向夏清小妹求助
手机看帖 9 1328
一直关注OSMO,11号下午六点收到了OSMO手柄,回家后迫不及待地按步骤升级成功后,激活、连接手机各种试;刚开始一切正常,后来,点“进入相机”,按“录制”,黑屏,自动退出。再点“进入相机”,点回放,时而能回放,时而黑屏。向夏清小妹求助。。。。。。。
长治一小伙  DJI RS 2认证用户 2016-1-12 2#
手机的问题,你换平板就会好多啦
秋香  超级版主 2016-1-12 3#
楼主目前是最新的固件版本吗?检查蛋蛋是否卡紧,其次看看黑屏的时候两个指示灯怎么闪烁,也可以尝试更换设备试试
楼主  Inspire 1认证用户 2016-1-12 4#
秋香 发表于 2016-1-12 09:29
楼主目前是最新的固件版本吗?检查蛋蛋是否卡紧,其次看看黑屏的时候两个指示灯怎么闪烁,也可以尝试更换设 ...
是最新版本。换手机试试看先
秋香  超级版主 2016-1-12 5#
179478061 发表于 2016-1-12 09:50
是最新版本。换手机试试看先
好的~
楼主  Inspire 1认证用户 2016-1-14 6#
换了手机也不行啊!咋办?咋办?21号要用啊。。。跟这位大侠描述的一样(http://bbs.dji.com/forum.php?mod ... peid%26typeid%3D187),我把云台拆卸了再装也不行!
楼主  Inspire 1认证用户 2016-1-17 7#
秋香小妹,我已将我的OSMO问题邮件给售后技术专员,麻烦你能否亲自过问一下,能尽早给个答复!
楼主  Inspire 1认证用户 2016-1-17 8#
========== 2014.01.01 00:00:08 remo-con disconnect======
Packet: OSMO_FW_V01.04.01.80.bin
Upgrading ...
========== 2016.01.11 21:58:44 =====================
Upgrading ...
Upgrading ...
========== 2014.01.01 00:00:09 remo-con disconnect======
Upgrading ...
Result: Success.
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
========== 2016.01.12 00:20:38 =====================
Result: Abort.
Result: Abort.
========== 2016.01.12 01:31:39 =====================
Result: Abort.
Result: Abort.
Result: Abort.
========== 2016.01.12 01:51:37 =====================
Result: Abort.
========== 2016.01.12 01:54:01 =====================
Result: Abort.
========== 2016.01.12 02:00:38 =====================
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
========== 2016.01.12 02:39:11 =====================
Result: Abort.
========== 2016.01.12 02:40:39 =====================
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
========== 2016.01.14 21:53:04 =====================
Result: Abort.
========== 2016.01.14 21:53:27 =====================
Result: Abort.
========== 2016.01.14 21:53:53 =====================
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
秋香  超级版主 2016-1-17 9#
179478061 发表于 2016-1-17 19:19
秋香小妹,我已将我的OSMO问题邮件给售后技术专员,麻烦你能否亲自过问一下,能尽早给个答复! ...
您是给我的哪位同事了?有没有尝试强制重新升级试试?
秋香  超级版主 2016-1-18 10#
Upgrading  ...
我已经在您的帖子里回复您了哈,您尝试把云台里的红色小红圈取下试试,如果还是不行,那估计就只能寄回来了,应该就是硬件的故障了
已累计飞行149326米
收藏 点赞 评论
