgrade finish successfully.
[00013172]========== remo-con disconnect. boot(15) ============
[00013211]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x98a5e888].
[00013251]Packet upgrade start...
[00013299]Packet checking...
[00013339]Packet vlink 01.03.0020 <-> 01.01.0009.
[00013377]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00013415]Done.
[00013456]Version checking[1]...
[00013530][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013606][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013653][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013706][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013831][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013926][12 00][00] v1.8.0.0 -> v1.8.0.0
[00014026][12 01][00] v1.8.0.0 -> v1.8.0.0
[00014116][12 02][00] v1.8.0.0 -> v1.8.0.0
[00014205][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014341][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014436][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014560][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014626][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014664][01 00][00] v1.23.3419 -> v1.23.3419
[00014705][01 01][00] v1.23.3419 -> v1.23.3419
[00014769][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014809]Packet upgrade cancelled at version checking.
[00012583]========== remo-con disconnect. boot(15) ============
[00012623]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x98a5e888].
[00012661]Packet upgrade start...
[00012712]Packet checking...
[00012749]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012788]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012826]Done.
[00012868]Version checking[1]...
[00012941][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013020][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013065][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013116][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013241][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00013336][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013436][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013536][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013637][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013833][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013933][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014073][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014156][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014195][01 00][00] v1.23.3419 -> v1.23.3419
[00014233][01 01][00] v1.23.3419 -> v1.23.3419
[00014289][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014344]Done.
[00016381]Waiting for user confirm...
[00026419]Timeout, start upgrade automatically.
[00026502]Firmware upgrading[1]...
[00026550][11 00] Firmware upgrade start...
[00076459][11 00] Firmware upgrade finished successfully.
[00076497]Done.
[00076541]Version checking[2]...
[00076625][03 05][00] v34.2.0.9 -> v34.2.0.9
[00076704][03 06][00] v2.2.6.19 -> v2.2.6.19
[00076753][04 00][00] v1.40.0.0 -> v1.40.0.0
[00076819][09 00][00] v1.7.0.3 -> v1.7.0.3
[00076949][11 00][05] v1.7.0.0 -> v1.7.0.0
[00077034][12 00][00] v1.8.0.0 -> v1.8.0.0
[00077135][12 01][00] v1.8.0.0 -> v1.8.0.0
[00077234][12 02][00] v1.8.0.0 -> v1.8.0.0
[00077324][12 03][00] v1.8.0.0 -> v1.8.0.0
[00077456][15 00][00] v1.1.2.0 -> v1.1.2.0
[00077555][17 00][00] v1.1.1.7 -> v1.1.1.7
[00077675][17 01][00] v1.0.2.7 -> v1.0.2.7
[00077740][19 00][00] v1.0.8.96 -> v1.0.8.96
[00077780][01 00][00] v1.23.3419 -> v1.23.3419
[00077825][01 01][00] v1.23.3419 -> v1.23.3419
[00077876][08 00][00] v0.12.0.4 -> v0.12.0.4
[00077916]Packet upgrade finish successfully.
[00012587]========== remo-con disconnect. boot(15) ============
[00012624]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x98a5e888].
[00012665]Packet upgrade start...
[00012717]Packet checking...
[00012754]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012793]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012837]Done.
[00012878]Version checking[1]...
[00012970][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013050][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013096][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013165][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013290][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00013477][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013575][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013674][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013764][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013899][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013999][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014134][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014185][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014227][01 00][00] v1.23.3419 -> v1.23.3419
[00014265][01 01][00] v1.23.3419 -> v1.23.3419
[00014332][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014367]Done.
[00016409]Waiting for user confirm...
[00026447]Timeout, start upgrade automatically.
[00026527]Firmware upgrading[1]...
[00026576][11 00] Firmware upgrade start...
[00075028][11 00] Firmware upgrade finished successfully.
[00075064]Done.
[00075109]Version checking[2]...
[00075193][03 05][00] v34.2.0.9 -> v34.2.0.9
[00075273][03 06][00] v2.2.6.19 -> v2.2.6.19
[00075318][04 00][00] v1.40.0.0 -> v1.40.0.0
[00075369][09 00][00] v1.7.0.3 -> v1.7.0.3
[00075493][11 00][05] v1.7.0.0 -> v1.7.0.0
[00075593][12 00][00] v1.8.0.0 -> v1.8.0.0
[00075683][12 01][00] v1.8.0.0 -> v1.8.0.0
[00075783][12 02][00] v1.8.0.0 -> v1.8.0.0
[00075883][12 03][00] v1.8.0.0 -> v1.8.0.0
[00076018][15 00][00] v1.1.2.0 -> v1.1.2.0
[00076124][17 00][00] v1.1.1.7 -> v1.1.1.7
[00076243][17 01][00] v1.0.2.7 -> v1.0.2.7
[00076309][19 00][00] v1.0.8.96 -> v1.0.8.96
[00076371][01 00][00] v1.23.3419 -> v1.23.3419
[00076409][01 01][00] v1.23.3419 -> v1.23.3419
[00076464][08 00][00] v0.12.0.4 -> v0.12.0.4
[00076505]Packet upgrade finish successfully.
[00012613]========== remo-con disconnect. boot(15) ============
[00012651]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x98a5e888].
[00012695]Packet upgrade start...
[00012741]Packet checking...
[00012782]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012823]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012872]Done.
[00012910]Version checking[1]...
[00012997][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013157][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013207][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013267][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013387][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00013482][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013581][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013681][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013781][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013922][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014017][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014137][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014207][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014248][01 00][00] v1.23.3419 -> v1.23.3419
[00014296][01 01][00] v1.23.3419 -> v1.23.3419
[00014378][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014419]Done.
[00016464]Waiting for user confirm...
[00026504]Timeout, start upgrade automatically.
[00026585]Firmware upgrading[1]...
[00026641][11 00] Firmware upgrade start...
[00075205][11 00] Firmware upgrade finished successfully.
[00075251]Done.
[00075291]Version checking[2]...
[00075398][03 05][00] v34.2.0.9 -> v34.2.0.9
[00075473][03 06][00] v2.2.6.19 -> v2.2.6.19
[00075518][04 00][00] v1.40.0.0 -> v1.40.0.0
[00075593][09 00][00] v1.7.0.3 -> v1.7.0.3
[00075737][11 00][05] v1.7.0.0 -> v1.7.0.0
[00075825][12 00][00] v1.8.0.0 -> v1.8.0.0
[00075925][12 01][00] v1.8.0.0 -> v1.8.0.0
[00076026][12 02][00] v1.8.0.0 -> v1.8.0.0
[00076126][12 03][00] v1.8.0.0 -> v1.8.0.0
[00076252][15 00][00] v1.1.2.0 -> v1.1.2.0
[00076341][17 00][00] v1.1.1.7 -> v1.1.1.7
[00076480][17 01][00] v1.0.2.7 -> v1.0.2.7
[00076553][19 00][00] v1.0.8.96 -> v1.0.8.96
[00076594][01 00][00] v1.23.3419 -> v1.23.3419
[00076636][01 01][00] v1.23.3419 -> v1.23.3419
[00076697][08 00][00] v0.12.0.4 -> v0.12.0.4
[00076740]Packet upgrade finish successfully.
[00012626]========== remo-con disconnect. boot(15) ============
[00012667]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x98a5e888].
[00012713]Packet upgrade start...
[00012762]Packet checking...
[00012800]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012934]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012973]Done.
[00013018]Version checking[1]...
[00013103][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013183][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013232][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013287][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013423][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013517][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013617][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013717][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013817][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013962][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014056][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014176][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014227][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014270][01 00][00] v1.23.3419 -> v1.23.3419
[00014316][01 01][00] v1.23.3419 -> v1.23.3419
[00014402][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014448]Packet upgrade cancelled at version checking.
[00014021]========== remo-con disconnect. boot(15) ============
[00014063]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x98a5e888].
[00014111]Packet upgrade start...
[00014157]Packet checking...
[00014200]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014243]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00014290]Done.
[00014333]Version checking[1]...
[00014407][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014487][03 06][00] v2.2.6.19 -> v2.3.0.13 need upgrade.
[00014538][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[00014613][09 00][00] v1.7.0.3 -> v1.7.0.3
[00014726][11 00][00] v1.7.0.0 -> v1.7.0.0
[00014822][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00014922][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00015021][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00015121][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00015261][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015333][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015461][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015537][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015580][01 00][00] v1.23.3419 -> v1.23.3419
[00015690][01 01][00] v1.23.3419 -> v1.23.3419
[00015781][08 00][00] v0.12.0.4 -> v0.12.0.4
[00015823]Done.
[00017872]Waiting for user confirm...
[00027911]Timeout, start upgrade automatically.
[00027993]Firmware upgrading[1]...
[00028050][12 00] Firmware upgrade start...
[00094348][12 00] Firmware upgrade finished successfully.
[00094403][12 01] Firmware upgrade start...
[00162145][12 01] Firmware upgrade finished successfully.
[00162201][12 02] Firmware upgrade start...
[00234044][12 02] Firmware upgrade finished successfully.
[00234108][12 03] Firmware upgrade start...
[00315203][12 03] Firmware upgrade finished successfully.
[00315429][03 06] Firmware upgrade start...
[00642108][03 06] Firmware upgrade finished successfully.
[00642178][04 00] Firmware upgrade start...
[00701143][04 00] Firmware upgrade finished successfully.
[00701190]Done.
[00701233]Version checking[2]...
[00701318][03 05][00] v34.2.0.9 -> v34.2.0.9
[00701418][03 06][05] v2.3.0.13 -> v2.3.0.13
[00701467][04 00][05] v1.41.0.0 -> v1.41.0.0
[00701533][09 00][00] v1.7.0.3 -> v1.7.0.3
[00701658][11 00][00] v1.7.0.0 -> v1.7.0.0
[00701747][12 00][05] v1.10.0.0 -> v1.10.0.0
[00701853][12 01][05] v1.10.0.0 -> v1.10.0.0
[00701953][12 02][05] v1.10.0.0 -> v1.10.0.0
[00702053][12 03][05] v1.10.0.0 -> v1.10.0.0
[00702188][15 00][00] v1.1.2.0 -> v1.1.2.0
[00702282][17 00][00] v1.1.1.7 -> v1.1.1.7
[00702422][17 01][00] v1.0.2.7 -> v1.0.2.7
[00702493][19 00][00] v1.0.8.96 -> v1.0.8.96
[00702538][01 00][00] v1.23.3419 -> v1.23.3419
[00702581][01 01][00] v1.23.3419 -> v1.23.3419
[00702637][08 00][00] v0.12.0.4 -> v0.12.0.4
[00702681]Packet upgrade finish successfully.
[00013976]========== remo-con disconnect. boot(15) ============
[00014020]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x98a5e888].
[00014068]Packet upgrade start...
[00014117]Packet checking...
[00014160]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014209]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014337]Done.
[00014387]Version checking[1]...
[00014480][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014580][03 06][00] v2.3.0.13 -> v2.3.0.13
[00014643][04 00][00] v1.41.0.0 -> v1.41.0.0
[00014713][09 00][00] v1.7.0.3 -> v1.7.0.3
[00014840][11 00][00] v1.7.0.0 -> v1.7.0.0
[00014928][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015040][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015128][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015229][12 03][00] v1.10.0.0 -> v1.10.0.0
[00015376][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015464][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015604][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015675][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015719][01 00][00] v1.23.3419 -> v1.23.3419
[00015764][01 01][00] v1.23.3419 -> v1.23.3419
[00015828][08 00][00] v0.12.0.4 -> v0.12.0.4
[00015873]Packet upgrade cancelled at version checking.
[00015878]========== remo-con disconnect. boot(15) ============
[00015927]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x98a5e888].
[00015978]Packet upgrade start...
[00016030]Packet checking...
[00016074]Packet vlink 01.05.0030 <-> 01.04.0010.
[00016121]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00016169]Done.
[00016212]Version checking[1]...
[00016286][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016360][03 06][00] v2.3.0.13 -> v2.4.0.5 need upgrade.
[00016412][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016540][11 00][00] v1.7.0.0 -> v1.7.0.0
[00016634][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016710][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016805][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016892][12 03][00] v1.10.0.0 -> v1.10.0.0
[00029454][15 00][00] device not detected.
[00029550][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029672][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029751][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029795][01 00][00] v1.23.3419 -> v1.26.4315 need upgrade
[00029847][01 01][00] v1.23.3419 -> v1.26.4315 need upgrade
[00042392][08 00][00] device not detected.
[00042451][09 00][00] v1.7.0.3 -> v2.13.0.0 need upgrade.
[00042574]Done.
[00044621]Waiting for user confirm...
[00054669]Timeout, start upgrade automatically.
[00054759]Firmware upgrading[1]...
[00067556][01 00] Firmware upgrade start...
[00014147][01 00] Firmware upgrade finished successfully.
[00014193]Done.
[00014240]Packet [C:\P3X_FW_V01.05.0030.bin] resumed, card sn [0x98a5e888].
[00014294]Packet vlink 01.05.0030 <-> 01.04.0010.
[00014348]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014394]Version checking[2]...
[00014476][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014577][03 06][00] v2.3.0.13 -> v2.4.0.5 need upgrade.
[00014647][04 00][00] v1.41.0.0 -> v1.41.0.0
[00014775][11 00][00] v1.7.0.0 -> v1.7.0.0
[00014884][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014984][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015065][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015165][12 03][00] v1.10.0.0 -> v1.10.0.0
[00027712][15 00][00] device not detected.
[00027801][17 00][00] v1.1.1.7 -> v1.1.1.7
[00027940][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028001][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028048][01 00][05] v1.26.4315 -> v1.26.4315
[00028098][01 01][00] v1.23.3419 -> v1.26.4315 need upgrade
[00040648][08 00][00] device not detected.
[00040721][09 00][00] v1.7.0.3 -> v2.13.0.0 need upgrade.
[00040772]Done.
[00040819]Firmware upgrading[2]...
[00040986][01 01] Firmware upgrade start...
[00071266][01 01] Firmware upgrade finished successfully.
[00071532][03 06] Firmware upgrade start...
[00390117][03 06] Firmware upgrade finished successfully.
[00390197][09 00] Firmware upgrade start...
[00444320][09 00] Firmware upgrade finished successfully.
[00444367]Done.
[00444417]Version checking[3]...
[00444487][03 05][00] v34.2.0.9 -> v34.2.0.9
[00444572][03 06][05] v2.4.0.5 -> v2.4.0.5
[00444624][04 00][00] v1.41.0.0 -> v1.41.0.0
[00444747][11 00][00] v1.7.0.0 -> v1.7.0.0
[00444847][12 00][00] v1.10.0.0 -> v1.10.0.0
[00444936][12 01][00] v1.10.0.0 -> v1.10.0.0
[00445021][12 02][00] v1.10.0.0 -> v1.10.0.0
[00445216][12 03][00] v1.10.0.0 -> v1.10.0.0
[00457770][15 00][00] device not detected.
[00457852][17 00][00] v1.1.1.7 -> v1.1.1.7
[00457972][17 01][00] v1.0.2.7 -> v1.0.2.7
[00458037][19 00][00] v1.0.8.96 -> v1.0.8.96
[00458091][01 00][05] v1.26.4315 -> v1.26.4315
[00458141][01 01][05] v1.26.4315 -> v1.26.4315
[00470690][08 00][00] device not detected.
[00470764][09 00][05] v2.13.0.0 -> v2.13.0.0
[00470812]Packet upgrade failed at version checking.
[00015916]========== remo-con disconnect. boot(15) ============
[00015973]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x98a5e888].
[00016022]Packet upgrade start...
[00016078]Packet checking...
[00016131]Packet vlink 01.05.0030 <-> 01.04.0010.
[00016179]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00016229]Done.
[00016277]Version checking[1]...
[00016359][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016439][03 06][00] v2.4.0.5 -> v2.4.0.5
[00016498][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016619][11 00][00] v1.7.0.0 -> v1.7.0.0
[00016713][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016812][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016912][12 02][00] v1.10.0.0 -> v1.10.0.0
[00017032][12 03][00] v1.10.0.0 -> v1.10.0.0
[00029581][15 00][00] device not detected.
[00029672][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029788][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029869][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029919][01 00][00] v1.26.4315 -> v1.26.4315
[00029970][01 01][00] v1.26.4315 -> v1.26.4315
[00042525][08 00][00] device not detected.
[00042590][09 00][00] v2.13.0.0 -> v2.13.0.0
[00042638]Packet upgrade failed at version checking.
[00015313]========== remo-con disconnect. boot(15) ============
[00015366]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x98a5e888].
[00015413]Packet upgrade start...
[00015472]Packet checking...
[00015520]Packet vlink 01.06.0040 <-> 01.05.0030.
[00015570]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015618]Done.
[00015744]Version checking[1]...
[00015830][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015915][03 06][00] v2.4.0.5 -> v2.4.10.7 need upgrade.
[00015983][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016095][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[00016204][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016304][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016405][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016504][12 03][00] v1.10.0.0 -> v1.10.0.0
[00029052][15 00][00] device not detected.
[00029159][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029285][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029366][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029414][01 00][00] v1.26.4315 -> v1.26.4315
[00029463][01 01][00] v1.26.4315 -> v1.26.4315
[00042018][08 00][00] device not detected.
[00042086][09 00][00] v2.13.0.0 -> v2.13.0.0
[00042137]Done.
[00044194]Waiting for user confirm...
[00054240]Timeout, start upgrade automatically.
[00054338]Firmware upgrading[1]...
[00054393][11 00] Firmware upgrade start...
[00102195][11 00] Firmware upgrade finished successfully.
[00102437][03 06] Firmware upgrade start...
[00429425][03 06] Firmware upgrade finished successfully.
[00429475]Done.
[00429526]Version checking[2]...
[00429610][03 05][00] v34.2.0.9 -> v34.2.0.9
[00429690][03 06][05] v2.4.10.7 -> v2.4.10.7
[00429753][04 00][00] v1.41.0.0 -> v1.41.0.0
[00429892][11 00][05] v1.7.15.1 -> v1.7.15.1
[00430005][12 00][00] v1.10.0.0 -> v1.10.0.0
[00430110][12 01][00] v1.10.0.0 -> v1.10.0.0
[00430211][12 02][00] v1.10.0.0 -> v1.10.0.0
[00430310][12 03][00] v1.10.0.0 -> v1.10.0.0
[00442863][15 00][00] device not detected.
[00442955][17 00][00] v1.1.1.7 -> v1.1.1.7
[00443085][17 01][00] v1.0.2.7 -> v1.0.2.7
[00443151][19 00][00] v1.0.8.96 -> v1.0.8.96
[00443202][01 00][00] v1.26.4315 -> v1.26.4315
[00443259][01 01][00] v1.26.4315 -> v1.26.4315
[00455806][08 00][00] device not detected.
[00455872][09 00][00] v2.13.0.0 -> v2.13.0.0
[00455928]Packet upgrade failed at version checking.
[00015470]========== remo-con disconnect. boot(15) ============
[00015614]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x98a5e888].
[00015669]Packet upgrade start...
[00015740]Packet checking...
[00015788]Packet vlink 01.06.0040 <-> 01.05.0030.
[00015839]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015889]Done.
[00015942]Version checking[1]...
[00016032][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016111][03 06][00] v2.4.10.7 -> v2.4.10.7
[00016172][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016287][11 00][00] v1.7.15.1 -> v1.7.15.1
[00016395][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016487][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016587][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016687][12 03][00] v1.10.0.0 -> v1.10.0.0
[00029245][15 00][00] device not detected.
[00029336][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029476][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029556][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029608][01 00][00] v1.26.4315 -> v1.26.4315
[00029659][01 01][00] v1.26.4315 -> v1.26.4315
[00042225][08 00][00] device not detected.
[00042296][09 00][00] v2.13.0.0 -> v2.13.0.0
[00042347]Packet upgrade failed at version checking.
[00015352]========== remo-con disconnect. boot(15) ============
[00015406]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x98a5e888].
[00015457]Packet upgrade start...
[00015512]Packet checking...
[00015570]Packet vlink 01.05.0030 <-> 01.04.0010.
[00015621]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015674]Done.
[00015733]Version checking[1]...
[00015818][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015918][03 06][00] v2.4.10.7 -> v2.4.0.5
[00015975][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016118][11 00][00] v1.7.0.0 -> v1.7.0.0
[00016226][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016328][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016426][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016531][12 03][00] v1.10.0.0 -> v1.10.0.0
[00029081][15 00][00] device not detected.
[00029187][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029338][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029499][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029556][01 00][00] v1.26.4315 -> v1.26.4315
[00029611][01 01][00] v1.26.4315 -> v1.26.4315
[00042162][08 00][00] device not detected.
[00042239][09 00][00] v2.13.0.0 -> v2.13.0.0
[00042292]Packet upgrade failed at version checking.
[00016110]========== remo-con disconnect. boot(15) ============
[00016165]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x98a5e888].
[00016212]Packet upgrade start...
[00016275]Packet checking...
[00016327]Packet vlink 01.04.0010 <-> 01.03.0020.
[00016377]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00016432]Done.
[00016481]Version checking[1]...
[00016583][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016683][03 06][00] v2.4.10.7 -> v2.3.0.13
[00016749][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016825][09 00][00] v2.13.0.0 -> v1.7.0.3
[00016968][11 00][00] v1.7.0.0 -> v1.7.0.0
[00017083][12 00][00] v1.10.0.0 -> v1.10.0.0
[00017192][12 01][00] v1.10.0.0 -> v1.10.0.0
[00017292][12 02][00] v1.10.0.0 -> v1.10.0.0
[00017393][12 03][00] v1.10.0.0 -> v1.10.0.0
[00029947][15 00][00] device not detected.
[00030053][17 00][00] v1.1.1.7 -> v1.1.1.7
[00030194][17 01][00] v1.0.2.7 -> v1.0.2.7
[00030265][19 00][00] v1.0.8.96 -> v1.0.8.96
[00030320][01 00][00] v1.26.4315 -> v1.23.3419
[00030374][01 01][00] v1.26.4315 -> v1.23.3419
[00042923][08 00][00] device not detected.
[00042977]Packet upgrade failed at version checking.
[00014488]========== remo-con disconnect. boot(15) ============
[00014530]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0xbd86065d].
[00014575]Packet upgrade start...
[00014626]Packet checking...
[00014672]Packet vlink 01.06.0040 <-> 01.05.0030.
[00014715]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014755]Done.
[00014803]Version checking[1]...
[00014896][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014996][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015057][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015176][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[00015372][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015496][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015600][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015706][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028252][15 00][00] device not detected.
[00028366][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028506][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028572][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028616][01 00][00] v1.26.4315 -> v1.26.4315
[00028668][01 01][00] v1.26.4315 -> v1.26.4315
[00041212][08 00][00] device not detected.
[00041292][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041340]Done.
[00043382]Waiting for user confirm...
[00053427]Timeout, start upgrade automatically.
[00053520]Firmware upgrading[1]...
[00053567][11 00] Firmware upgrade start...
[00101236][11 00] Firmware upgrade finished successfully.
[00101278]Done.
[00101325]Version checking[2]...
[00101407][03 05][00] v34.2.0.9 -> v34.2.0.9
[00101506][03 06][00] v2.4.10.7 -> v2.4.10.7
[00101564][04 00][00] v1.41.0.0 -> v1.41.0.0
[00101682][11 00][05] v1.7.15.1 -> v1.7.15.1
[00101790][12 00][00] v1.10.0.0 -> v1.10.0.0
[00101890][12 01][00] v1.10.0.0 -> v1.10.0.0
[00101990][12 02][00] v1.10.0.0 -> v1.10.0.0
[00102117][12 03][00] v1.10.0.0 -> v1.10.0.0
[00114664][15 00][00] device not detected.
[00114772][17 00][00] v1.1.1.7 -> v1.1.1.7
[00114911][17 01][00] v1.0.2.7 -> v1.0.2.7
[00114976][19 00][00] v1.0.8.96 -> v1.0.8.96
[00115021][01 00][00] v1.26.4315 -> v1.26.4315
[00115072][01 01][00] v1.26.4315 -> v1.26.4315
[00127620][08 00][00] device not detected.
[00127676][09 00][00] v2.13.0.0 -> v2.13.0.0
[00127727]Packet upgrade failed at version checking.
[00014521]========== remo-con disconnect. boot(15) ============
[00014565]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0xbd86065d].
[00014613]Packet upgrade start...
[00014659]Packet checking...
[00014701]Packet vlink 01.06.0040 <-> 01.05.0030.
[00014745]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014878]Done.
[00014928]Version checking[1]...
[00015011][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015111][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015166][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015290][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015379][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015479][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015579][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015679][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028226][15 00][00] device not detected.
[00028320][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028454][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028510][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028555][01 00][00] v1.26.4315 -> v1.26.4315
[00028606][01 01][00] v1.26.4315 -> v1.26.4315
[00041150][08 00][00] device not detected.
[00041211][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041258]Packet upgrade failed at version checking.
[00014524]========== remo-con disconnect. boot(15) ============
[00014567]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0xbd86065d].
[00014621]Packet upgrade start...
[00014667]Packet checking...
[00014712]Packet vlink 01.06.0040 <-> 01.05.0030.
[00014761]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014803]Done.
[00014852]Version checking[1]...
[00014924][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015001][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015063][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015186][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015301][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015401][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015510][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015600][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028147][15 00][00] device not detected.
[00028232][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028352][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028410][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028462][01 00][00] v1.26.4315 -> v1.26.4315
[00028509][01 01][00] v1.26.4315 -> v1.26.4315
[00041054][08 00][00] device not detected.
[00041116][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041160]Packet upgrade failed at version checking.
[00014762]========== remo-con disconnect. boot(15) ============
[00014814]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x98a5e888].
[00014876]Packet upgrade start...
[00014941]Packet checking...
[00014993]Packet vlink 01.06.0040 <-> 01.05.0030.
[00015052]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015109]Done.
[00015167]Version checking[1]...
[00015261][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015381][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015445][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015580][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015685][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015785][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015885][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015985][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028545][15 00][00] device not detected.
[00028646][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028766][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028832][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028891][01 00][00] v1.26.4315 -> v1.26.4315
[00028950][01 01][00] v1.26.4315 -> v1.26.4315
[00041503][08 00][00] device not detected.
[00041592][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041644]Packet upgrade failed at version checking.
[00014510]========== remo-con disconnect. boot(15) ============
[00014555]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0xbd86065d].
[00014607]Packet upgrade start...
[00014656]Packet checking...
[00014701]Packet vlink 01.05.0030 <-> 01.04.0010.
[00014752]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014798]Done.
[00014847]Version checking[1]...
[00014928][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015007][03 06][00] v2.4.10.7 -> v2.4.0.5
[00015068][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015188][11 00][00] v1.7.15.1 -> v1.7.0.0
[00015291][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015387][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015491][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015587][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028134][15 00][00] device not detected.
[00028234][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028462][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028532][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028579][01 00][00] v1.26.4315 -> v1.26.4315
[00028632][01 01][00] v1.26.4315 -> v1.26.4315
[00041179][08 00][00] device not detected.
[00041273][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041316]Packet upgrade failed at version checking.
[00014522]========== 2015.12.27 23:52:20. boot(15) ============
[00014566]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0xbd86065d].
[00014609]Packet upgrade start...
[00014789]Done.
[00014834]Version checking[1]...
[00014916][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015016][03 06][00] v2.4.10.7 -> v2.4.0.5
[00015075][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015196][11 00][00] v1.7.15.1 -> v1.7.0.0
[00015305][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015405][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015505][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015605][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028150][15 00][00] device not detected.
[00028245][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028369][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028433][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028477][01 00][00] v1.26.4315 -> v1.26.4315
[00028521][01 01][00] v1.26.4315 -> v1.26.4315
[00041065][08 00][00] device not detected.
[00041140][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041183]Packet upgrade failed at version checking.
[00014559]========== remo-con disconnect. boot(15) ============
[00014605]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0xbd86065d].
[00014660]Packet upgrade start...
[00014710]Packet checking...
[00014757]Packet vlink 01.06.0040 <-> 01.05.0030.
[00014810]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014858]Done.
[00014904]Version checking[1]...
[00015001][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015102][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015161][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015382][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015470][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015570][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015670][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015770][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028321][15 00][00] device not detected.
[00028425][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028565][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028626][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028675][01 00][00] v1.26.4315 -> v1.26.4315
[00028724][01 01][00] v1.26.4315 -> v1.26.4315
[00041271][08 00][00] device not detected.
[00041340][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041386]Packet upgrade failed at version checking.
[00014572]========== remo-con disconnect. boot(15) ============
[00014624]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0xbd86065d].
[00014673]Packet upgrade start...
[00014721]Packet checking...
[00014770]Packet vlink 01.06.0040 <-> 01.05.0030.
[00014823]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014872]Done.
[00014919]Version checking[1]...
[00015003][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015103][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015165][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015283][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015371][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015471][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015571][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015671][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028219][15 00][00] device not detected.
[00028332][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028477][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028548][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028598][01 00][00] v1.26.4315 -> v1.26.4315
[00028649][01 01][00] v1.26.4315 -> v1.26.4315
[00041201][08 00][00] device not detected.
[00041288][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041342]Packet upgrade failed at version checking.
[00014556]========== remo-con disconnect. boot(15) ============
[00014608]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0xbd86065d].
[00014659]Packet upgrade start...
[00014798]Packet checking...
[00014850]Packet vlink 01.06.0040 <-> 01.05.0030.
[00014896]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014951]Done.
[00014996]Version checking[1]...
[00015097][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015183][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015257][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015378][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015485][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015585][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015685][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015785][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028332][15 00][00] device not detected.
[00028430][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028576][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028662][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028710][01 00][00] v1.26.4315 -> v1.26.4315
[00028765][01 01][00] v1.26.4315 -> v1.26.4315
[00041311][08 00][00] device not detected.
[00041382][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041431]Packet upgrade failed at version checking.
[00014628]========== remo-con disconnect. boot(15) ============
[00014679]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0xbd86065d].
[00014726]Packet upgrade start...
[00014783]Packet checking...
[00014835]Packet vlink 01.06.0040 <-> 01.05.0030.
[00014887]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014943]Done.
[00014990]Version checking[1]...
[00015092][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015173][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015244][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015376][11 00][00] v1.7.15.1 -> v1.7.15.1
[00028337][15 00][00] device not detected.
[00028440][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028581][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028656][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028704][01 00][00] v1.26.4315 -> v1.26.4315
[00028760][01 01][00] v1.26.4315 -> v1.26.4315
[00041399][08 00][00] device not detected.
[00041499][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041548]Packet upgrade failed at version checking.
[00014612]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xbd86065d].
[00014661]Packet upgrade start...
[00014714]Packet checking...
[00014769]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014821]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014876]Done.
[00014930]Version checking[1]...
[00015027][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015125][03 06][00] v2.4.10.7 -> v2.3.0.13
[00015184][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015279][09 00][00] v2.13.0.0 -> v1.7.0.3
[00015412][11 00][00] v1.7.15.1 -> v1.7.0.0
[00015525][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015633][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015733][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015833][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028384][15 00][00] device not detected.
[00028515][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028655][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028720][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028775][01 00][00] v1.26.4315 -> v1.23.3419
[00028829][01 01][00] v1.26.4315 -> v1.23.3419
[00041378][08 00][00] device not detected.
[00041429]Packet upgrade failed at version checking.
[00014791]========== remo-con disconnect. boot(15) ============
[00014849]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x98a5e888].
[00014911]Packet upgrade start...
[00014979]Packet checking...
[00015042]Packet vlink 01.06.0040 <-> 01.05.0030.
[00015100]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015156]Done.
[00015218]Version checking[1]...
[00015318][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015418][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015487][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015638][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015752][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015852][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015978][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016166][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028731][15 00][00] device not detected.
[00028833][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028988][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029064][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029125][01 00][00] v1.26.4315 -> v1.26.4315
[00029184][01 01][00] v1.26.4315 -> v1.26.4315
[00041749][08 00][00] device not detected.
[00041823][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041880]Packet upgrade failed at version checking.
[00014824]========== remo-con disconnect. boot(15) ============
[00014885]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x98a5e888].
[00014944]Packet upgrade start...
[00015009]Packet checking...
[00015073]Packet vlink 01.06.0040 <-> 01.05.0030.
[00015134]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015197]Done.
[00015251]Version checking[1]...
[00015345][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015445][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015512][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015645][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015749][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015849][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015949][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016049][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028610][15 00][00] device not detected.
[00028696][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028840][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028915][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028979][01 00][00] v1.26.4315 -> v1.26.4315
[00029042][01 01][00] v1.26.4315 -> v1.26.4315
[00041598][08 00][00] device not detected.
[00041676][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041742]Packet upgrade failed at version checking.
[00014613]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0xbd86065d].
[00014665]Packet upgrade start...
[00014719]Packet checking...
[00014777]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014829]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).
[00014882]Done.
[00015026]Version checking[1]...
[00015112][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015198][03 06][00] v2.4.10.7 -> v2.2.6.19 need upgrade.
[00015279][04 00][00] v1.41.0.0 -> v1.40.0.0 need upgrade.
[00015356][09 00][00] v2.13.0.0 -> v1.7.0.3
[00015492][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015582][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015680][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015780][12 02][00] v1.10.0.0 -> v1.8.0.0
[00015892][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028452][15 00][00] device not detected.
[00028547][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028682][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028762][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028811][01 00][00] v1.26.4315 -> v1.23.3419
[00028866][01 01][00] v1.26.4315 -> v1.23.3419
[00041418][08 00][00] device not detected.
[00041476]Done.
[00043525]Waiting for user confirm...
[00053578]Timeout, start upgrade automatically.
[00053689]Firmware upgrading[1]...
[00053893][03 06] Firmware upgrade start...
[00355302][03 06] Firmware upgrade finished successfully.
[00355375][04 00] Firmware upgrade start...
[00412385][04 00] Firmware upgrade finished successfully.
[00412437]Done.
[00412493]Version checking[2]...
[00412575][03 05][00] v34.2.0.9 -> v34.2.0.9
[00412680][03 06][05] v2.2.6.19 -> v2.2.6.19
[00412747][04 00][05] v1.40.0.0 -> v1.40.0.0
[00412820][09 00][00] v2.13.0.0 -> v1.7.0.3
[00412942][11 00][00] v1.7.0.0 -> v1.7.0.0
[00413051][12 00][00] v1.10.0.0 -> v1.8.0.0
[00413151][12 01][00] v1.10.0.0 -> v1.8.0.0
[00413251][12 02][00] v1.10.0.0 -> v1.8.0.0
[00413351][12 03][00] v1.10.0.0 -> v1.8.0.0
[00425902][15 00][00] device not detected.
[00426006][17 00][00] v1.1.1.7 -> v1.1.1.7
[00426151][17 01][00] v1.0.2.7 -> v1.0.2.7
[00426221][19 00][00] v1.0.8.96 -> v1.0.8.96
[00426273][01 00][00] v1.26.4315 -> v1.23.3419
[00426333][01 01][00] v1.26.4315 -> v1.23.3419
[00438884][08 00][00] device not detected.
[00438937]Packet upgrade failed at version checking.
[00014565]========== remo-con disconnect. boot(15) ============
[00014694]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0xbd86065d].
[00014754]Packet upgrade start...
[00014809]Packet checking...
[00014862]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014922]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).
[00014977]Done.
[00015029]Version checking[1]...
[00015127][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015227][03 06][00] v2.2.6.19 -> v2.2.6.19
[00015292][04 00][00] v1.40.0.0 -> v1.40.0.0
[00015367][09 00][00] v2.13.0.0 -> v1.7.0.3
[00015508][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015618][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015717][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015817][12 02][00] v1.10.0.0 -> v1.8.0.0
[00015917][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028469][15 00][00] device not detected.
[00028573][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028738][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028808][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028865][01 00][00] v1.26.4315 -> v1.23.3419
[00028926][01 01][00] v1.26.4315 -> v1.23.3419
[00041478][08 00][00] device not detected.
[00041532]Packet upgrade failed at version checking.
[00014579]========== remo-con disconnect. boot(15) ============
[00014631]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xbd86065d].
[00014685]Packet upgrade start...
[00014746]Packet checking...
[00014796]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014853]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014912]Done.
[00014962]Version checking[1]...
[00015069][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015168][03 06][00] v2.2.6.19 -> v2.3.0.13 need upgrade.
[00015245][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[00015308][09 00][00] v2.13.0.0 -> v1.7.0.3
[00015453][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015562][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015689][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015799][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015923][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028479][15 00][00] device not detected.
[00028579][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028824][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028890][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028947][01 00][00] v1.26.4315 -> v1.23.3419
[00029001][01 01][00] v1.26.4315 -> v1.23.3419
[00041561][08 00][00] device not detected.
[00041620]Done.
[00043675]Waiting for user confirm...
[00053728]Timeout, start upgrade automatically.
[00053843]Firmware upgrading[1]...
[00054063][03 06] Firmware upgrade start...
[00370405][03 06] Firmware upgrade finished successfully.
[00370484][04 00] Firmware upgrade start...
[00428064][04 00] Firmware upgrade finished successfully.
[00428120]Done.
[00428177]Version checking[2]...
[00428315][03 05][00] v34.2.0.9 -> v34.2.0.9
[00428420][03 06][05] v2.3.0.13 -> v2.3.0.13
[00428479][04 00][05] v1.41.0.0 -> v1.41.0.0
[00428553][09 00][00] v2.13.0.0 -> v1.7.0.3
[00428693][11 00][00] v1.7.0.0 -> v1.7.0.0
[00428814][12 00][00] v1.10.0.0 -> v1.10.0.0
[00428922][12 01][00] v1.10.0.0 -> v1.10.0.0
[00429022][12 02][00] v1.10.0.0 -> v1.10.0.0
[00429122][12 03][00] v1.10.0.0 -> v1.10.0.0
[00441679][15 00][00] device not detected.
[00441784][17 00][00] v1.1.1.7 -> v1.1.1.7
[00441944][17 01][00] v1.0.2.7 -> v1.0.2.7
[00442014][19 00][00] v1.0.8.96 -> v1.0.8.96
[00442071][01 00][00] v1.26.4315 -> v1.23.3419
[00442122][01 01][00] v1.26.4315 -> v1.23.3419
[00454683][08 00][00] device not detected.
[00454734]Packet upgrade failed at version checking.
[00014598]========== remo-con disconnect. boot(15) ============
[00014655]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0xbd86065d].
[00014710]Packet upgrade start...
[00014767]Packet checking...
[00014820]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014877]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).
[00014932]Done.
[00014987]Version checking[1]...
[00015095][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015175][03 06][00] v2.3.0.13 -> v2.2.6.19 need upgrade.
[00015254][04 00][00] v1.41.0.0 -> v1.40.0.0 need upgrade.
[00015412][09 00][00] v2.13.0.0 -> v1.7.0.3
[00015559][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015648][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015748][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015849][12 02][00] v1.10.0.0 -> v1.8.0.0
[00015951][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028505][15 00][00] device not detected.
[00028603][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028744][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028829][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028884][01 00][00] v1.26.4315 -> v1.23.3419
[00028945][01 01][00] v1.26.4315 -> v1.23.3419
[00041501][08 00][00] device not detected.
[00041554]Done.
[00043615]Waiting for user confirm...
[00053672]Timeout, start upgrade automatically.
[00053787]Firmware upgrading[1]...
[00053993][03 06] Firmware upgrade start...
[00354058][03 06] Firmware upgrade finished successfully.
[00354141][04 00] Firmware upgrade start...
[00410959][04 00] Firmware upgrade finished successfully.
[00411020]Done.
[00411078]Version checking[2]...
[00411169][03 05][00] v34.2.0.9 -> v34.2.0.9
[00411247][03 06][05] v2.2.6.19 -> v2.2.6.19
[00411314][04 00][05] v1.40.0.0 -> v1.40.0.0
[00411393][09 00][00] v2.13.0.0 -> v1.7.0.3
[00411527][11 00][00] v1.7.0.0 -> v1.7.0.0
[00411622][12 00][00] v1.10.0.0 -> v1.8.0.0
[00411742][12 01][00] v1.10.0.0 -> v1.8.0.0
[00411842][12 02][00] v1.10.0.0 -> v1.8.0.0
[00411942][12 03][00] v1.10.0.0 -> v1.8.0.0
[00424503][15 00][00] device not detected.
[00424593][17 00][00] v1.1.1.7 -> v1.1.1.7
[00424742][17 01][00] v1.0.2.7 -> v1.0.2.7
[00424813][19 00][00] v1.0.8.96 -> v1.0.8.96
[00424873][01 00][00] v1.26.4315 -> v1.23.3419
[00424930][01 01][00] v1.26.4315 -> v1.23.3419
[00437500][08 00][00] device not detected.
[00437552]Packet upgrade failed at version checking.
[00014597]========== remo-con disconnect. boot(15) ============
[00014711]Packet upgrade start...
[00014823]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014968]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).
[00015025]Done.
[00015087]Version checking[1]...
[00015189][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015309][03 06][00] v2.2.6.19 -> v2.2.6.19
[00015370][04 00][00] v1.40.0.0 -> v1.40.0.0
[00015464][09 00][00] v2.13.0.0 -> v1.7.0.3
[00015610][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015724][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015824][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015945][12 02][00] v1.10.0.0 -> v1.8.0.0
[00016069][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028627][15 00][00] device not detected.
[00028740][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028899][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028987][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029044][01 00][00] v1.26.4315 -> v1.23.3419
[00029106][01 01][00] v1.26.4315 -> v1.23.3419
[00041663][08 00][00] device not detected.
[00041720]Packet upgrade failed at version checking.
[00014600]========== remo-con disconnect. boot(15) ============
[00014659]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xbd86065d].
[00014716]Packet upgrade start...
[00014779]Packet checking...
[00014835]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014892]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014954]Done.
[00015011]Version checking[1]...
[00015212][03 06][00] v2.2.6.19 -> v2.3.0.13 need upgrade.
[00015292][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[00015532][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015647][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015768][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015893][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016002][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028561][15 00][00] device not detected.
[00028669][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028891][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028951][01 00][00] v1.26.4315 -> v1.23.3419
[00029006][01 01][00] v1.26.4315 -> v1.23.3419
[00041642][08 00][00] device not detected.
[00041694]Done.
[00043752]Waiting for user confirm...
[00053817]Timeout, start upgrade automatically.
[00053929]Firmware upgrading[1]...
[00054154][03 06] Firmware upgrade start...
[00359782][03 06] Firmware upgrade finished successfully.
[00359861][04 00] Firmware upgrade start...
[00417475][04 00] Firmware upgrade finished successfully.
[00417534]Done.
[00417592]Version checking[2]...
[00417717][03 05][00] v34.2.0.9 -> v34.2.0.9
[00417819][03 06][05] v2.3.0.13 -> v2.3.0.13
[00417882][04 00][05] v1.41.0.0 -> v1.41.0.0
[00417951][09 00][00] v2.13.0.0 -> v1.7.0.3
[00418098][11 00][00] v1.7.0.0 -> v1.7.0.0
[00418227][12 00][00] v1.10.0.0 -> v1.10.0.0
[00418352][12 01][00] v1.10.0.0 -> v1.10.0.0
[00418472][12 02][00] v1.10.0.0 -> v1.10.0.0
[00418586][12 03][00] v1.10.0.0 -> v1.10.0.0
[00431143][15 00][00] device not detected.
[00431267][17 00][00] v1.1.1.7 -> v1.1.1.7
[00431427][17 01][00] v1.0.2.7 -> v1.0.2.7
[00431498][19 00][00] v1.0.8.96 -> v1.0.8.96
[00431554][01 00][00] v1.26.4315 -> v1.23.3419
[00431609][01 01][00] v1.26.4315 -> v1.23.3419
[00444177][08 00][00] device not detected.
[00444233]Packet upgrade failed at version checking.
[00014620]========== remo-con disconnect. boot(15) ============
[00014678]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0xbd86065d].
[00014732]Packet upgrade start...
[00014796]Packet checking...
[00014856]Packet vlink 01.05.0030 <-> 01.04.0010.
[00014915]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014971]Done.
[00015133][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015237][03 06][00] v2.3.0.13 -> v2.4.0.5 need upgrade.
[00015304][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015454][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015561][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015681][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015783][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015906][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028552][15 00][00] device not detected.
[00028662][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028822][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028894][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028948][01 00][00] v1.26.4315 -> v1.26.4315
[00029013][01 01][00] v1.26.4315 -> v1.26.4315
[00041574][08 00][00] device not detected.
[00041674][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041728]Done.
[00043786]Waiting for user confirm...
[00053851]Timeout, start upgrade automatically.
[00053964]Firmware upgrading[1]...
[00054194][03 06] Firmware upgrade start...
[00368006][03 06] Firmware upgrade finished successfully.
[00368066]Done.
[00368120]Version checking[2]...
[00368213][03 05][00] v34.2.0.9 -> v34.2.0.9
[00368354][03 06][05] v2.4.0.5 -> v2.4.0.5
[00368422][04 00][00] v1.41.0.0 -> v1.41.0.0
[00368577][11 00][00] v1.7.0.0 -> v1.7.0.0
[00368707][12 00][00] v1.10.0.0 -> v1.10.0.0
[00368827][12 01][00] v1.10.0.0 -> v1.10.0.0
[00368954][12 02][00] v1.10.0.0 -> v1.10.0.0
[00369064][12 03][00] v1.10.0.0 -> v1.10.0.0
[00381620][15 00][00] device not detected.
[00381723][17 00][00] v1.1.1.7 -> v1.1.1.7
[00381863][17 01][00] v1.0.2.7 -> v1.0.2.7
[00381933][19 00][00] v1.0.8.96 -> v1.0.8.96
[00381997][01 00][00] v1.26.4315 -> v1.26.4315
[00382058][01 01][00] v1.26.4315 -> v1.26.4315
[00394623][08 00][00] device not detected.
[00394694][09 00][00] v2.13.0.0 -> v2.13.0.0
[00394751]Packet upgrade failed at version checking.
[00014627]========== remo-con disconnect. boot(15) ============
[00014686]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xbd86065d].
[00014745]Packet upgrade start...
[00014806]Packet checking...
[00014866]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014926]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014989]Done.
[00015050]Version checking[1]...
[00015132][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015212][03 06][00] v2.4.0.5 -> v2.3.0.13
[00015293][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015366][09 00][00] v2.13.0.0 -> v1.7.0.3
[00015597][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015726][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015827][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015926][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016026][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028588][15 00][00] device not detected.
[00028702][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028847][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028927][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028986][01 00][00] v1.26.4315 -> v1.23.3419
[00029045][01 01][00] v1.26.4315 -> v1.23.3419
[00041604][08 00][00] device not detected.
[00041667]Packet upgrade failed at version checking.
[00014735]========== remo-con disconnect. boot(15) ============
[00014800]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0xbd86065d].
[00014862]Packet upgrade start...
[00014924]Packet checking...
[00014991]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015053]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).
[00015118]Done.
[00015179]Version checking[1]...
[00015283][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015403][03 06][00] v2.4.0.5 -> v2.2.6.19 need upgrade.
[00015486][04 00][00] v1.41.0.0 -> v1.40.0.0 need upgrade.
[00015572][09 00][00] v2.13.0.0 -> v1.7.0.3
[00015738][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015837][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015937][12 01][00] v1.10.0.0 -> v1.8.0.0
[00016037][12 02][00] v1.10.0.0 -> v1.8.0.0
[00016137][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028698][15 00][00] device not detected.
[00028808][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028956][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029034][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029094][01 00][00] v1.26.4315 -> v1.23.3419
[00029154][01 01][00] v1.26.4315 -> v1.23.3419
[00041713][08 00][00] device not detected.
[00041773]Done.
[00043835]Waiting for user confirm...
[00053892]Timeout, start upgrade automatically.
[00054012]Firmware upgrading[1]...
[00054224][03 06] Firmware upgrade start...
[00343802][03 06] Firmware upgrade finished successfully.
[00343882][04 00] Firmware upgrade start...
[00400750][04 00] Firmware upgrade finished successfully.
[00400812]Done.
[00400880]Version checking[2]...
[00400980][03 05][00] v34.2.0.9 -> v34.2.0.9
[00401100][03 06][05] v2.2.6.19 -> v2.2.6.19
[00401174][04 00][05] v1.40.0.0 -> v1.40.0.0
[00401277][09 00][00] v2.13.0.0 -> v1.7.0.3
[00401420][11 00][00] v1.7.0.0 -> v1.7.0.0
[00401560][12 00][00] v1.10.0.0 -> v1.8.0.0
[00401670][12 01][00] v1.10.0.0 -> v1.8.0.0
[00401798][12 02][00] v1.10.0.0 -> v1.8.0.0
[00401926][12 03][00] v1.10.0.0 -> v1.8.0.0
[00414491][15 00][00] device not detected.
[00414611][17 00][00] v1.1.1.7 -> v1.1.1.7
[00414766][17 01][00] v1.0.2.7 -> v1.0.2.7
[00414836][19 00][00] v1.0.8.96 -> v1.0.8.96
[00414901][01 00][00] v1.26.4315 -> v1.23.3419
[00414963][01 01][00] v1.26.4315 -> v1.23.3419
[00427531][08 00][00] device not detected.
[00427592]Packet upgrade failed at version checking.
[00014659]========== remo-con disconnect. boot(15) ============
[00014721]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0xbd86065d].
[00014787]Packet upgrade start...
[00014851]Packet checking...
[00014914]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014974]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).
[00015035]Done.
[00015096]Version checking[1]...
[00015199][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015319][03 06][00] v2.2.6.19 -> v2.2.6.19
[00015390][04 00][00] v1.40.0.0 -> v1.40.0.0
[00015480][09 00][00] v2.13.0.0 -> v1.7.0.3
[00015620][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015754][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015874][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015999][12 02][00] v1.10.0.0 -> v1.8.0.0
[00016109][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028670][15 00][00] device not detected.
[00028797][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028954][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029041][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029103][01 00][00] v1.26.4315 -> v1.23.3419
[00029169][01 01][00] v1.26.4315 -> v1.23.3419
[00041738][08 00][00] device not detected.
[00041892]Packet upgrade failed at version checking.
[00014667]========== remo-con disconnect. boot(15) ============
[00014729]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xbd86065d].
[00014796]Packet upgrade start...
[00014862]Packet checking...
[00014925]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014993]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015057]Done.
[00015123]Version checking[1]...
[00015224][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015345][03 06][00] v2.2.6.19 -> v2.3.0.13 need upgrade.
[00015412][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[00015512][09 00][00] v2.13.0.0 -> v1.7.0.3
[00015646][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015759][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015885][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016004][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016119][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028684][15 00][00] device not detected.
[00029031][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029093][01 00][00] v1.26.4315 -> v1.23.3419
[00029155][01 01][00] v1.26.4315 -> v1.23.3419
[00041716][08 00][00] device not detected.
[00041778]Done.
[00043847]Waiting for user confirm...
[00053914]Timeout, start upgrade automatically.
[00054043]Firmware upgrading[1]...
[00054270][03 06] Firmware upgrade start...
[00369106][03 06] Firmware upgrade finished successfully.
[00369193][04 00] Firmware upgrade start...
[00426677][04 00] Firmware upgrade finished successfully.
[00426744]Done.
[00426807]Version checking[2]...
[00426905][03 05][00] v34.2.0.9 -> v34.2.0.9
[00427005][03 06][05] v2.3.0.13 -> v2.3.0.13
[00427090][04 00][05] v1.41.0.0 -> v1.41.0.0
[00427174][09 00][00] v2.13.0.0 -> v1.7.0.3
[00427365][11 00][00] v1.7.0.0 -> v1.7.0.0
[00427480][12 00][00] v1.10.0.0 -> v1.10.0.0
[00427580][12 01][00] v1.10.0.0 -> v1.10.0.0
[00427699][12 02][00] v1.10.0.0 -> v1.10.0.0
[00427814][12 03][00] v1.10.0.0 -> v1.10.0.0
[00440451][15 00][00] device not detected.
[00440555][17 00][00] v1.1.1.7 -> v1.1.1.7
[00440695][17 01][00] v1.0.2.7 -> v1.0.2.7
[00440795][19 00][00] v1.0.8.96 -> v1.0.8.96
[00440861][01 00][00] v1.26.4315 -> v1.23.3419
[00440929][01 01][00] v1.26.4315 -> v1.23.3419
[00453491][08 00][00] device not detected.
[00453554]Packet upgrade failed at version checking.
[00014658]========== remo-con disconnect. boot(15) ============
[00014722]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0xbd86065d].
[00014789]Packet upgrade start...
[00014855]Packet checking...
[00014924]Packet vlink 01.05.0030 <-> 01.04.0010.
[00014987]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015052]Done.
[00015120]Version checking[1]...
[00015218][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015337][03 06][00] v2.3.0.13 -> v2.4.0.5 need upgrade.
[00015404][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015558][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015682][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015807][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015933][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016052][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028620][15 00][00] device not detected.
[00028723][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028888][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028975][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029040][01 00][00] v1.26.4315 -> v1.26.4315
[00029108][01 01][00] v1.26.4315 -> v1.26.4315
[00041671][08 00][00] device not detected.
[00041755][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041824]Done.
[00043894]Waiting for user confirm...
[00053961]Timeout, start upgrade automatically.
[00054089]Firmware upgrading[1]...
[00054326][03 06] Firmware upgrade start...
[00376809][03 06] Firmware upgrade finished successfully.
[00376872]Done.
[00376940]Version checking[2]...
[00377037][03 05][00] v34.2.0.9 -> v34.2.0.9
[00377136][03 06][05] v2.4.0.5 -> v2.4.0.5
[00377202][04 00][00] v1.41.0.0 -> v1.41.0.0
[00377380][11 00][00] v1.7.0.0 -> v1.7.0.0
[00377614][12 00][00] v1.10.0.0 -> v1.10.0.0
[00377749][12 01][00] v1.10.0.0 -> v1.10.0.0
[00377884][12 02][00] v1.10.0.0 -> v1.10.0.0
[00378009][12 03][00] v1.10.0.0 -> v1.10.0.0
[00390576][15 00][00] device not detected.
[00390705][17 00][00] v1.1.1.7 -> v1.1.1.7
[00390865][17 01][00] v1.0.2.7 -> v1.0.2.7
[00390955][19 00][00] v1.0.8.96 -> v1.0.8.96
[00391021][01 00][00] v1.26.4315 -> v1.26.4315
[00391084][01 01][00] v1.26.4315 -> v1.26.4315
[00403656][08 00][00] device not detected.
[00403757][09 00][00] v2.13.0.0 -> v2.13.0.0
[00403825]Packet upgrade failed at version checking.
[00014665]========== remo-con disconnect. boot(15) ============
[00014728]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0xbd86065d].
[00014863]Packet checking...
[00014933]Packet vlink 01.06.0040 <-> 01.05.0030.
[00014995]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015061]Done.
[00015131]Version checking[1]...
[00015324][03 06][00] v2.4.0.5 -> v2.4.10.7 need upgrade.
[00015394][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015544][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[00015658][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015757][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015877][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016003][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028567][15 00][00] device not detected.
[00028694][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028839][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028914][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029045][01 01][00] v1.26.4315 -> v1.26.4315
[00041614][08 00][00] device not detected.
[00041714][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041789]Done.
[00043855]Waiting for user confirm...
[00053919]Timeout, start upgrade automatically.
[00054053]Firmware upgrading[1]...
[00054129][11 00] Firmware upgrade start...
[00099209][11 00] Firmware upgrade finished successfully.
[00099519][03 06] Firmware upgrade start...
[00415933][03 06] Firmware upgrade finished successfully.
[00416002]Done.
[00416067]Version checking[2]...
[00416174][03 05][00] v34.2.0.9 -> v34.2.0.9
[00416312][03 06][05] v2.4.10.7 -> v2.4.10.7
[00416384][04 00][00] v1.41.0.0 -> v1.41.0.0
[00416529][11 00][05] v1.7.15.1 -> v1.7.15.1
[00416646][12 00][00] v1.10.0.0 -> v1.10.0.0
[00416774][12 01][00] v1.10.0.0 -> v1.10.0.0
[00416878][12 02][00] v1.10.0.0 -> v1.10.0.0
[00416980][12 03][00] v1.10.0.0 -> v1.10.0.0
[00429546][15 00][00] device not detected.
[00429659][17 00][00] v1.1.1.7 -> v1.1.1.7
[00429825][17 01][00] v1.0.2.7 -> v1.0.2.7
[00429898][19 00][00] v1.0.8.96 -> v1.0.8.96
[00429963][01 00][00] v1.26.4315 -> v1.26.4315
[00430035][01 01][00] v1.26.4315 -> v1.26.4315
[00442600][08 00][00] device not detected.
[00442700][09 00][00] v2.13.0.0 -> v2.13.0.0
[00442761]Packet upgrade failed at version checking.
秋香  超级版主 2015-12-28 3#
楼主的这种情况建议通过:http://www.dji.com/cn/support 与我们取得联系,将机器寄回我们帮您解决了,为此给您带来的不便敬请您的谅解。
楼主  Inspire 1 V2.0认证用户 2015-12-28 4#
秋香 发表于 2015-12-28 18:04
楼主的这种情况建议通过:http://www.dji.com/cn/support 与我们取得联系,将机器寄回我们帮您解决了,为此 ...
秋香妹妹好,我是先通过电联系还是直接填写返修表然后将机器寄回大疆。
秋香  超级版主 2015-12-28 5#
通过我给您的链接联系我们
楼主  Inspire 1 V2.0认证用户 2015-12-28 6#
秋香 发表于 2015-12-28 19:48
通过我给您的链接联系我们
谢谢,已经联系
秋香  超级版主 2015-12-29 7#
好的
楼主  Inspire 1 V2.0认证用户 2015-12-31 8#
我返厂的精灵昨天上午维修部就签收了,可是今天还查询不到情况,您是否帮我看看,登记号CAS-42115-C7B8H1,谢谢
秋香  超级版主 2015-12-31 9#
会飞的虎 发表于 2015-12-31 11:43
我返厂的精灵昨天上午维修部就签收了,可是今天还查询不到情况,您是否帮我看看,登记号CAS-42115-C7B8H1 ...
签收后入系统需要1-2个工作日的
收藏 点赞 评论
