fans73ea55c4
已累计飞行 0 米
发布于
2016-1-14
浏览
2.0k
相关分类
10 条评论
最新
最早
fans73ea55c4
11
已累计飞行 0 米
折腾到凌晨3点,问题依然没有解决,郁闷……。:dizzy:
2016-1-15
fans73ea55c4
10
已累计飞行 0 米
[00012244][01 00] Firmware upgrade finished successfully. [00012352]Done. [00012391]Packet [C:\WM610_FC550_FW_V01.03.00.60.bin] resumed, card sn [0xb0ce01d7]. [00012433]Packet vlink 01.03.0060 01.00.0030. [00012496]Version checking[2]... [00012539][01 00][05] v1.9.4499 -> v1.9.4499 [00012570][01 01][00] v0.16.3234 -> v1.9.4499 need upgrade [00012620][01 04][00] v0.1.10296 -> v0.2.4270 need upgrade [00012671][04 00][00] v1.26.0.13 -> v1.29.0.60 need upgrade. [00012759][03 05][00] v34.1.0.5 -> v34.1.0.5 [00012839][03 06][00] v2.4.10.7 -> v2.4.10.7 [00012918][05 00][00] v3.0.6.2 -> v3.0.6.2 [00025451][08 00][00] device not detected. [00025493][09 00][00] v1.8.0.0 -> v1.8.0.0 [00025579][11 00][00] v3.8.15.4 -> v3.8.15.4 [00025658][12 00][00] v1.11.0.0 -> v1.11.0.0 [00025738][12 01][00] v1.11.0.0 -> v1.11.0.0 [00025818][12 02][00] v1.11.0.0 -> v1.11.0.0 [00025918][12 03][00] v1.11.0.0 -> v1.11.0.0 [00038459][15 00][00] device not detected. [00038518][17 00][00] v1.1.0.4 -> v1.1.0.4 [00038618][17 01][00] v2.0.1.2 -> v2.0.1.2 [00038672][19 00][00] v1.0.8.96 -> v1.0.8.96 [00038705]Done. [00038744]Firmware upgrading[2]... [00038831][01 01] Firmware upgrade start... [00069112][01 01] Firmware upgrade finished successfully. [00069162][01 04] Firmware upgrade start... [00109387][01 04] Firmware upgrade finished successfully. [00109446][04 00] Firmware upgrade start... [00181350][04 00] Firmware upgrade finished successfully. [00181388]Done. [00181422]Version checking[3]... [00181460][01 00][05] v1.9.4499 -> v1.9.4499 [00181494][01 01][05] v1.9.4499 -> v1.9.4499 [00181541][01 04][05] v0.2.4270 -> v0.2.4270 [00181582][04 00][05] v1.29.0.60 -> v1.29.0.60 [00181656][03 05][00] v34.1.0.5 -> v34.1.0.5 [00181735][03 06][00] v2.4.10.7 -> v2.4.10.7 [00181815][05 00][00] v3.0.6.2 -> v3.0.6.2 [00194349][08 00][00] device not detected. [00194395][09 00][00] v1.8.0.0 -> v1.8.0.0 [00194475][11 00][00] v3.8.15.4 -> v3.8.15.4 [00194555][12 00][00] v1.11.0.0 -> v1.11.0.0 [00194735][12 01][00] v1.11.0.0 -> v1.11.0.0 [00194815][12 02][00] v1.11.0.0 -> v1.11.0.0 [00194915][12 03][00] v1.11.0.0 -> v1.11.0.0 [00207461][15 00][00] device not detected. [00207515][17 00][00] v1.1.0.4 -> v1.1.0.4 [00207615][17 01][00] v2.0.1.2 -> v2.0.1.2 [00207665][19 00][00] v1.0.8.96 -> v1.0.8.96 [00207699]Packet upgrade failed at version checking. [00012811]========== remo-con disconnect. boot(15) ============ [00012844]Packet [C:\WM610_FC550_FW_V01.03.00.60.bin] detected, card sn [0xb0ce01d7]. [00012877]Packet upgrade start... [00012916]Packet checking... [00012953]Packet vlink 01.03.0060 01.00.0030. [00013016]Done. [00013050]Version checking[1]... [00013084][01 00][00] v1.9.4499 -> v1.9.4499 [00013121][01 01][00] v1.9.4499 -> v1.9.4499 [00013159][01 04][00] v0.2.4270 -> v0.2.4270 [00013198][04 00][00] v1.29.0.60 -> v1.29.0.60 [00013294][03 05][00] v34.1.0.5 -> v34.1.0.5 [00013378][03 06][00] v2.4.10.7 -> v2.4.10.7 [00013434][05 00][00] v3.0.6.2 -> v3.0.6.2 [00025969][08 00][00] device not detected. [00026019][09 00][00] v1.8.0.0 -> v1.8.0.0 [00026075][11 00][00] v3.8.15.4 -> v3.8.15.4 [00026157][12 00][00] v1.11.0.0 -> v1.11.0.0 [00026234][12 01][00] v1.11.0.0 -> v1.11.0.0 [00026314][12 02][00] v1.11.0.0 -> v1.11.0.0 [00026414][12 03][00] v1.11.0.0 -> v1.11.0.0 [00038948][15 00][00] device not detected. [00039014][17 00][00] v1.1.0.4 -> v1.1.0.4 [00039114][17 01][00] v2.0.1.2 -> v2.0.1.2 [00039159][19 00][00] v1.0.8.96 -> v1.0.8.96 [00041192]Packet upgrade failed at version checking. [00012510]========== remo-con disconnect. boot(15) ============ [00012542]Packet [C:\WM610_FC550_FW_V01.03.00.60.bin] detected, card sn [0xb0ce01d7]. [00012575]Packet upgrade start... [00012612]Packet checking... [00012648]Packet vlink 01.03.0060 01.00.0030. [00012716]Done. [00012750]Version checking[1]... [00012782][01 00][00] v1.9.4499 -> v1.9.4499 [00012821][01 01][00] v1.9.4499 -> v1.9.4499 [00012959][01 04][00] v0.2.4270 -> v0.2.4270 [00013005][04 00][00] v1.29.0.60 -> v1.29.0.60 [00013071][03 05][00] v34.1.0.5 -> v34.1.0.5 [00013150][03 06][00] v2.4.10.7 -> v2.4.10.7 [00013230][05 00][00] v3.0.6.2 -> v3.0.6.2 [00025761][08 00][00] device not detected. [00025810][09 00][00] v1.8.0.0 -> v1.8.0.0 [00025890][11 00][00] v3.8.15.4 -> v3.8.15.4 [00025990][12 00][00] v1.11.0.0 -> v1.11.0.0 [00026090][12 01][00] v1.11.0.0 -> v1.11.0.0 [00026190][12 02][00] v1.11.0.0 -> v1.11.0.0 [00026290][12 03][00] v1.11.0.0 -> v1.11.0.0 [00038829][15 00][00] device not detected. [00038889][17 00][00] v1.1.0.4 -> v1.1.0.4 [00039009][17 01][00] v2.0.1.2 -> v2.0.1.2 [00039059][19 00][00] v1.0.8.96 -> v1.0.8.96 [00041093]Packet upgrade failed at version checking. [00012615]========== remo-con disconnect. boot(15) ============ [00012648]Packet [C:\WM610_FC550_FW_V01.02.00.50.bin] detected, card sn [0xb0ce01d7]. [00012683]Packet upgrade start... [00012728]Packet checking... [00012763]Packet vlink 01.02.0050 01.00.0030. [00012831]Done. [00012864]Version checking[1]... [00012904][01 00][00] v1.9.4499 -> v1.9.4499 [00012937][01 01][00] v1.9.4499 -> v1.9.4499 [00012977][01 04][00] v0.2.4270 -> v0.2.4270 [00013021][04 00][00] v1.29.0.60 -> v1.28.0.15 [00013097][03 05][00] v34.1.0.5 -> v34.1.0.5 [00013174][03 06][00] v2.4.10.7 -> v2.4.0.5 [00013254][05 00][00] v3.0.6.2 -> v3.0.6.2 [00025785][08 00][00] device not detected. [00025854][09 00][00] v1.8.0.0 -> v1.8.0.0 [00025935][11 00][00] v3.8.15.4 -> v3.8.15.4 [00026034][12 00][00] v1.11.0.0 -> v1.11.0.0 [00026114][12 01][00] v1.11.0.0 -> v1.11.0.0 [00026194][12 02][00] v1.11.0.0 -> v1.11.0.0 [00026293][12 03][00] v1.11.0.0 -> v1.11.0.0 [00038833][15 00][00] device not detected. [00038894][17 00][00] v1.1.0.4 -> v1.1.0.4 [00038994][17 01][00] v2.0.1.2 -> v2.0.1.2 [00039048][19 00][00] v1.0.8.96 -> v1.0.8.96 [00041082]Packet upgrade failed at version checking. [00012433]========== remo-con disconnect. boot(15) ============ [00012545]Packet [C:\WM610_FC550_FW_V01.02.00.50.bin] detected, card sn [0xb0ce01d7]. [00012579]Packet upgrade start... [00012619]Packet checking... [00012662]Packet vlink 01.02.0050 01.00.0030. [00012726]Done. [00012767]Version checking[1]... [00012801][01 00][00] v1.9.4499 -> v1.9.4499 [00012842][01 01][00] v1.9.4499 -> v1.9.4499 [00012880][01 04][00] v0.2.4270 -> v0.2.4270 [00012926][04 00][00] v1.29.0.60 -> v1.28.0.15 [00013016][03 05][00] v34.1.0.5 -> v34.1.0.5 [00013096][03 06][00] v2.4.10.7 -> v2.4.0.5 [00013156][05 00][00] v3.0.6.2 -> v3.0.6.2 [00025688][08 00][00] device not detected. [00025747][09 00][00] v1.8.0.0 -> v1.8.0.0 [00025815][11 00][00] v3.8.15.4 -> v3.8.15.4 [00025895][12 00][00] v1.11.0.0 -> v1.11.0.0 [00025975][12 01][00] v1.11.0.0 -> v1.11.0.0 [00026076][12 02][00] v1.11.0.0 -> v1.11.0.0 [00026176][12 03][00] v1.11.0.0 -> v1.11.0.0 [00038711][15 00][00] device not detected. [00038782][17 00][00] v1.1.0.4 -> v1.1.0.4 [00038875][17 01][00] v2.0.1.2 -> v2.0.1.2 [00038922][19 00][00] v1.0.8.96 -> v1.0.8.96 [00040962]Packet upgrade failed at version checking. [00012617]========== remo-con disconnect. boot(15) ============ [00012650]Packet [C:\WM610_FC550_FW_V01.03.00.60.bin] detected, card sn [0xb0ce01d7]. [00012685]Packet upgrade start... [00012728]Packet checking... [00012764]Packet vlink 01.03.0060 01.00.0030. [00012836]Done. [00012870]Version checking[1]... [00012910][01 00][00] v1.9.4499 -> v1.9.4499 [00012945][01 01][00] v1.9.4499 -> v1.9.4499 [00012985][01 04][00] v0.2.4270 -> v0.2.4270 [00013037][04 00][00] v1.29.0.60 -> v1.29.0.60 [00013123][03 05][00] v34.1.0.5 -> v34.1.0.5 [00013203][03 06][00] v2.4.10.7 -> v2.4.10.7 [00013303][05 00][00] v3.0.6.2 -> v3.0.6.2 [00025838][08 00][00] device not detected. [00025888][09 00][00] v1.8.0.0 -> v1.8.0.0 [00025963][11 00][00] v3.8.15.4 -> v3.8.15.4 [00026043][12 00][00] v1.11.0.0 -> v1.11.0.0 [00026210][12 01][00] v1.11.0.0 -> v1.11.0.0 [00026310][12 02][00] v1.11.0.0 -> v1.11.0.0 [00026410][12 03][00] v1.11.0.0 -> v1.11.0.0 [00038951][15 00][00] device not detected. [00039023][17 00][00] v1.1.0.4 -> v1.1.0.4 [00039123][17 01][00] v2.0.1.2 -> v2.0.1.2 [00039168][19 00][00] v1.0.8.96 -> v1.0.8.96 [00041204]Packet upgrade failed at version checking. [00012534]========== remo-con disconnect. boot(15) ============ [00012580]Packet [C:\WM610_FC550_FW_V01.03.00.60.bin] detected, card sn [0xb0ce01d7]. [00012620]Packet upgrade start... [00012664]Packet checking... [00012705]Packet vlink 01.03.0060 01.00.0030. [00012774]Done. [00012815]Version checking[1]... [00012854][01 00][00] v1.9.4499 -> v1.9.4499 [00012896][01 01][00] v1.9.4499 -> v1.9.4499 [00012946][01 04][00] v0.2.4270 -> v0.2.4270 [00012998][04 00][00] v1.29.0.60 -> v1.29.0.60 [00013072][03 05][00] v34.1.0.5 -> v34.1.0.5 [00013132][03 06][00] v2.4.10.7 -> v2.4.10.7 [00013192][05 00][00] v3.0.6.2 -> v3.0.6.2 [00025730][08 00][00] device not detected. [00025785][09 00][00] v1.8.0.0 -> v1.8.0.0 [00025851][11 00][00] v3.8.15.4 -> v3.8.15.4 [00025931][12 00][00] v1.11.0.0 -> v1.11.0.0 [00026011][12 01][00] v1.11.0.0 -> v1.11.0.0 [00026091][12 02][00] v1.11.0.0 -> v1.11.0.0 [00026191][12 03][00] v1.11.0.0 -> v1.11.0.0 [00038736][15 00][00] device not detected. [00038812][17 00][00] v1.1.0.4 -> v1.1.0.4 [00038912][17 01][00] v2.0.1.2 -> v2.0.1.2 [00038966][19 00][00] v1.0.8.96 -> v1.0.8.96 [00041009]Packet upgrade failed at version checking. [00012832]========== remo-con disconnect. boot(15) ============ [00012868]Packet [C:\WM610_FC550_FW_V01.02.00.50.bin] detected, card sn [0xb0ce01d7]. [00012907]Packet upgrade start... [00012951]Packet checking... [00012989]Packet vlink 01.02.0050 01.00.0030. [00013055]Done. [00013090]Version checking[1]... [00013125][01 00][00] v1.9.4499 -> v1.9.4499 [00013163][01 01][00] v1.9.4499 -> v1.9.4499 [00013291][01 04][00] v0.2.4270 -> v0.2.4270 [00013333][04 00][00] v1.29.0.60 -> v1.28.0.15 [00013398][03 05][00] v34.1.0.5 -> v34.1.0.5 [00013478][03 06][00] v2.4.10.7 -> v2.4.0.5 [00013539][05 00][00] v3.0.6.2 -> v3.0.6.2 [00026073][08 00][00] device not detected. [00026128][09 00][00] v1.8.0.0 -> v1.8.0.0 [00026218][11 00][00] v3.8.15.4 -> v3.8.15.4 [00026298][12 00][00] v1.11.0.0 -> v1.11.0.0 [00026378][12 01][00] v1.11.0.0 -> v1.11.0.0 [00026458][12 02][00] v1.11.0.0 -> v1.11.0.0 [00026538][12 03][00] v1.11.0.0 -> v1.11.0.0 [00039072][15 00][00] device not detected. [00039138][17 00][00] v1.1.0.4 -> v1.1.0.4 [00039239][17 01][00] v2.0.1.2 -> v2.0.1.2 [00039288][19 00][00] v1.0.8.96 -> v1.0.8.96 [00041326]Packet upgrade failed at version checking. [00013337]========== remo-con disconnect. boot(15) ============ [00013375]Packet [C:\WM610_FC550_FW_V01.03.00.60.bin] detected, card sn [0xb0ce01d7]. [00013417]Packet upgrade start... [00013459]Packet checking... [00013502]Packet vlink 01.03.0060 01.00.0030. [00013571]Done. [00013614]Version checking[1]... [00013651][01 00][00] v1.9.4499 -> v1.9.4499 [00013693][01 01][00] v1.9.4499 -> v1.9.4499 [00013740][01 04][00] v0.2.4270 -> v0.2.4270 [00013786][04 00][00] v1.29.0.60 -> v1.29.0.60 [00013850][03 05][00] v34.1.0.5 -> v34.1.0.5 [00013909][03 06][00] v2.4.0.5 -> v2.4.10.7 need upgrade. [00013989][05 00][00] v3.0.6.2 -> v3.0.6.2 [00026527][08 00][00] device not detected. [00026579][09 00][00] v1.8.0.0 -> v1.8.0.0 [00026649][11 00][00] v3.8.15.4 -> v3.8.15.4 [00026729][12 00][00] v1.11.0.0 -> v1.11.0.0 [00026809][12 01][00] v1.11.0.0 -> v1.11.0.0 [00026909][12 02][00] v1.11.0.0 -> v1.11.0.0 [00027009][12 03][00] v1.11.0.0 -> v1.11.0.0 [00039544][15 00][00] device not detected. [00039612][17 00][00] v1.1.0.4 -> v1.1.0.4 [00039712][17 01][00] v2.0.1.2 -> v2.0.1.2 [00039768][19 00][00] v1.0.8.96 -> v1.0.8.96 [00039802]Done. [00041842]Waiting for user ... [00051879]Timeout, start upgrade automatically. [00052053]Firmware upgrading[1]... [00052175][03 06] Firmware upgrade start... [00300181][03 06] Firmware upgrade finished successfully. [00300217]Done. [00300254]Version checking[2]... [00300297][01 00][00] v1.9.4499 -> v1.9.4499 [00300339][01 01][00] v1.9.4499 -> v1.9.4499 [00300388][01 04][00] v0.2.4270 -> v0.2.4270 [00300434][04 00][00] v1.29.0.60 -> v1.29.0.60 [00300524][03 05][00] v34.1.0.5 -> v34.1.0.5 [00300604][03 06][05] v2.4.10.7 -> v2.4.10.7 [00300664][05 00][00] v3.0.6.2 -> v3.0.6.2 [00313213][08 00][00] device not detected. [00313263][09 00][00] v1.8.0.0 -> v1.8.0.0 [00313323][11 00][00] v3.8.15.4 -> v3.8.15.4 [00313423][12 00][00] v1.11.0.0 -> v1.11.0.0 [00313523][12 01][00] v1.11.0.0 -> v1.11.0.0 [00313623][12 02][00] v1.11.0.0 -> v1.11.0.0 [00313723][12 03][00] v1.11.0.0 -> v1.11.0.0 [00326261][15 00][00] device not detected. [00326323][17 00][00] v1.1.0.4 -> v1.1.0.4 [00326423][17 01][00] v2.0.1.2 -> v2.0.1.2 [00326473][19 00][00] v1.0.8.96 -> v1.0.8.96 [00326514]Packet upgrade failed at version checking.
2016-1-14
fans73ea55c4
9
已累计飞行 0 米
txt文件提示:升级失败,重启升级。
2016-1-14
fans73ea55c4
8
已累计飞行 0 米
好的,现在出门了,回家再穿到你的邮箱。
2016-1-14
秋香
7
已累计飞行 0 米
把SD卡里的log上传我看看吧
2016-1-14
fans73ea55c4
6
已累计飞行 0 米
咨询客服答复降级,降级固件40多分钟了,依然持续长鸣。
2016-1-14
fans73ea55c4
5
已累计飞行 0 米
等了1个多小时,还是不行,持续长鸣。
2016-1-14
fans73ea55c4
4
已累计飞行 0 米
升级40分钟了,还是长鸣声,秋香妹子,怎么处理啊?
2016-1-14
fans73ea55c4
已累计飞行 0 米
好的,谢谢!
2016-1-14
秋香
已累计飞行 0 米
让他自行进行升级,升级的过程大约需要半小时左右,待听到嘀-嘀嘀后断电重启就好
2016-1-14
暂无更多评论
关于作者
已累计飞行 0 米
fans73ea55c4
暂无关联认证的设备
最新帖子
云南出台《关于加强“低慢小”航空器管理的通告》,我的悟还有得玩吗?
秋香,请进来下,关于X5返修回来的问题
请问悟1使用x5升级pro固件失败,重新升级的问题。
