请选择 进入手机版 | 继续访问电脑版
精灵3PRO 无图传信号,1月10日还正常飞行
手机看帖 32 1694
1月10日正常飞行后因天气原因一直没动设备,2月10日连上设备后有信号,APP显示无图传信号,其它如无线信道质量等均无异常。搜索论坛后升级飞行器、遥控器、APP等,飞行器升级下载最新固件1.6版本,text文件显示失败。
根据阿香姐回复其它帖子的提示,1.5也不能升级成功,怎么办好?
*飞行器之前正常升级到过1.4版本
秋香  超级版主 2016-2-15 2#
麻烦您将您升级的log文件上传我帮您看看具体升级失败的原因
楼主  Osmo认证用户 2016-2-15 3#
之前成功升级过1.4版本,昨天升级1.6版本失败,今天1.5也失败
Result: Success.
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3X_FW_V01.04.0010.bin
Upgrading ...
Result: Success.
========== 2015.09.08 14:48:09 =====================
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2015.09.08 14:59:35 =====================
Result: Abort.
Result: Abort.
========== 2014.01.01 00:00:11 remo-con disconnect======
Result: Abort.
========== 2015.09.08 15:04:19 =====================
Result: Abort.
========== 2015.09.08 15:12:28 =====================
Result: Abort.
========== 2015.09.08 15:52:12 =====================
Result: Abort.
Result: Abort.
========== 2015.09.08 16:36:28 =====================
Result: Abort.
========== 2015.09.09 12:05:50 =====================
Upgrading ...
Result: Success.
========== 2015.09.09 12:12:13 =====================
Result: Abort.
========== 2015.09.10 11:30:44 =====================
Result: Abort.
========== 2015.09.10 11:33:52 =====================
Result: Abort.
========== 2015.09.10 11:37:03 =====================
Result: Abort.
========== 2014.01.01 00:00:13 remo-con disconnect======
Result: Abort.
========== 2015.09.10 11:52:17 =====================
Result: Abort.
========== 2015.09.10 12:05:48 =====================
Result: Abort.
========== 2015.09.11 12:41:23 =====================
Result: Abort.
Packet: P3X_FW_V01.06.0040.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Result: Failed.
Upgrading ...
Result: Failed.
========== 2014.01.01 00:00:14 remo-con disconnect======
Result: Failed.
Result: Failed.
========== 2014.01.01 00:00:15 remo-con disconnect======
Packet: P3X_FW_V01.05.0030.bin
Result: Failed.
Result: Failed.
========== 2016.02.15 13:14:16 =====================
Result: Failed.
========== 2016.02.15 13:16:31 =====================
Result: Failed.
秋香  超级版主 2016-2-15 4#
Result: Success.
这是TXT,您要把misc/log里的文件给我看看哦
楼主  Osmo认证用户 2016-2-15 5#
[00013239][01 00] Firmware upgrade finished successfully.
[00013345]Done.
[00013382]Packet [C:\P3X_FW_V01.02.0006.bin] resumed, card sn [0xa0ce1ee8].
[00013415]Version checking[2]...
[00013499][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00013573][03 06][00] v2.1.6.18 -> v2.2.6.8 need upgrade.
[00013611][04 00][00] v1.36.0.0 -> v1.38.0.0 need upgrade.
[00013677][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013773][11 00][00] v1.6.0.0 -> v1.6.0.0
[00013846][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013922][12 01][00] v1.8.0.0 -> v1.8.0.0
[00014012][12 02][00] v1.8.0.0 -> v1.8.0.0
[00014112][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014238][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014327][17 00][00] v1.1.1.2 -> v1.1.1.6 need upgrade.
[00014447][17 01][00] v1.0.2.4 -> v1.0.2.5 need upgrade.
[00014497][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00014528][01 00][05] v1.15.3056 -> v1.15.3056
[00014566][01 01][00] v1.5.2735 -> v1.15.3056 need upgrade
[00014604][08 00][00] v0.11.0.4 -> v0.11.0.4
[00014633]Done.
[00014668]Firmware upgrading[2]...
[00014824][01 01] Firmware upgrade start...
[00045120][01 01] Firmware upgrade finished successfully.
[00045175][17 00] Firmware upgrade start...
[00160545][17 00] Firmware upgrade finished successfully.
[00160588][17 01] Firmware upgrade start...
[00229308][17 01] Firmware upgrade finished successfully.
[00229357][03 05] Firmware upgrade start...
[00305313][03 05] Firmware upgrade finished successfully.
[00305532][03 06] Firmware upgrade start...
[00601459][03 06] Firmware upgrade finished successfully.
[00604416][19 00] Firmware upgrade start...
[00770816][19 00] Firmware upgrade finished successfully.
[00770874][04 00] Firmware upgrade start...
[00828585][04 00] Firmware upgrade finished successfully.
[00828615]Done.
[00828647]Version checking[3]...
[00828717][03 05][05] v34.2.0.9 -> v34.2.0.9
[00828797][03 06][05] v2.2.6.8 -> v2.2.6.8
[00828830][04 00][05] v1.38.0.0 -> v1.38.0.0
[00828892][09 00][00] v1.7.0.3 -> v1.7.0.3
[00829097][11 00][00] v1.6.0.0 -> v1.6.0.0
[00829187][12 00][00] v1.8.0.0 -> v1.8.0.0
[00829277][12 01][00] v1.8.0.0 -> v1.8.0.0
[00829362][12 02][00] v1.8.0.0 -> v1.8.0.0
[00829452][12 03][00] v1.8.0.0 -> v1.8.0.0
[00829575][15 00][00] v1.1.2.0 -> v1.1.2.0
[00829663][17 00][05] v1.1.1.6 -> v1.1.1.6
[00829781][17 01][05] v1.0.2.5 -> v1.0.2.5
[00829832][19 00][05] v1.0.8.96 -> v1.0.8.96
[00829863][01 00][05] v1.15.3056 -> v1.15.3056
[00829897][01 01][05] v1.15.3056 -> v1.15.3056
[00829937][08 00][00] v0.11.0.4 -> v0.11.0.4
[00829967]Packet upgrade finish successfully.
[00012824]========== remo-con disconnect. boot(15) ============
[00012861]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0b504a9].
[00012901]Packet upgrade start...
[00012947]Packet checking...
[00012989]Done.
[00013030]Version checking[1]...
[00013097][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013177][03 06][00] v2.2.6.8 -> v2.3.0.13 need upgrade.
[00013221][04 00][00] v1.38.0.0 -> v1.41.0.0 need upgrade.
[00013272][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013377][11 00][00] v1.6.1.0 -> v1.7.0.0 need upgrade.
[00013492][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013567][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013656][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013732][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013889][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013986][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00014107][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00014172][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014213][01 00][00] v1.15.3056 -> v1.23.3419 need upgrade
[00014257][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade
[00014316][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00014353]Done.
[00016394]Waiting for user confirm...
[00026431]Timeout, start upgrade automatically.
[00026506]Firmware upgrading[1]...
[00039137][01 00] Firmware upgrade start...
[00012137][01 00] Firmware upgrade finished successfully.
[00012489]Done.
[00012599]Packet [C:\P3X_FW_V01.04.0010.bin] resumed, card sn [0xb0b504a9].
[00012798]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012933]Version checking[2]...
[00013085][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013246][03 06][00] v2.2.6.8 -> v2.3.0.13 need upgrade.
[00013378][04 00][00] v1.38.0.0 -> v1.41.0.0 need upgrade.
[00013482][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013611][11 00][00] v1.6.1.0 -> v1.7.0.0 need upgrade.
[00013706][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013806][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013896][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013996][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00014123][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014238][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00014371][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00014442][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014482][01 00][05] v1.23.3419 -> v1.23.3419
[00014522][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade
[00014578][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00014618]Done.
[00014658]Firmware upgrading[2]...
[00014809][01 01] Firmware upgrade start...
[00045075][01 01] Firmware upgrade finished successfully.
[00045946][08 00] Firmware upgrade start...
[00563047][08 00] Firmware upgrade finished successfully.
[00563101][12 00] Firmware upgrade start...
[00630324][12 00] Firmware upgrade finished successfully.
[00630378][12 01] Firmware upgrade start...
[00696609][12 01] Firmware upgrade finished successfully.
[00696669][12 02] Firmware upgrade start...
[00763012][12 02] Firmware upgrade finished successfully.
[00763076][12 03] Firmware upgrade start...
[00828745][12 03] Firmware upgrade finished successfully.
[00828814][17 00] Firmware upgrade start...
[00937301][17 00] Firmware upgrade finished successfully.
[00937353][17 01] Firmware upgrade start...
[01006685][17 01] Firmware upgrade finished successfully.
[01006737][11 00] Firmware upgrade start...
[01055078][11 00] Firmware upgrade finished successfully.
[01055387][03 06] Firmware upgrade start...
[01379371][03 06] Firmware upgrade finished successfully.
[01379441][04 00] Firmware upgrade start...
[01436628][04 00] Firmware upgrade finished successfully.
[01436667]Done.
[01436705]Version checking[3]...
[01436789][03 05][00] v34.2.0.9 -> v34.2.0.9
[01436865][03 06][05] v2.3.0.13 -> v2.3.0.13
[01436910][04 00][05] v1.41.0.0 -> v1.41.0.0
[01436979][09 00][00] v1.7.0.3 -> v1.7.0.3
[01437091][11 00][05] v1.7.0.0 -> v1.7.0.0
[01437226][12 00][05] v1.10.0.0 -> v1.10.0.0
[01437304][12 01][05] v1.10.0.0 -> v1.10.0.0
[01437404][12 02][05] v1.10.0.0 -> v1.10.0.0
[01437504][12 03][05] v1.10.0.0 -> v1.10.0.0
[01437662][15 00][00] v1.1.2.0 -> v1.1.2.0
[01437758][17 00][05] v1.1.1.7 -> v1.1.1.7
[01437874][17 01][05] v1.0.2.7 -> v1.0.2.7
[01437919][19 00][00] v1.0.8.96 -> v1.0.8.96
[01437961][01 00][05] v1.23.3419 -> v1.23.3419
[01438000][01 01][05] v1.23.3419 -> v1.23.3419
[01438057][08 00][05] v0.12.0.4 -> v0.12.0.4
[01438100]Packet upgrade finish successfully.
[00012944]========== 2015.09.08 14:48:09. boot(15) ============
[00012984]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0b504a9].
[00013028]Packet upgrade start...
[00013075]Packet checking...
[00013111]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013150]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013195]Done.
[00013235]Version checking[1]...
[00013311][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013385][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013436][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013494][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013610][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013699][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013779][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013853][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013934][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014079][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014153][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014283][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014474][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014513][01 00][00] v1.23.3419 -> v1.23.3419
[00014552][01 01][00] v1.23.3419 -> v1.23.3419
[00014603][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014646]Packet upgrade cancelled at version checking.
[00012949]========== 2015.09.08 14:59:36. boot(15) ============
[00012988]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0b504a9].
[00013031]Packet upgrade start...
[00013076]Packet checking...
[00013115]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013155]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013201]Done.
[00013239]Version checking[1]...
[00013323][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013408][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013454][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013516][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013642][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013723][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013813][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013901][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014001][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014144][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014236][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014371][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014438][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014483][01 00][00] v1.23.3419 -> v1.23.3419
[00014522][01 01][00] v1.23.3419 -> v1.23.3419
[00014577][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014622]Packet upgrade cancelled at version checking.
[00012833]========== 2015.09.08 15:01:11. boot(2) ============
[00012873]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0b504a9].
[00012912]Packet upgrade start...
[00012964]Packet checking...
[00013003]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013043]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013083]Done.
[00013129]Version checking[1]...
[00013204][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013284][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013336][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013389][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013504][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013673][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013773][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013938][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014097][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014190][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014313][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014368][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014413][01 00][00] v1.23.3419 -> v1.23.3419
[00014455][01 01][00] v1.23.3419 -> v1.23.3419
[00014505][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014553]Packet upgrade cancelled at version checking.
[00012753]========== remo-con disconnect. boot(2) ============
[00012796]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0b504a9].
[00012839]Packet upgrade start...
[00012885]Packet checking...
[00012924]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012970]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013008]Done.
[00013048]Version checking[1]...
[00013136][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013213][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013309][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013380][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013496][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013594][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013688][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013790][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013892][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014036][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014140][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014301][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014365][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014412][01 00][00] v1.23.3419 -> v1.23.3419
[00014451][01 01][00] v1.23.3419 -> v1.23.3419
[00014506][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014554]Packet upgrade cancelled at version checking.
[00012805]========== 2015.09.08 15:04:19. boot(2) ============
[00012846]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0b504a9].
[00012887]Packet upgrade start...
[00012934]Packet checking...
[00012977]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013106]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013153]Done.
[00013193]Version checking[1]...
[00013270][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013367][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013414][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013474][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013587][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013678][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013758][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013834][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013918][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014069][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014173][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014291][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014357][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014402][01 00][00] v1.23.3419 -> v1.23.3419
[00014443][01 01][00] v1.23.3419 -> v1.23.3419
[00014493][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014533]Packet upgrade cancelled at version checking.
[00013040]========== 2015.09.08 15:12:28. boot(15) ============
[00013104]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0b504a9].
[00013172]Packet upgrade start...
[00013234]Packet checking...
[00013272]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013309]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013349]Done.
[00013386]Version checking[1]...
[00013449][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013510][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013556][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013619][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013730][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013794][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013884][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013961][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014040][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014859][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014955][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015055][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015119][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015158][01 00][00] v1.23.3419 -> v1.23.3419
[00015197][01 01][00] v1.23.3419 -> v1.23.3419
[00015272][08 00][00] v0.12.0.4 -> v0.12.0.4
[00015380]Packet upgrade cancelled at version checking.
[00012975]========== 2015.09.08 15:52:13. boot(15) ============
[00013021]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0b504a9].
[00013062]Packet upgrade start...
[00013110]Packet checking...
[00013149]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013196]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013235]Done.
[00013275]Version checking[1]...
[00013376][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013457][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013506][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013575][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013699][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013790][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013888][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013989][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014064][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014214][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014307][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014468][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014524][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014565][01 00][00] v1.23.3419 -> v1.23.3419
[00014610][01 01][00] v1.23.3419 -> v1.23.3419
[00014661][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014703]Packet upgrade cancelled at version checking.
[00012976]========== remo-con disconnect. boot(15) ============
[00013020]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0b504a9].
[00013109]Packet checking...
[00013193]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013236]Done.
[00013382][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013462][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013516][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013566][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013682][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013776][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013877][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014051][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014283][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014376][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014491][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014547][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014587][01 00][00] v1.23.3419 -> v1.23.3419
[00014636][01 01][00] v1.23.3419 -> v1.23.3419
[00014686][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014729]Packet upgrade cancelled at version checking.
[00012985]========== 2015.09.08 16:36:29. boot(15) ============
[00013024]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0b504a9].
[00013064]Packet upgrade start...
[00013157]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013236]Done.
[00013276]Version checking[1]...
[00013372][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013449][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013497][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013571][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013690][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013786][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013883][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013985][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014086][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014255][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014357][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014485][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014566][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014607][01 00][00] v1.23.3419 -> v1.23.3419
[00014650][01 01][00] v1.23.3419 -> v1.23.3419
[00014700][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014747]Packet upgrade cancelled at version checking.
[00013148]========== 2015.09.09 12:05:50. boot(15) ============
[00013195]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0b504a9].
[00013236]Packet upgrade start...
[00013283]Packet checking...
[00013328]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013370]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013414]Done.
[00013457]Version checking[1]...
[00013539][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013613][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013738][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013791][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013916][11 00][00] v1.6.1.0 -> v1.7.0.0 need upgrade.
[00014000][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014121][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014205][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014291][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014492][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014565][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014716][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014782][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014825][01 00][00] v1.23.3419 -> v1.23.3419
[00014869][01 01][00] v1.23.3419 -> v1.23.3419
[00014921][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014963]Done.
[00017042]Waiting for user confirm...
[00027084]Timeout, start upgrade automatically.
[00027164]Firmware upgrading[1]...
[00027217][11 00] Firmware upgrade start...
[00074936][11 00] Firmware upgrade finished successfully.
[00074976]Done.
[00075017]Version checking[2]...
[00075080][03 05][00] v34.2.0.9 -> v34.2.0.9
[00075159][03 06][00] v2.3.0.13 -> v2.3.0.13
[00075208][04 00][00] v1.41.0.0 -> v1.41.0.0
[00075269][09 00][00] v1.7.0.3 -> v1.7.0.3
[00075379][11 00][05] v1.7.0.0 -> v1.7.0.0
[00075473][12 00][00] v1.10.0.0 -> v1.10.0.0
[00075552][12 01][00] v1.10.0.0 -> v1.10.0.0
[00075652][12 02][00] v1.10.0.0 -> v1.10.0.0
[00075729][12 03][00] v1.10.0.0 -> v1.10.0.0
[00075867][15 00][00] v1.1.2.0 -> v1.1.2.0
[00075942][17 00][00] v1.1.1.7 -> v1.1.1.7
[00076072][17 01][00] v1.0.2.7 -> v1.0.2.7
[00076127][19 00][00] v1.0.8.96 -> v1.0.8.96
[00076170][01 00][00] v1.23.3419 -> v1.23.3419
[00076218][01 01][00] v1.23.3419 -> v1.23.3419
[00076271][08 00][00] v0.12.0.4 -> v0.12.0.4
[00076312]Packet upgrade finish successfully.
[00013014]========== 2015.09.09 12:12:13. boot(15) ============
[00013056]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0b504a9].
[00013097]Packet upgrade start...
[00013153]Packet checking...
[00013195]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013313]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013359]Done.
[00013401]Version checking[1]...
[00013471][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013547][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013596][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013670][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013788][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013880][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013981][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014068][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014143][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014299][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014417][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014557][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014616][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014659][01 00][00] v1.23.3419 -> v1.23.3419
[00014704][01 01][00] v1.23.3419 -> v1.23.3419
[00014767][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014809]Packet upgrade cancelled at version checking.
[00013023]========== 2015.09.10 11:30:45. boot(15) ============
[00013065]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0b504a9].
[00013108]Packet upgrade start...
[00013168]Packet checking...
[00013208]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013251]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013296]Done.
[00013345]Version checking[1]...
[00013432][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013512][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013565][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013631][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013753][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013853][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013944][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014040][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014126][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014293][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014421][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014631][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014673][01 00][00] v1.23.3419 -> v1.23.3419
[00014716][01 01][00] v1.23.3419 -> v1.23.3419
[00014865][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014908]Packet upgrade cancelled at version checking.
[00013070]========== 2015.09.10 11:33:52. boot(15) ============
[00013113]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0b504a9].
[00013157]Packet upgrade start...
[00013214]Packet checking...
[00013256]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013299]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013349]Done.
[00013392]Version checking[1]...
[00013467][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013548][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013598][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013650][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013767][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013860][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013960][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014060][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014160][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014344][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014435][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014570][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014630][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014674][01 00][00] v1.23.3419 -> v1.23.3419
[00014718][01 01][00] v1.23.3419 -> v1.23.3419
[00014774][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014817]Packet upgrade cancelled at version checking.
[00013030]========== 2015.09.10 11:37:03. boot(15) ============
[00013070]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0b504a9].
[00013109]Packet upgrade start...
[00013164]Packet checking...
[00013248]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013295]Done.
[00013341]Version checking[1]...
[00013420][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013523][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013571][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013644][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013777][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013865][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013959][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014064][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014222][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014388][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014479][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014630][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014700][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014749][01 00][00] v1.23.3419 -> v1.23.3419
[00014792][01 01][00] v1.23.3419 -> v1.23.3419
[00014850][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014898]Packet upgrade cancelled at version checking.
[00013057]========== remo-con disconnect. boot(15) ============
[00013099]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0b504a9].
[00013148]Packet upgrade start...
[00013198]Packet checking...
[00013239]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013280]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013330]Done.
[00013375]Version checking[1]...
[00013451][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013526][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013576][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013771][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013859][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014059][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014166][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014298][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014411][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014535][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014609][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014653][01 00][00] v1.23.3419 -> v1.23.3419
[00014697][01 01][00] v1.23.3419 -> v1.23.3419
[00014766][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014806]Packet upgrade cancelled at version checking.
[00012955]========== 2015.09.10 11:52:17. boot(15) ============
[00012997]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0b504a9].
[00013039]Packet upgrade start...
[00013085]Packet checking...
[00013125]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013167]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013208]Done.
[00013248]Version checking[1]...
[00013324][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013486][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013534][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013592][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013707][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013802][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013900][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014021][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014119][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014282][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014374][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014498][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014563][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014657][01 01][00] v1.23.3419 -> v1.23.3419
[00014706][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014752]Packet upgrade cancelled at version checking.
[00013043]========== 2015.09.10 12:05:49. boot(15) ============
[00013086]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0b504a9].
[00013131]Packet upgrade start...
[00013187]Packet checking...
[00013231]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013276]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013324]Done.
[00013368]Version checking[1]...
[00013452][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016040][03 06][00] v2.3.0.13 -> v2.3.0.13
[00016089][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016146][09 00][00] v1.7.0.3 -> v1.7.0.3
[00016271][11 00][00] v1.7.0.0 -> v1.7.0.0
[00016372][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016461][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016559][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016671][12 03][00] v1.10.0.0 -> v1.10.0.0
[00016846][15 00][00] v1.1.2.0 -> v1.1.2.0
[00016940][17 00][00] v1.1.1.7 -> v1.1.1.7
[00017067][17 01][00] v1.0.2.7 -> v1.0.2.7
[00017139][19 00][00] v1.0.8.96 -> v1.0.8.96
[00017185][01 00][00] v1.23.3419 -> v1.23.3419
[00017230][01 01][00] v1.23.3419 -> v1.23.3419
[00017283][08 00][00] v0.12.0.4 -> v0.12.0.4
[00017333]Packet upgrade cancelled at version checking.
[00013040]========== 2015.09.11 12:41:24. boot(15) ============
[00013163]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0b504a9].
[00013211]Packet upgrade start...
[00013263]Packet checking...
[00013306]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013352]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013396]Done.
[00013447]Version checking[1]...
[00013524][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013599][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013652][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013723][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013845][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013928][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014009][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014108][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014192][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014360][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014449][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014569][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014623][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014668][01 00][00] v1.23.3419 -> v1.23.3419
[00014769][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014811]Packet upgrade cancelled at version checking.
[00014556]========== remo-con disconnect. boot(15) ============
[00014597]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x80ce5a03].
[00014636]Packet upgrade start...
[00014684]Packet checking...
[00014724]Packet vlink 01.06.0040 <-> 01.05.0030.
[00014764]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014808]Done.
[00014847]Version checking[1]...
[00014920][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014995][03 06][00] v2.3.0.13 -> v2.4.10.7 need upgrade.
[00015046][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015155][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[00015249][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015349][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015424][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015535][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028075][15 00][00] device not detected.
[00028164][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028284][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028440][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028484][01 00][00] v1.23.3419 -> v1.26.4315 need upgrade
[00028524][01 01][00] v1.23.3419 -> v1.26.4315 need upgrade
[00041068][08 00][00] device not detected.
[00041140][09 00][00] v1.7.0.3 -> v2.13.0.0 need upgrade.
[00041181]Done.
[00043228]Waiting for user confirm...
[00053269]Timeout, start upgrade automatically.
[00053353]Firmware upgrading[1]...
[00065724][01 00] Firmware upgrade start...
[00014243][01 00] Firmware upgrade finished successfully.
[00014285]Done.
[00014327]Packet [C:\P3X_FW_V01.06.0040.bin] resumed, card sn [0x80ce5a03].
[00014376]Packet vlink 01.06.0040 <-> 01.05.0030.
[00014419]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014463]Version checking[2]...
[00014544][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014624][03 06][00] v2.3.0.13 -> v2.4.10.7 need upgrade.
[00014680][04 00][00] v1.41.0.0 -> v1.41.0.0
[00014809][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[00014917][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014997][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015097][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015197][12 03][00] v1.10.0.0 -> v1.10.0.0
[00027740][15 00][00] device not detected.
[00027813][17 00][00] v1.1.1.7 -> v1.1.1.7
[00027933][17 01][00] v1.0.2.7 -> v1.0.2.7
[00027991][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028031][01 00][05] v1.26.4315 -> v1.26.4315
[00028071][01 01][00] v1.23.3419 -> v1.26.4315 need upgrade
[00040615][08 00][00] device not detected.
[00040690][09 00][00] v1.7.0.3 -> v2.13.0.0 need upgrade.
[00040730]Done.
[00040774]Firmware upgrading[2]...
[00040931][01 01] Firmware upgrade start...
[00071192][01 01] Firmware upgrade finished successfully.
[00071245][11 00] Firmware upgrade start...
[00120644][11 00] Firmware upgrade finished successfully.
[00120887][03 06] Firmware upgrade start...
[00454412][03 06] Firmware upgrade finished successfully.
[00454480][09 00] Firmware upgrade start...
[00520022][09 00] Firmware upgrade finished successfully.
[00520152]Done.
[00520194]Version checking[3]...
[00520278][03 05][00] v34.2.0.9 -> v34.2.0.9
[00520351][03 06][05] v2.4.10.7 -> v2.4.10.7
[00520397][04 00][00] v1.41.0.0 -> v1.41.0.0
[00520530][11 00][05] v1.7.15.1 -> v1.7.15.1
[00520631][12 00][00] v1.10.0.0 -> v1.10.0.0
[00520730][12 01][00] v1.10.0.0 -> v1.10.0.0
[00520831][12 02][00] v1.10.0.0 -> v1.10.0.0
[00520930][12 03][00] v1.10.0.0 -> v1.10.0.0
[00533476][15 00][00] device not detected.
[00533560][17 00][00] v1.1.1.7 -> v1.1.1.7
[00533685][17 01][00] v1.0.2.7 -> v1.0.2.7
[00533754][19 00][00] v1.0.8.96 -> v1.0.8.96
[00533794][01 00][05] v1.26.4315 -> v1.26.4315
[00533837][01 01][05] v1.26.4315 -> v1.26.4315
[00546384][08 00][00] device not detected.
[00546437][09 00][05] v2.13.0.0 -> v2.13.0.0
[00546478]Packet upgrade failed at version checking.
[00014573]========== remo-con disconnect. boot(15) ============
[00014612]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x80ce5a03].
[00014661]Packet upgrade start...
[00014706]Packet checking...
[00014750]Packet vlink 01.06.0040 <-> 01.05.0030.
[00014789]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014837]Done.
[00014878]Version checking[1]...
[00014974][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015054][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015100][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015230][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015333][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015429][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015533][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015630][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028174][15 00][00] device not detected.
[00028275][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028419][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028486][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028530][01 00][00] v1.26.4315 -> v1.26.4315
[00028574][01 01][00] v1.26.4315 -> v1.26.4315
[00041115][08 00][00] device not detected.
[00041187][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041236]Packet upgrade failed at version checking.
[00014676]========== remo-con disconnect. boot(15) ============
[00014718]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x80ce5a03].
[00014760]Packet upgrade start...
[00014810]Packet checking...
[00014856]Packet vlink 01.06.0040 <-> 01.05.0030.
[00014898]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014942]Done.
[00014988]Version checking[1]...
[00015062][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015143][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015192][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015317][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[00015397][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015497][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015571][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015652][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028195][15 00][00] device not detected.
[00028287][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028414][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028473][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028516][01 00][00] v1.26.4315 -> v1.26.4315
[00028558][01 01][00] v1.26.4315 -> v1.26.4315
[00041110][08 00][00] device not detected.
[00041173][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041221]Done.
[00043264]Waiting for user confirm...
[00053312]Timeout, start upgrade automatically.
[00053401]Firmware upgrading[1]...
[00053455][11 00] Firmware upgrade start...
[00102598][11 00] Firmware upgrade finished successfully.
[00102641]Done.
[00102685]Version checking[2]...
[00102783][03 05][00] v34.2.0.9 -> v34.2.0.9
[00102863][03 06][00] v2.4.10.7 -> v2.4.10.7
[00102910][04 00][00] v1.41.0.0 -> v1.41.0.0
[00103023][11 00][05] v1.7.15.1 -> v1.7.15.1
[00103117][12 00][00] v1.10.0.0 -> v1.10.0.0
[00103191][12 01][00] v1.10.0.0 -> v1.10.0.0
[00103316][12 02][00] v1.10.0.0 -> v1.10.0.0
[00103392][12 03][00] v1.10.0.0 -> v1.10.0.0
[00115936][15 00][00] device not detected.
[00116012][17 00][00] v1.1.1.7 -> v1.1.1.7
[00116137][17 01][00] v1.0.2.7 -> v1.0.2.7
[00116197][19 00][00] v1.0.8.96 -> v1.0.8.96
[00116242][01 00][00] v1.26.4315 -> v1.26.4315
[00116377][01 01][00] v1.26.4315 -> v1.26.4315
[00128931][08 00][00] device not detected.
[00128997][09 00][00] v2.13.0.0 -> v2.13.0.0
[00129041]Packet upgrade failed at version checking.
[00015360]========== remo-con disconnect. boot(15) ============
[00015407]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0xb0b504a9].
[00015462]Packet upgrade start...
[00015514]Packet checking...
[00015560]Packet vlink 01.06.0040 <-> 01.05.0030.
[00015614]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015662]Done.
[00015707]Version checking[1]...
[00015786][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015866][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015925][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016054][11 00][00] v1.7.15.1 -> v1.7.15.1
[00016136][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016214][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016306][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016410][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028956][15 00][00] device not detected.
[00029056][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029180][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029235][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029281][01 00][00] v1.26.4315 -> v1.26.4315
[00029336][01 01][00] v1.26.4315 -> v1.26.4315
[00041884][08 00][00] device not detected.
[00041956][09 00][00] v2.13.0.0 -> v2.13.0.0
[00042009]Packet upgrade failed at version checking.
[00014646]========== remo-con disconnect. boot(15) ============
[00014692]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x80ce5a03].
[00014736]Packet upgrade start...
[00014781]Packet checking...
[00014831]Packet vlink 01.06.0040 <-> 01.05.0030.
[00014874]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014914]Done.
[00014955]Version checking[1]...
[00015053][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015150][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015199][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015352][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015466][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015647][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015746][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015855][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028397][15 00][00] device not detected.
[00028515][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028655][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028721][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028769][01 00][00] v1.26.4315 -> v1.26.4315
[00028813][01 01][00] v1.26.4315 -> v1.26.4315
[00041357][08 00][00] device not detected.
[00041421][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041466]Packet upgrade failed at version checking.
[00015373]========== remo-con disconnect. boot(15) ============
[00015427]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0xb0b504a9].
[00015473]Packet upgrade start...
[00015530]Packet checking...
[00015581]Packet vlink 01.05.0030 <-> 01.04.0010.
[00015630]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015677]Done.
[00015731]Version checking[1]...
[00015810][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015910][03 06][00] v2.4.10.7 -> v2.4.0.5
[00015966][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016090][11 00][00] v1.7.15.1 -> v1.7.0.0
[00016198][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016298][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016418][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016518][12 03][00] v1.10.0.0 -> v1.10.0.0
[00029073][15 00][00] device not detected.
[00029179][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029334][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029405][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029453][01 00][00] v1.26.4315 -> v1.26.4315
[00029507][01 01][00] v1.26.4315 -> v1.26.4315
[00042054][08 00][00] device not detected.
[00042131][09 00][00] v2.13.0.0 -> v2.13.0.0
[00042179]Packet upgrade failed at version checking.
[00015377]========== remo-con disconnect. boot(15) ============
[00015429]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0xb0b504a9].
[00015475]Packet upgrade start...
[00015534]Packet checking...
[00015585]Packet vlink 01.05.0030 <-> 01.04.0010.
[00015774]Done.
[00015823]Version checking[1]...
[00015906][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015986][03 06][00] v2.4.10.7 -> v2.4.0.5
[00016042][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016165][11 00][00] v1.7.15.1 -> v1.7.0.0
[00016265][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016369][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016465][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016565][12 03][00] v1.10.0.0 -> v1.10.0.0
[00029112][15 00][00] device not detected.
[00029210][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029340][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029415][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029464][01 00][00] v1.26.4315 -> v1.26.4315
[00029515][01 01][00] v1.26.4315 -> v1.26.4315
[00042069][08 00][00] device not detected.
[00042135][09 00][00] v2.13.0.0 -> v2.13.0.0
[00042183]Packet upgrade failed at version checking.
[00016018]========== 2016.02.15 13:14:18. boot(15) ============
[00016070]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0xb0b504a9].
[00016117]Packet upgrade start...
[00016177]Packet checking...
[00016229]Packet vlink 01.05.0030 <-> 01.04.0010.
[00016276]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00016323]Done.
[00016383]Version checking[1]...
[00016493][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016587][03 06][00] v2.4.10.7 -> v2.4.0.5
[00016642][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016787][11 00][00] v1.7.15.1 -> v1.7.0.0
[00016896][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016996][12 01][00] v1.10.0.0 -> v1.10.0.0
[00017096][12 02][00] v1.10.0.0 -> v1.10.0.0
[00017196][12 03][00] v1.10.0.0 -> v1.10.0.0
[00029751][15 00][00] device not detected.
[00029852][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029992][17 01][00] v1.0.2.7 -> v1.0.2.7
[00030063][19 00][00] v1.0.8.96 -> v1.0.8.96
[00030111][01 00][00] v1.26.4315 -> v1.26.4315
[00030166][01 01][00] v1.26.4315 -> v1.26.4315
[00042712][08 00][00] device not detected.
[00042793][09 00][00] v2.13.0.0 -> v2.13.0.0
[00042916]Packet upgrade failed at version checking.
[00014610]========== 2016.02.15 13:16:32. boot(15) ============
[00014661]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x80ce5a03].
[00014704]Packet upgrade start...
[00014751]Packet checking...
[00014795]Packet vlink 01.06.0040 <-> 01.05.0030.
[00014845]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014888]Done.
[00014934]Version checking[1]...
[00015022][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015127][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015177][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015302][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015391][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015492][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015606][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015702][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028246][15 00][00] device not detected.
[00028346][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028485][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028566][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028610][01 00][00] v1.26.4315 -> v1.26.4315
[00028657][01 01][00] v1.26.4315 -> v1.26.4315
[00041206][08 00][00] device not detected.
[00041281][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041324]Packet upgrade failed at version checking.
会飞的虎  Inspire 1认证用户 2016-2-15 6#
云台相机图传板坏了,返厂吧,就是不明白升级固件为什么会造成硬件损坏,这个损坏应该谁负责。这个主板只保修半年,我的就是花了1200自费维修的
楼主  Osmo认证用户 2016-2-15 7#
会飞的虎 发表于 2016-2-15 15:56
云台相机图传板坏了,返厂吧,就是不明白升级固件为什么会造成硬件损坏,这个损坏应该谁负责。这个主板只保 ...
算起来我购买已经超过了半年,不会就这样撒去1200元吧?等等秋香的答复
会飞的虎  Inspire 1认证用户 2016-2-15 8#
这两条设备无法检测到
秋香  超级版主 2016-2-15 9#
[00013345]Done.
这个目前只能返厂进行烧录了,建议您通过:http://www.dji.com/cn/support 与我们取得联系,我的相关同事会协助您解决此问题
楼主  Osmo认证用户 2016-2-16 10#
秋香 发表于 2016-2-15 18:07
这个目前只能返厂进行烧录了,建议您通过:http://www.dji.com/cn/support 与我们取得联系,我的相关同事 ...
谢谢秋香这么热心的答复,话说烧录大约需要多少银子?大约需要多长时间?
1357642cd217  Osmo认证用户 2016-2-16 11#
同样问题啊,放着不飞也会坏,还好我是免费修的
楼主  Osmo认证用户 2016-2-16 12#
免费修的吗?太好了!!
1357642cd217  Osmo认证用户 2016-2-16 13#
就是没有图传,其他的很正常吗
350238091  Phantom 3 Professional认证用户 2016-2-16 14#
图传只能用半年.
秋香  超级版主 2016-2-16 15#
goodfilter 发表于 2016-2-16 08:22
谢谢秋香这么热心的答复,话说烧录大约需要多少银子?大约需要多长时间? ...
这个应该是免费的
楼主  Osmo认证用户 2016-2-16 16#
秋香 发表于 2016-2-16 10:19
这个应该是免费的
这个是比今天上午我的股票涨停还好的消息
秋香  超级版主 2016-2-16 17#
goodfilter 发表于 2016-2-16 11:42
这个是比今天上午我的股票涨停还好的消息
哈哈哈,普天同庆
hly007  Osmo Mobile认证用户 2016-2-16 18#
我的精灵3也是同样的毛病,买了一年不到,总共才飞了十多次,放了几个月后,初四拿去来飞一下,第一块电池飞很正常,换第二块就没图传了,换手机换平板换苹果换安卓,折腾了好几天,都没搞定。
楼主  Osmo认证用户 2016-2-17 19#
hly007 发表于 2016-2-16 23:22
我的精灵3也是同样的毛病,买了一年不到,总共才飞了十多次,放了几个月后,初四拿去来飞一下,第一块电池 ...
看了这个问题挺多的
不得了  Phantom 3 Professional认证用户 2016-2-18 20#
goodfilter 发表于 2016-2-17 11:46
看了这个问题挺多的
我都是這樣,飛機沒玩個多月就無圖傳信號,什麼方法都試了都沒用,最終在2月3日年廿五到深圳快修,整個雲台相機更換了才行,最初已為是舊版本固件不兼容問題。
http://bbs.dji.com/thread-40450-1-1.html
不得了  Phantom 3 Professional认证用户 2016-2-18 21#
對的,云台相机图传板質量非常差。
会飞的虎  Inspire 1认证用户 2016-2-18 22#
这个应该是免费的
我的为什么要收1200换板子啊,升级固件前是好的,升级固件失败就坏了,返厂说过了半年质保,需自费1200修
秋香  超级版主 2016-2-18 23#
会飞的虎 发表于 2016-2-18 10:13
我的为什么要收1200换板子啊,升级固件前是好的,升级固件失败就坏了,返厂说过了半年质保,需自费1200修 ...
也是这个1500 0800升级出问题了吗?
会飞的虎  Inspire 1认证用户 2016-2-18 24#
是的,我发过帖子http://bbs.dji.com/thread-38335-1-1.html,里面有LOG文件
会飞的虎  Inspire 1认证用户 2016-2-18 25#
[size=15.65217399597168px][00015878]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00015927]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x98a5e888].
[size=15.65217399597168px][00015978]Packet upgrade start...
[size=15.65217399597168px][00016030]Packet checking...
[size=15.65217399597168px][00016074]Packet vlink 01.05.0030 <-> 01.04.0010.
[size=15.65217399597168px][00016121]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00016169]Done.
[size=15.65217399597168px][00016212]Version checking[1]...
[size=15.65217399597168px][00016286][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00016360][03 06][00] v2.3.0.13 -> v2.4.0.5 need upgrade.
[size=15.65217399597168px][00016412][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00016540][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00016634][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00016710][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00016805][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00016892][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00029454][15 00][00] device not detected.
[size=15.65217399597168px][00029550][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00029672][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00029751][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00029795][01 00][00] v1.23.3419 -> v1.26.4315 need upgrade
[size=15.65217399597168px][00029847][01 01][00] v1.23.3419 -> v1.26.4315 need upgrade
[size=15.65217399597168px][00042392][08 00][00] device not detected.
[size=15.65217399597168px][00042451][09 00][00] v1.7.0.3 -> v2.13.0.0 need upgrade.
[size=15.65217399597168px][00042574]Done.
[size=15.65217399597168px][00044621]Waiting for user confirm...
[size=15.65217399597168px][00054669]Timeout, start upgrade automatically.
[size=15.65217399597168px][00054759]Firmware upgrading[1]...
[size=15.65217399597168px][00067556][01 00] Firmware upgrade start...
[size=15.65217399597168px][00014147][01 00] Firmware upgrade finished successfully.
[size=15.65217399597168px][00014193]Done.
[size=15.65217399597168px][00014240]Packet [C:\P3X_FW_V01.05.0030.bin] resumed, card sn [0x98a5e888].
[size=15.65217399597168px][00014294]Packet vlink 01.05.0030 <-> 01.04.0010.
[size=15.65217399597168px][00014348]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00014394]Version checking[2]...
[size=15.65217399597168px][00014476][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00014577][03 06][00] v2.3.0.13 -> v2.4.0.5 need upgrade.
[size=15.65217399597168px][00014647][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00014775][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00014884][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00014984][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015065][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015165][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00027712][15 00][00] device not detected.
[size=15.65217399597168px][00027801][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00027940][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00028001][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00028048][01 00][05] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00028098][01 01][00] v1.23.3419 -> v1.26.4315 need upgrade
[size=15.65217399597168px][00040648][08 00][00] device not detected.
[size=15.65217399597168px][00040721][09 00][00] v1.7.0.3 -> v2.13.0.0 need upgrade.
[size=15.65217399597168px][00040772]Done.
[size=15.65217399597168px][00040819]Firmware upgrading[2]...
[size=15.65217399597168px][00040986][01 01] Firmware upgrade start...
[size=15.65217399597168px][00071266][01 01] Firmware upgrade finished successfully.
[size=15.65217399597168px][00071532][03 06] Firmware upgrade start...
[size=15.65217399597168px][00390117][03 06] Firmware upgrade finished successfully.
[size=15.65217399597168px][00390197][09 00] Firmware upgrade start...
[size=15.65217399597168px][00444320][09 00] Firmware upgrade finished successfully.
[size=15.65217399597168px][00444367]Done.
[size=15.65217399597168px][00444417]Version checking[3]...
[size=15.65217399597168px][00444487][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00444572][03 06][05] v2.4.0.5 -> v2.4.0.5
[size=15.65217399597168px][00444624][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00444747][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00444847][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00444936][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00445021][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00445216][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00457770][15 00][00] device not detected.
[size=15.65217399597168px][00457852][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00457972][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00458037][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00458091][01 00][05] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00458141][01 01][05] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00470690][08 00][00] device not detected.
[size=15.65217399597168px][00470764][09 00][05] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00470812]Packet upgrade failed at version checking.
[size=15.65217399597168px][00015916]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00015973]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x98a5e888].
[size=15.65217399597168px][00016022]Packet upgrade start...
[size=15.65217399597168px][00016078]Packet checking...
[size=15.65217399597168px][00016131]Packet vlink 01.05.0030 <-> 01.04.0010.
[size=15.65217399597168px][00016179]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00016229]Done.
[size=15.65217399597168px][00016277]Version checking[1]...
[size=15.65217399597168px][00016359][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00016439][03 06][00] v2.4.0.5 -> v2.4.0.5
[size=15.65217399597168px][00016498][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00016619][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00016713][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00016812][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00016912][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00017032][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00029581][15 00][00] device not detected.
[size=15.65217399597168px][00029672][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00029788][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00029869][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00029919][01 00][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00029970][01 01][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00042525][08 00][00] device not detected.
[size=15.65217399597168px][00042590][09 00][00] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00042638]Packet upgrade failed at version checking.
[size=15.65217399597168px][00015313]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00015366]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x98a5e888].
[size=15.65217399597168px][00015413]Packet upgrade start...
[size=15.65217399597168px][00015472]Packet checking...
[size=15.65217399597168px][00015520]Packet vlink 01.06.0040 <-> 01.05.0030.
[size=15.65217399597168px][00015570]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00015618]Done.
[size=15.65217399597168px][00015744]Version checking[1]...
[size=15.65217399597168px][00015830][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015915][03 06][00] v2.4.0.5 -> v2.4.10.7 need upgrade.
[size=15.65217399597168px][00015983][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00016095][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[size=15.65217399597168px][00016204][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00016304][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00016405][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00016504][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00029052][15 00][00] device not detected.
[size=15.65217399597168px][00029159][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00029285][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00029366][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00029414][01 00][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00029463][01 01][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00042018][08 00][00] device not detected.
[size=15.65217399597168px][00042086][09 00][00] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00042137]Done.
[size=15.65217399597168px][00044194]Waiting for user confirm...
[size=15.65217399597168px][00054240]Timeout, start upgrade automatically.
[size=15.65217399597168px][00054338]Firmware upgrading[1]...
[size=15.65217399597168px][00054393][11 00] Firmware upgrade start...
[size=15.65217399597168px][00102195][11 00] Firmware upgrade finished successfully.
[size=15.65217399597168px][00102437][03 06] Firmware upgrade start...
[size=15.65217399597168px][00429425][03 06] Firmware upgrade finished successfully.
[size=15.65217399597168px][00429475]Done.
[size=15.65217399597168px][00429526]Version checking[2]...
[size=15.65217399597168px][00429610][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00429690][03 06][05] v2.4.10.7 -> v2.4.10.7
[size=15.65217399597168px][00429753][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00429892][11 00][05] v1.7.15.1 -> v1.7.15.1
[size=15.65217399597168px][00430005][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00430110][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00430211][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00430310][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00442863][15 00][00] device not detected.
[size=15.65217399597168px][00442955][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00443085][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00443151][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00443202][01 00][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00443259][01 01][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00455806][08 00][00] device not detected.
[size=15.65217399597168px][00455872][09 00][00] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00455928]Packet upgrade failed at version checking.
[size=15.65217399597168px][00015470]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00015614]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x98a5e888].
[size=15.65217399597168px][00015669]Packet upgrade start...
[size=15.65217399597168px][00015740]Packet checking...
[size=15.65217399597168px][00015788]Packet vlink 01.06.0040 <-> 01.05.0030.
[size=15.65217399597168px][00015839]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00015889]Done.
[size=15.65217399597168px][00015942]Version checking[1]...
[size=15.65217399597168px][00016032][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00016111][03 06][00] v2.4.10.7 -> v2.4.10.7
[size=15.65217399597168px][00016172][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00016287][11 00][00] v1.7.15.1 -> v1.7.15.1
[size=15.65217399597168px][00016395][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00016487][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00016587][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00016687][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00029245][15 00][00] device not detected.
[size=15.65217399597168px][00029336][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00029476][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00029556][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00029608][01 00][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00029659][01 01][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00042225][08 00][00] device not detected.
[size=15.65217399597168px][00042296][09 00][00] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00042347]Packet upgrade failed at version checking.
[size=15.65217399597168px][00015352]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00015406]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x98a5e888].
[size=15.65217399597168px][00015457]Packet upgrade start...
[size=15.65217399597168px][00015512]Packet checking...
[size=15.65217399597168px][00015570]Packet vlink 01.05.0030 <-> 01.04.0010.
[size=15.65217399597168px][00015621]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00015674]Done.
[size=15.65217399597168px][00015733]Version checking[1]...
[size=15.65217399597168px][00015818][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015918][03 06][00] v2.4.10.7 -> v2.4.0.5
[size=15.65217399597168px][00015975][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00016118][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00016226][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00016328][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00016426][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00016531][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00029081][15 00][00] device not detected.
[size=15.65217399597168px][00029187][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00029338][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00029499][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00029556][01 00][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00029611][01 01][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00042162][08 00][00] device not detected.
[size=15.65217399597168px][00042239][09 00][00] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00042292]Packet upgrade failed at version checking.
[size=15.65217399597168px][00016110]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00016165]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x98a5e888].
[size=15.65217399597168px][00016212]Packet upgrade start...
[size=15.65217399597168px][00016275]Packet checking...
[size=15.65217399597168px][00016327]Packet vlink 01.04.0010 <-> 01.03.0020.
[size=15.65217399597168px][00016377]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00016432]Done.
[size=15.65217399597168px][00016481]Version checking[1]...
[size=15.65217399597168px][00016583][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00016683][03 06][00] v2.4.10.7 -> v2.3.0.13
[size=15.65217399597168px][00016749][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00016825][09 00][00] v2.13.0.0 -> v1.7.0.3
[size=15.65217399597168px][00016968][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00017083][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00017192][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00017292][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00017393][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00029947][15 00][00] device not detected.
[size=15.65217399597168px][00030053][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00030194][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00030265][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00030320][01 00][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00030374][01 01][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00042923][08 00][00] device not detected.
[size=15.65217399597168px][00042977]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014488]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00014530]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0xbd86065d].
[size=15.65217399597168px][00014575]Packet upgrade start...
[size=15.65217399597168px][00014626]Packet checking...
[size=15.65217399597168px][00014672]Packet vlink 01.06.0040 <-> 01.05.0030.
[size=15.65217399597168px][00014715]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00014755]Done.
[size=15.65217399597168px][00014803]Version checking[1]...
[size=15.65217399597168px][00014896][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00014996][03 06][00] v2.4.10.7 -> v2.4.10.7
[size=15.65217399597168px][00015057][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00015176][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[size=15.65217399597168px][00015372][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015496][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015600][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015706][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00028252][15 00][00] device not detected.
[size=15.65217399597168px][00028366][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028506][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00028572][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00028616][01 00][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00028668][01 01][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00041212][08 00][00] device not detected.
[size=15.65217399597168px][00041292][09 00][00] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00041340]Done.
[size=15.65217399597168px][00043382]Waiting for user confirm...
[size=15.65217399597168px][00053427]Timeout, start upgrade automatically.
[size=15.65217399597168px][00053520]Firmware upgrading[1]...
[size=15.65217399597168px][00053567][11 00] Firmware upgrade start...
[size=15.65217399597168px][00101236][11 00] Firmware upgrade finished successfully.
[size=15.65217399597168px][00101278]Done.
[size=15.65217399597168px][00101325]Version checking[2]...
[size=15.65217399597168px][00101407][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00101506][03 06][00] v2.4.10.7 -> v2.4.10.7
[size=15.65217399597168px][00101564][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00101682][11 00][05] v1.7.15.1 -> v1.7.15.1
[size=15.65217399597168px][00101790][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00101890][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00101990][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00102117][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00114664][15 00][00] device not detected.
[size=15.65217399597168px][00114772][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00114911][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00114976][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00115021][01 00][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00115072][01 01][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00127620][08 00][00] device not detected.
[size=15.65217399597168px][00127676][09 00][00] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00127727]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014521]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00014565]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0xbd86065d].
[size=15.65217399597168px][00014613]Packet upgrade start...
[size=15.65217399597168px][00014659]Packet checking...
[size=15.65217399597168px][00014701]Packet vlink 01.06.0040 <-> 01.05.0030.
[size=15.65217399597168px][00014745]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00014878]Done.
[size=15.65217399597168px][00014928]Version checking[1]...
[size=15.65217399597168px][00015011][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015111][03 06][00] v2.4.10.7 -> v2.4.10.7
[size=15.65217399597168px][00015166][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00015290][11 00][00] v1.7.15.1 -> v1.7.15.1
[size=15.65217399597168px][00015379][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015479][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015579][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015679][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00028226][15 00][00] device not detected.
[size=15.65217399597168px][00028320][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028454][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00028510][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00028555][01 00][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00028606][01 01][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00041150][08 00][00] device not detected.
[size=15.65217399597168px][00041211][09 00][00] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00041258]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014524]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00014567]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0xbd86065d].
[size=15.65217399597168px][00014621]Packet upgrade start...
[size=15.65217399597168px][00014667]Packet checking...
[size=15.65217399597168px][00014712]Packet vlink 01.06.0040 <-> 01.05.0030.
[size=15.65217399597168px][00014761]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00014803]Done.
[size=15.65217399597168px][00014852]Version checking[1]...
[size=15.65217399597168px][00014924][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015001][03 06][00] v2.4.10.7 -> v2.4.10.7
[size=15.65217399597168px][00015063][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00015186][11 00][00] v1.7.15.1 -> v1.7.15.1
[size=15.65217399597168px][00015301][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015401][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015510][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015600][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00028147][15 00][00] device not detected.
[size=15.65217399597168px][00028232][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028352][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00028410][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00028462][01 00][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00028509][01 01][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00041054][08 00][00] device not detected.
[size=15.65217399597168px][00041116][09 00][00] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00041160]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014762]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00014814]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x98a5e888].
[size=15.65217399597168px][00014876]Packet upgrade start...
[size=15.65217399597168px][00014941]Packet checking...
[size=15.65217399597168px][00014993]Packet vlink 01.06.0040 <-> 01.05.0030.
[size=15.65217399597168px][00015052]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00015109]Done.
[size=15.65217399597168px][00015167]Version checking[1]...
[size=15.65217399597168px][00015261][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015381][03 06][00] v2.4.10.7 -> v2.4.10.7
[size=15.65217399597168px][00015445][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00015580][11 00][00] v1.7.15.1 -> v1.7.15.1
[size=15.65217399597168px][00015685][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015785][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015885][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015985][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00028545][15 00][00] device not detected.
[size=15.65217399597168px][00028646][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028766][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00028832][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00028891][01 00][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00028950][01 01][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00041503][08 00][00] device not detected.
[size=15.65217399597168px][00041592][09 00][00] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00041644]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014510]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00014555]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0xbd86065d].
[size=15.65217399597168px][00014607]Packet upgrade start...
[size=15.65217399597168px][00014656]Packet checking...
[size=15.65217399597168px][00014701]Packet vlink 01.05.0030 <-> 01.04.0010.
[size=15.65217399597168px][00014752]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00014798]Done.
[size=15.65217399597168px][00014847]Version checking[1]...
[size=15.65217399597168px][00014928][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015007][03 06][00] v2.4.10.7 -> v2.4.0.5
[size=15.65217399597168px][00015068][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00015188][11 00][00] v1.7.15.1 -> v1.7.0.0
[size=15.65217399597168px][00015291][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015387][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015491][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015587][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00028134][15 00][00] device not detected.
[size=15.65217399597168px][00028234][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028462][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00028532][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00028579][01 00][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00028632][01 01][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00041179][08 00][00] device not detected.
[size=15.65217399597168px][00041273][09 00][00] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00041316]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014522]========== 2015.12.27 23:52:20. boot(15) ============
[size=15.65217399597168px][00014566]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0xbd86065d].
[size=15.65217399597168px][00014609]Packet upgrade start...
[size=15.65217399597168px][00014789]Done.
[size=15.65217399597168px][00014834]Version checking[1]...
[size=15.65217399597168px][00014916][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015016][03 06][00] v2.4.10.7 -> v2.4.0.5
[size=15.65217399597168px][00015075][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00015196][11 00][00] v1.7.15.1 -> v1.7.0.0
[size=15.65217399597168px][00015305][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015405][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015505][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015605][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00028150][15 00][00] device not detected.
[size=15.65217399597168px][00028245][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028369][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00028433][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00028477][01 00][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00028521][01 01][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00041065][08 00][00] device not detected.
[size=15.65217399597168px][00041140][09 00][00] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00041183]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014559]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00014605]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0xbd86065d].
[size=15.65217399597168px][00014660]Packet upgrade start...
[size=15.65217399597168px][00014710]Packet checking...
[size=15.65217399597168px][00014757]Packet vlink 01.06.0040 <-> 01.05.0030.
[size=15.65217399597168px][00014810]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00014858]Done.
[size=15.65217399597168px][00014904]Version checking[1]...
[size=15.65217399597168px][00015001][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015102][03 06][00] v2.4.10.7 -> v2.4.10.7
[size=15.65217399597168px][00015161][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00015382][11 00][00] v1.7.15.1 -> v1.7.15.1
[size=15.65217399597168px][00015470][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015570][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015670][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015770][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00028321][15 00][00] device not detected.
[size=15.65217399597168px][00028425][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028565][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00028626][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00028675][01 00][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00028724][01 01][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00041271][08 00][00] device not detected.
[size=15.65217399597168px][00041340][09 00][00] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00041386]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014572]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00014624]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0xbd86065d].
[size=15.65217399597168px][00014673]Packet upgrade start...
[size=15.65217399597168px][00014721]Packet checking...
[size=15.65217399597168px][00014770]Packet vlink 01.06.0040 <-> 01.05.0030.
[size=15.65217399597168px][00014823]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00014872]Done.
[size=15.65217399597168px][00014919]Version checking[1]...
[size=15.65217399597168px][00015003][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015103][03 06][00] v2.4.10.7 -> v2.4.10.7
[size=15.65217399597168px][00015165][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00015283][11 00][00] v1.7.15.1 -> v1.7.15.1
[size=15.65217399597168px][00015371][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015471][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015571][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015671][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00028219][15 00][00] device not detected.
[size=15.65217399597168px][00028332][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028477][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00028548][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00028598][01 00][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00028649][01 01][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00041201][08 00][00] device not detected.
[size=15.65217399597168px][00041288][09 00][00] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00041342]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014556]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00014608]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0xbd86065d].
[size=15.65217399597168px][00014659]Packet upgrade start...
[size=15.65217399597168px][00014798]Packet checking...
[size=15.65217399597168px][00014850]Packet vlink 01.06.0040 <-> 01.05.0030.
[size=15.65217399597168px][00014896]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00014951]Done.
[size=15.65217399597168px][00014996]Version checking[1]...
[size=15.65217399597168px][00015097][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015183][03 06][00] v2.4.10.7 -> v2.4.10.7
[size=15.65217399597168px][00015257][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00015378][11 00][00] v1.7.15.1 -> v1.7.15.1
[size=15.65217399597168px][00015485][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015585][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015685][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015785][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00028332][15 00][00] device not detected.
[size=15.65217399597168px][00028430][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028576][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00028662][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00028710][01 00][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00028765][01 01][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00041311][08 00][00] device not detected.
[size=15.65217399597168px][00041382][09 00][00] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00041431]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014628]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00014679]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0xbd86065d].
[size=15.65217399597168px][00014726]Packet upgrade start...
[size=15.65217399597168px][00014783]Packet checking...
[size=15.65217399597168px][00014835]Packet vlink 01.06.0040 <-> 01.05.0030.
[size=15.65217399597168px][00014887]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00014943]Done.
[size=15.65217399597168px][00014990]Version checking[1]...
[size=15.65217399597168px][00015092][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015173][03 06][00] v2.4.10.7 -> v2.4.10.7
[size=15.65217399597168px][00015244][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00015376][11 00][00] v1.7.15.1 -> v1.7.15.1
[size=15.65217399597168px][00028337][15 00][00] device not detected.
[size=15.65217399597168px][00028440][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028581][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00028656][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00028704][01 00][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00028760][01 01][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00041399][08 00][00] device not detected.
[size=15.65217399597168px][00041499][09 00][00] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00041548]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014612]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xbd86065d].
[size=15.65217399597168px][00014661]Packet upgrade start...
[size=15.65217399597168px][00014714]Packet checking...
[size=15.65217399597168px][00014769]Packet vlink 01.04.0010 <-> 01.03.0020.
[size=15.65217399597168px][00014821]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00014876]Done.
[size=15.65217399597168px][00014930]Version checking[1]...
[size=15.65217399597168px][00015027][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015125][03 06][00] v2.4.10.7 -> v2.3.0.13
[size=15.65217399597168px][00015184][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00015279][09 00][00] v2.13.0.0 -> v1.7.0.3
[size=15.65217399597168px][00015412][11 00][00] v1.7.15.1 -> v1.7.0.0
[size=15.65217399597168px][00015525][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015633][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015733][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015833][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00028384][15 00][00] device not detected.
[size=15.65217399597168px][00028515][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028655][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00028720][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00028775][01 00][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00028829][01 01][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00041378][08 00][00] device not detected.
[size=15.65217399597168px][00041429]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014791]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00014849]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x98a5e888].
[size=15.65217399597168px][00014911]Packet upgrade start...
[size=15.65217399597168px][00014979]Packet checking...
[size=15.65217399597168px][00015042]Packet vlink 01.06.0040 <-> 01.05.0030.
[size=15.65217399597168px][00015100]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00015156]Done.
[size=15.65217399597168px][00015218]Version checking[1]...
[size=15.65217399597168px][00015318][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015418][03 06][00] v2.4.10.7 -> v2.4.10.7
[size=15.65217399597168px][00015487][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00015638][11 00][00] v1.7.15.1 -> v1.7.15.1
[size=15.65217399597168px][00015752][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015852][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015978][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00016166][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00028731][15 00][00] device not detected.
[size=15.65217399597168px][00028833][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028988][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00029064][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00029125][01 00][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00029184][01 01][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00041749][08 00][00] device not detected.
[size=15.65217399597168px][00041823][09 00][00] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00041880]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014824]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00014885]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x98a5e888].
[size=15.65217399597168px][00014944]Packet upgrade start...
[size=15.65217399597168px][00015009]Packet checking...
[size=15.65217399597168px][00015073]Packet vlink 01.06.0040 <-> 01.05.0030.
[size=15.65217399597168px][00015134]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00015197]Done.
[size=15.65217399597168px][00015251]Version checking[1]...
[size=15.65217399597168px][00015345][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015445][03 06][00] v2.4.10.7 -> v2.4.10.7
[size=15.65217399597168px][00015512][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00015645][11 00][00] v1.7.15.1 -> v1.7.15.1
[size=15.65217399597168px][00015749][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015849][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015949][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00016049][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00028610][15 00][00] device not detected.
[size=15.65217399597168px][00028696][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028840][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00028915][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00028979][01 00][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00029042][01 01][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00041598][08 00][00] device not detected.
[size=15.65217399597168px][00041676][09 00][00] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00041742]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014613]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0xbd86065d].
[size=15.65217399597168px][00014665]Packet upgrade start...
[size=15.65217399597168px][00014719]Packet checking...
[size=15.65217399597168px][00014777]Packet vlink 01.03.0020 <-> 01.01.0009.
[size=15.65217399597168px][00014829]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).
[size=15.65217399597168px][00014882]Done.
[size=15.65217399597168px][00015026]Version checking[1]...
[size=15.65217399597168px][00015112][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015198][03 06][00] v2.4.10.7 -> v2.2.6.19 need upgrade.
[size=15.65217399597168px][00015279][04 00][00] v1.41.0.0 -> v1.40.0.0 need upgrade.
[size=15.65217399597168px][00015356][09 00][00] v2.13.0.0 -> v1.7.0.3
[size=15.65217399597168px][00015492][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00015582][12 00][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00015680][12 01][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00015780][12 02][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00015892][12 03][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00028452][15 00][00] device not detected.
[size=15.65217399597168px][00028547][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028682][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00028762][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00028811][01 00][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00028866][01 01][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00041418][08 00][00] device not detected.
[size=15.65217399597168px][00041476]Done.
[size=15.65217399597168px][00043525]Waiting for user confirm...
[size=15.65217399597168px][00053578]Timeout, start upgrade automatically.
[size=15.65217399597168px][00053689]Firmware upgrading[1]...
[size=15.65217399597168px][00053893][03 06] Firmware upgrade start...
[size=15.65217399597168px][00355302][03 06] Firmware upgrade finished successfully.
[size=15.65217399597168px][00355375][04 00] Firmware upgrade start...
[size=15.65217399597168px][00412385][04 00] Firmware upgrade finished successfully.
[size=15.65217399597168px][00412437]Done.
[size=15.65217399597168px][00412493]Version checking[2]...
[size=15.65217399597168px][00412575][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00412680][03 06][05] v2.2.6.19 -> v2.2.6.19
[size=15.65217399597168px][00412747][04 00][05] v1.40.0.0 -> v1.40.0.0
[size=15.65217399597168px][00412820][09 00][00] v2.13.0.0 -> v1.7.0.3
[size=15.65217399597168px][00412942][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00413051][12 00][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00413151][12 01][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00413251][12 02][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00413351][12 03][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00425902][15 00][00] device not detected.
[size=15.65217399597168px][00426006][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00426151][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00426221][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00426273][01 00][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00426333][01 01][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00438884][08 00][00] device not detected.
[size=15.65217399597168px][00438937]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014565]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00014694]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0xbd86065d].
[size=15.65217399597168px][00014754]Packet upgrade start...
[size=15.65217399597168px][00014809]Packet checking...
[size=15.65217399597168px][00014862]Packet vlink 01.03.0020 <-> 01.01.0009.
[size=15.65217399597168px][00014922]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).
[size=15.65217399597168px][00014977]Done.
[size=15.65217399597168px][00015029]Version checking[1]...
[size=15.65217399597168px][00015127][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015227][03 06][00] v2.2.6.19 -> v2.2.6.19
[size=15.65217399597168px][00015292][04 00][00] v1.40.0.0 -> v1.40.0.0
[size=15.65217399597168px][00015367][09 00][00] v2.13.0.0 -> v1.7.0.3
[size=15.65217399597168px][00015508][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00015618][12 00][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00015717][12 01][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00015817][12 02][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00015917][12 03][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00028469][15 00][00] device not detected.
[size=15.65217399597168px][00028573][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028738][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00028808][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00028865][01 00][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00028926][01 01][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00041478][08 00][00] device not detected.
[size=15.65217399597168px][00041532]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014579]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00014631]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xbd86065d].
[size=15.65217399597168px][00014685]Packet upgrade start...
[size=15.65217399597168px][00014746]Packet checking...
[size=15.65217399597168px][00014796]Packet vlink 01.04.0010 <-> 01.03.0020.
[size=15.65217399597168px][00014853]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00014912]Done.
[size=15.65217399597168px][00014962]Version checking[1]...
[size=15.65217399597168px][00015069][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015168][03 06][00] v2.2.6.19 -> v2.3.0.13 need upgrade.
[size=15.65217399597168px][00015245][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[size=15.65217399597168px][00015308][09 00][00] v2.13.0.0 -> v1.7.0.3
[size=15.65217399597168px][00015453][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00015562][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015689][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015799][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015923][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00028479][15 00][00] device not detected.
[size=15.65217399597168px][00028579][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028824][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00028890][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00028947][01 00][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00029001][01 01][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00041561][08 00][00] device not detected.
[size=15.65217399597168px][00041620]Done.
[size=15.65217399597168px][00043675]Waiting for user confirm...
[size=15.65217399597168px][00053728]Timeout, start upgrade automatically.
[size=15.65217399597168px][00053843]Firmware upgrading[1]...
[size=15.65217399597168px][00054063][03 06] Firmware upgrade start...
[size=15.65217399597168px][00370405][03 06] Firmware upgrade finished successfully.
[size=15.65217399597168px][00370484][04 00] Firmware upgrade start...
[size=15.65217399597168px][00428064][04 00] Firmware upgrade finished successfully.
[size=15.65217399597168px][00428120]Done.
[size=15.65217399597168px][00428177]Version checking[2]...
[size=15.65217399597168px][00428315][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00428420][03 06][05] v2.3.0.13 -> v2.3.0.13
[size=15.65217399597168px][00428479][04 00][05] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00428553][09 00][00] v2.13.0.0 -> v1.7.0.3
[size=15.65217399597168px][00428693][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00428814][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00428922][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00429022][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00429122][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00441679][15 00][00] device not detected.
[size=15.65217399597168px][00441784][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00441944][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00442014][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00442071][01 00][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00442122][01 01][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00454683][08 00][00] device not detected.
[size=15.65217399597168px][00454734]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014598]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00014655]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0xbd86065d].
[size=15.65217399597168px][00014710]Packet upgrade start...
[size=15.65217399597168px][00014767]Packet checking...
[size=15.65217399597168px][00014820]Packet vlink 01.03.0020 <-> 01.01.0009.
[size=15.65217399597168px][00014877]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).
[size=15.65217399597168px][00014932]Done.
[size=15.65217399597168px][00014987]Version checking[1]...
[size=15.65217399597168px][00015095][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015175][03 06][00] v2.3.0.13 -> v2.2.6.19 need upgrade.
[size=15.65217399597168px][00015254][04 00][00] v1.41.0.0 -> v1.40.0.0 need upgrade.
[size=15.65217399597168px][00015412][09 00][00] v2.13.0.0 -> v1.7.0.3
[size=15.65217399597168px][00015559][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00015648][12 00][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00015748][12 01][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00015849][12 02][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00015951][12 03][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00028505][15 00][00] device not detected.
[size=15.65217399597168px][00028603][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028744][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00028829][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00028884][01 00][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00028945][01 01][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00041501][08 00][00] device not detected.
[size=15.65217399597168px][00041554]Done.
[size=15.65217399597168px][00043615]Waiting for user confirm...
[size=15.65217399597168px][00053672]Timeout, start upgrade automatically.
[size=15.65217399597168px][00053787]Firmware upgrading[1]...
[size=15.65217399597168px][00053993][03 06] Firmware upgrade start...
[size=15.65217399597168px][00354058][03 06] Firmware upgrade finished successfully.
[size=15.65217399597168px][00354141][04 00] Firmware upgrade start...
[size=15.65217399597168px][00410959][04 00] Firmware upgrade finished successfully.
[size=15.65217399597168px][00411020]Done.
[size=15.65217399597168px][00411078]Version checking[2]...
[size=15.65217399597168px][00411169][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00411247][03 06][05] v2.2.6.19 -> v2.2.6.19
[size=15.65217399597168px][00411314][04 00][05] v1.40.0.0 -> v1.40.0.0
[size=15.65217399597168px][00411393][09 00][00] v2.13.0.0 -> v1.7.0.3
[size=15.65217399597168px][00411527][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00411622][12 00][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00411742][12 01][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00411842][12 02][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00411942][12 03][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00424503][15 00][00] device not detected.
[size=15.65217399597168px][00424593][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00424742][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00424813][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00424873][01 00][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00424930][01 01][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00437500][08 00][00] device not detected.
[size=15.65217399597168px][00437552]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014597]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00014711]Packet upgrade start...
[size=15.65217399597168px][00014823]Packet vlink 01.03.0020 <-> 01.01.0009.
[size=15.65217399597168px][00014968]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).
[size=15.65217399597168px][00015025]Done.
[size=15.65217399597168px][00015087]Version checking[1]...
[size=15.65217399597168px][00015189][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015309][03 06][00] v2.2.6.19 -> v2.2.6.19
[size=15.65217399597168px][00015370][04 00][00] v1.40.0.0 -> v1.40.0.0
[size=15.65217399597168px][00015464][09 00][00] v2.13.0.0 -> v1.7.0.3
[size=15.65217399597168px][00015610][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00015724][12 00][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00015824][12 01][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00015945][12 02][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00016069][12 03][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00028627][15 00][00] device not detected.
[size=15.65217399597168px][00028740][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028899][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00028987][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00029044][01 00][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00029106][01 01][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00041663][08 00][00] device not detected.
[size=15.65217399597168px][00041720]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014600]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00014659]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xbd86065d].
[size=15.65217399597168px][00014716]Packet upgrade start...
[size=15.65217399597168px][00014779]Packet checking...
[size=15.65217399597168px][00014835]Packet vlink 01.04.0010 <-> 01.03.0020.
[size=15.65217399597168px][00014892]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00014954]Done.
[size=15.65217399597168px][00015011]Version checking[1]...
[size=15.65217399597168px][00015212][03 06][00] v2.2.6.19 -> v2.3.0.13 need upgrade.
[size=15.65217399597168px][00015292][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[size=15.65217399597168px][00015532][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00015647][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015768][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015893][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00016002][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00028561][15 00][00] device not detected.
[size=15.65217399597168px][00028669][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028891][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00028951][01 00][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00029006][01 01][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00041642][08 00][00] device not detected.
[size=15.65217399597168px][00041694]Done.
[size=15.65217399597168px][00043752]Waiting for user confirm...
[size=15.65217399597168px][00053817]Timeout, start upgrade automatically.
[size=15.65217399597168px][00053929]Firmware upgrading[1]...
[size=15.65217399597168px][00054154][03 06] Firmware upgrade start...
[size=15.65217399597168px][00359782][03 06] Firmware upgrade finished successfully.
[size=15.65217399597168px][00359861][04 00] Firmware upgrade start...
[size=15.65217399597168px][00417475][04 00] Firmware upgrade finished successfully.
[size=15.65217399597168px][00417534]Done.
[size=15.65217399597168px][00417592]Version checking[2]...
[size=15.65217399597168px][00417717][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00417819][03 06][05] v2.3.0.13 -> v2.3.0.13
[size=15.65217399597168px][00417882][04 00][05] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00417951][09 00][00] v2.13.0.0 -> v1.7.0.3
[size=15.65217399597168px][00418098][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00418227][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00418352][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00418472][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00418586][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00431143][15 00][00] device not detected.
[size=15.65217399597168px][00431267][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00431427][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00431498][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00431554][01 00][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00431609][01 01][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00444177][08 00][00] device not detected.
[size=15.65217399597168px][00444233]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014620]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00014678]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0xbd86065d].
[size=15.65217399597168px][00014732]Packet upgrade start...
[size=15.65217399597168px][00014796]Packet checking...
[size=15.65217399597168px][00014856]Packet vlink 01.05.0030 <-> 01.04.0010.
[size=15.65217399597168px][00014915]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00014971]Done.
[size=15.65217399597168px][00015133][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015237][03 06][00] v2.3.0.13 -> v2.4.0.5 need upgrade.
[size=15.65217399597168px][00015304][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00015454][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00015561][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015681][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015783][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015906][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00028552][15 00][00] device not detected.
[size=15.65217399597168px][00028662][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028822][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00028894][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00028948][01 00][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00029013][01 01][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00041574][08 00][00] device not detected.
[size=15.65217399597168px][00041674][09 00][00] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00041728]Done.
[size=15.65217399597168px][00043786]Waiting for user confirm...
[size=15.65217399597168px][00053851]Timeout, start upgrade automatically.
[size=15.65217399597168px][00053964]Firmware upgrading[1]...
[size=15.65217399597168px][00054194][03 06] Firmware upgrade start...
[size=15.65217399597168px][00368006][03 06] Firmware upgrade finished successfully.
[size=15.65217399597168px][00368066]Done.
[size=15.65217399597168px][00368120]Version checking[2]...
[size=15.65217399597168px][00368213][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00368354][03 06][05] v2.4.0.5 -> v2.4.0.5
[size=15.65217399597168px][00368422][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00368577][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00368707][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00368827][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00368954][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00369064][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00381620][15 00][00] device not detected.
[size=15.65217399597168px][00381723][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00381863][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00381933][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00381997][01 00][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00382058][01 01][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00394623][08 00][00] device not detected.
[size=15.65217399597168px][00394694][09 00][00] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00394751]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014627]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00014686]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xbd86065d].
[size=15.65217399597168px][00014745]Packet upgrade start...
[size=15.65217399597168px][00014806]Packet checking...
[size=15.65217399597168px][00014866]Packet vlink 01.04.0010 <-> 01.03.0020.
[size=15.65217399597168px][00014926]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00014989]Done.
[size=15.65217399597168px][00015050]Version checking[1]...
[size=15.65217399597168px][00015132][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015212][03 06][00] v2.4.0.5 -> v2.3.0.13
[size=15.65217399597168px][00015293][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00015366][09 00][00] v2.13.0.0 -> v1.7.0.3
[size=15.65217399597168px][00015597][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00015726][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015827][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015926][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00016026][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00028588][15 00][00] device not detected.
[size=15.65217399597168px][00028702][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028847][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00028927][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00028986][01 00][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00029045][01 01][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00041604][08 00][00] device not detected.
[size=15.65217399597168px][00041667]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014735]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00014800]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0xbd86065d].
[size=15.65217399597168px][00014862]Packet upgrade start...
[size=15.65217399597168px][00014924]Packet checking...
[size=15.65217399597168px][00014991]Packet vlink 01.03.0020 <-> 01.01.0009.
[size=15.65217399597168px][00015053]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).
[size=15.65217399597168px][00015118]Done.
[size=15.65217399597168px][00015179]Version checking[1]...
[size=15.65217399597168px][00015283][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015403][03 06][00] v2.4.0.5 -> v2.2.6.19 need upgrade.
[size=15.65217399597168px][00015486][04 00][00] v1.41.0.0 -> v1.40.0.0 need upgrade.
[size=15.65217399597168px][00015572][09 00][00] v2.13.0.0 -> v1.7.0.3
[size=15.65217399597168px][00015738][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00015837][12 00][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00015937][12 01][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00016037][12 02][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00016137][12 03][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00028698][15 00][00] device not detected.
[size=15.65217399597168px][00028808][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028956][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00029034][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00029094][01 00][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00029154][01 01][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00041713][08 00][00] device not detected.
[size=15.65217399597168px][00041773]Done.
[size=15.65217399597168px][00043835]Waiting for user confirm...
[size=15.65217399597168px][00053892]Timeout, start upgrade automatically.
[size=15.65217399597168px][00054012]Firmware upgrading[1]...
[size=15.65217399597168px][00054224][03 06] Firmware upgrade start...
[size=15.65217399597168px][00343802][03 06] Firmware upgrade finished successfully.
[size=15.65217399597168px][00343882][04 00] Firmware upgrade start...
[size=15.65217399597168px][00400750][04 00] Firmware upgrade finished successfully.
[size=15.65217399597168px][00400812]Done.
[size=15.65217399597168px][00400880]Version checking[2]...
[size=15.65217399597168px][00400980][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00401100][03 06][05] v2.2.6.19 -> v2.2.6.19
[size=15.65217399597168px][00401174][04 00][05] v1.40.0.0 -> v1.40.0.0
[size=15.65217399597168px][00401277][09 00][00] v2.13.0.0 -> v1.7.0.3
[size=15.65217399597168px][00401420][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00401560][12 00][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00401670][12 01][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00401798][12 02][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00401926][12 03][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00414491][15 00][00] device not detected.
[size=15.65217399597168px][00414611][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00414766][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00414836][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00414901][01 00][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00414963][01 01][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00427531][08 00][00] device not detected.
[size=15.65217399597168px][00427592]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014659]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00014721]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0xbd86065d].
[size=15.65217399597168px][00014787]Packet upgrade start...
[size=15.65217399597168px][00014851]Packet checking...
[size=15.65217399597168px][00014914]Packet vlink 01.03.0020 <-> 01.01.0009.
[size=15.65217399597168px][00014974]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 1).
[size=15.65217399597168px][00015035]Done.
[size=15.65217399597168px][00015096]Version checking[1]...
[size=15.65217399597168px][00015199][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015319][03 06][00] v2.2.6.19 -> v2.2.6.19
[size=15.65217399597168px][00015390][04 00][00] v1.40.0.0 -> v1.40.0.0
[size=15.65217399597168px][00015480][09 00][00] v2.13.0.0 -> v1.7.0.3
[size=15.65217399597168px][00015620][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00015754][12 00][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00015874][12 01][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00015999][12 02][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00016109][12 03][00] v1.10.0.0 -> v1.8.0.0
[size=15.65217399597168px][00028670][15 00][00] device not detected.
[size=15.65217399597168px][00028797][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028954][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00029041][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00029103][01 00][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00029169][01 01][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00041738][08 00][00] device not detected.
[size=15.65217399597168px][00041892]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014667]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00014729]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xbd86065d].
[size=15.65217399597168px][00014796]Packet upgrade start...
[size=15.65217399597168px][00014862]Packet checking...
[size=15.65217399597168px][00014925]Packet vlink 01.04.0010 <-> 01.03.0020.
[size=15.65217399597168px][00014993]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00015057]Done.
[size=15.65217399597168px][00015123]Version checking[1]...
[size=15.65217399597168px][00015224][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015345][03 06][00] v2.2.6.19 -> v2.3.0.13 need upgrade.
[size=15.65217399597168px][00015412][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[size=15.65217399597168px][00015512][09 00][00] v2.13.0.0 -> v1.7.0.3
[size=15.65217399597168px][00015646][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00015759][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015885][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00016004][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00016119][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00028684][15 00][00] device not detected.
[size=15.65217399597168px][00029031][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00029093][01 00][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00029155][01 01][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00041716][08 00][00] device not detected.
[size=15.65217399597168px][00041778]Done.
[size=15.65217399597168px][00043847]Waiting for user confirm...
[size=15.65217399597168px][00053914]Timeout, start upgrade automatically.
[size=15.65217399597168px][00054043]Firmware upgrading[1]...
[size=15.65217399597168px][00054270][03 06] Firmware upgrade start...
[size=15.65217399597168px][00369106][03 06] Firmware upgrade finished successfully.
[size=15.65217399597168px][00369193][04 00] Firmware upgrade start...
[size=15.65217399597168px][00426677][04 00] Firmware upgrade finished successfully.
[size=15.65217399597168px][00426744]Done.
[size=15.65217399597168px][00426807]Version checking[2]...
[size=15.65217399597168px][00426905][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00427005][03 06][05] v2.3.0.13 -> v2.3.0.13
[size=15.65217399597168px][00427090][04 00][05] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00427174][09 00][00] v2.13.0.0 -> v1.7.0.3
[size=15.65217399597168px][00427365][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00427480][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00427580][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00427699][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00427814][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00440451][15 00][00] device not detected.
[size=15.65217399597168px][00440555][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00440695][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00440795][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00440861][01 00][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00440929][01 01][00] v1.26.4315 -> v1.23.3419
[size=15.65217399597168px][00453491][08 00][00] device not detected.
[size=15.65217399597168px][00453554]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014658]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00014722]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0xbd86065d].
[size=15.65217399597168px][00014789]Packet upgrade start...
[size=15.65217399597168px][00014855]Packet checking...
[size=15.65217399597168px][00014924]Packet vlink 01.05.0030 <-> 01.04.0010.
[size=15.65217399597168px][00014987]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00015052]Done.
[size=15.65217399597168px][00015120]Version checking[1]...
[size=15.65217399597168px][00015218][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00015337][03 06][00] v2.3.0.13 -> v2.4.0.5 need upgrade.
[size=15.65217399597168px][00015404][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00015558][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00015682][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015807][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015933][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00016052][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00028620][15 00][00] device not detected.
[size=15.65217399597168px][00028723][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028888][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00028975][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00029040][01 00][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00029108][01 01][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00041671][08 00][00] device not detected.
[size=15.65217399597168px][00041755][09 00][00] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00041824]Done.
[size=15.65217399597168px][00043894]Waiting for user confirm...
[size=15.65217399597168px][00053961]Timeout, start upgrade automatically.
[size=15.65217399597168px][00054089]Firmware upgrading[1]...
[size=15.65217399597168px][00054326][03 06] Firmware upgrade start...
[size=15.65217399597168px][00376809][03 06] Firmware upgrade finished successfully.
[size=15.65217399597168px][00376872]Done.
[size=15.65217399597168px][00376940]Version checking[2]...
[size=15.65217399597168px][00377037][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00377136][03 06][05] v2.4.0.5 -> v2.4.0.5
[size=15.65217399597168px][00377202][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00377380][11 00][00] v1.7.0.0 -> v1.7.0.0
[size=15.65217399597168px][00377614][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00377749][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00377884][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00378009][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00390576][15 00][00] device not detected.
[size=15.65217399597168px][00390705][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00390865][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00390955][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00391021][01 00][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00391084][01 01][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00403656][08 00][00] device not detected.
[size=15.65217399597168px][00403757][09 00][00] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00403825]Packet upgrade failed at version checking.
[size=15.65217399597168px][00014665]========== remo-con disconnect. boot(15) ============
[size=15.65217399597168px][00014728]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0xbd86065d].
[size=15.65217399597168px][00014863]Packet checking...
[size=15.65217399597168px][00014933]Packet vlink 01.06.0040 <-> 01.05.0030.
[size=15.65217399597168px][00014995]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[size=15.65217399597168px][00015061]Done.
[size=15.65217399597168px][00015131]Version checking[1]...
[size=15.65217399597168px][00015324][03 06][00] v2.4.0.5 -> v2.4.10.7 need upgrade.
[size=15.65217399597168px][00015394][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00015544][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[size=15.65217399597168px][00015658][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015757][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00015877][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00016003][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00028567][15 00][00] device not detected.
[size=15.65217399597168px][00028694][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00028839][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00028914][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00029045][01 01][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00041614][08 00][00] device not detected.
[size=15.65217399597168px][00041714][09 00][00] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00041789]Done.
[size=15.65217399597168px][00043855]Waiting for user confirm...
[size=15.65217399597168px][00053919]Timeout, start upgrade automatically.
[size=15.65217399597168px][00054053]Firmware upgrading[1]...
[size=15.65217399597168px][00054129][11 00] Firmware upgrade start...
[size=15.65217399597168px][00099209][11 00] Firmware upgrade finished successfully.
[size=15.65217399597168px][00099519][03 06] Firmware upgrade start...
[size=15.65217399597168px][00415933][03 06] Firmware upgrade finished successfully.
[size=15.65217399597168px][00416002]Done.
[size=15.65217399597168px][00416067]Version checking[2]...
[size=15.65217399597168px][00416174][03 05][00] v34.2.0.9 -> v34.2.0.9
[size=15.65217399597168px][00416312][03 06][05] v2.4.10.7 -> v2.4.10.7
[size=15.65217399597168px][00416384][04 00][00] v1.41.0.0 -> v1.41.0.0
[size=15.65217399597168px][00416529][11 00][05] v1.7.15.1 -> v1.7.15.1
[size=15.65217399597168px][00416646][12 00][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00416774][12 01][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00416878][12 02][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00416980][12 03][00] v1.10.0.0 -> v1.10.0.0
[size=15.65217399597168px][00429546][15 00][00] device not detected.
[size=15.65217399597168px][00429659][17 00][00] v1.1.1.7 -> v1.1.1.7
[size=15.65217399597168px][00429825][17 01][00] v1.0.2.7 -> v1.0.2.7
[size=15.65217399597168px][00429898][19 00][00] v1.0.8.96 -> v1.0.8.96
[size=15.65217399597168px][00429963][01 00][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00430035][01 01][00] v1.26.4315 -> v1.26.4315
[size=15.65217399597168px][00442600][08 00][00] device not detected.
[size=15.65217399597168px][00442700][09 00][00] v2.13.0.0 -> v2.13.0.0
[size=15.65217399597168px][00442761]Packet upgrade failed at version checking.
石榴姐  超级版主 2016-2-19 26#
会飞的虎 发表于 2016-2-18 18:03
[00015878]========== remo-con disconnect. boot(15) ============
[00015927]Packet [C:\P3X_FW_V01.05 ...
楼主,非常抱歉,石榴姐来解释一下哈,对于这个问题的处理政策,为了提高用户的使用体验和满意度,我们近期有过小小的调整。所以导致了您之前的维修因为过保而收费,我查了您之前的帖子和CAS号码,您的维修流程是符合我们之前的政策的,所以石榴姐要向您表示歉意。希望您理解。
会飞的虎  Inspire 1认证用户 2016-2-19 27#
石榴姐 发表于 2016-2-19 17:22
楼主,非常抱歉,石榴姐来解释一下哈,对于这个问题的处理政策,为了提高用户的使用体验和满意度,我们 ...
能送块电池弥补一下吗?再不行送个T恤和帽子也行吧
夏清  超级版主 2016-2-20 28#
您留下您的QQ或邮箱吧,我们会与您联系沟通的。
会飞的虎  Inspire 1认证用户 2016-2-20 29#
QQ:425015631,邮箱:yixiong81752@sina.com,谢谢
夏清  超级版主 2016-2-20 30#
会飞的虎 发表于 2016-2-20 16:30
QQ:425015631,邮箱:,谢谢
OK,收到~
楼主  Osmo认证用户 2016-2-22 31#
QQ:425015631,邮箱:,谢谢
@会飞的虎  好几个美女给你服务,待遇不错了
Liceen  Phantom 3 Professional认证用户 2016-6-2 32#
我由1.4升级到1.7.60时候 也这样了 2个设备也找不到
louis.wong1226   2016-6-9 33#
我也是这样,停飞了一段时间,拿出来时升级了下固件,就无图传了。怎么办呢?
已累计飞行1119米
收藏 点赞 评论
