精灵3专业版遥控器图传信号满格但是显示“无图传信号”
前一天,飞完几块电池,好好的。
第二天,充好电,再准备开飞,一直显示“无图传信号”,换也所有的电池也是如此。
除了无图传,所有的操作都是正常的,包括在空中拍相片与视频的操作,回来后,SD卡里有数据,但是无实时的图传回来了。
然后也进行了重新对频,仍是不行。
摇控器通过DJI GO的App直接从 1.5.70升级到1.6.0成功
但是飞行器与电池升级时报
Packet: P3X_FW_V01.09.0060.bin
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
报错后,第二次再进行升级,也是报错。
但是启动后也是可以连接,仍无图传信号。
MISC/LOG的日志最后一些的是
[00015034]========== remo-con disconnect. boot(15) ============
[00015079]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0x6ad6b744].
[00015130]Packet upgrade start...
[00015187]Packet checking...
[00015240]Packet vlink 01.09.0060 <-> 01.08.0080.
[00015282]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00015330]Done.
[00015379]Version checking[1]...
[00015453][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015538][03 06][00] v2.4.20.18 -> v2.4.20.18
[00015587][04 00][00] v1.44.0.0 -> v1.44.0.0
[00015739][11 00][00] v1.7.15.1 -> v1.8.0.0 need upgrade.
[00015854][11 01][00] v1.7.15.1 -> v2.0.0.33, firmware v1.7.15.1 not support.
[00015904][11 01][00] v1.7.15.1 -> v2.0.0.33
[00016015][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016125][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016229][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016329][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028879][15 00][00] device not detected.
[00028984][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029124][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029194][19 00][00] v255.255.255.254 -> v1.0.8.96
[00029247][01 00][00] v1.30.5036 -> v1.30.5036
[00029367][01 01][00] v1.30.5036 -> v1.30.5036
[00041921][08 00][00] device not detected.
[00041994][09 00][00] v3.0.0.10 -> v3.0.0.10
[00042039]Done.
[00044090]Waiting for user confirm...
[00054137]Timeout, start upgrade automatically.
[00054239]Firmware upgrading[1]...
[00054300][11 00] Firmware upgrade start...
[00101314][11 00] Firmware upgrade finished successfully.
[00101362]Done.
[00101407]Version checking[2]...
[00101499][03 05][00] v34.2.0.9 -> v34.2.0.9
[00101581][03 06][00] v2.4.20.18 -> v2.4.20.18
[00101642][04 00][00] v1.44.0.0 -> v1.44.0.0
[00101759][11 00][05] v1.8.0.0 -> v1.8.0.0
[00101881][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00101928][11 01][00] v1.8.0.0 -> v2.0.0.33
[00102044][12 00][00] v1.10.0.0 -> v1.10.0.0
[00102144][12 01][00] v1.10.0.0 -> v1.10.0.0
[00102227][12 02][00] v1.10.0.0 -> v1.10.0.0
[00102319][12 03][00] v1.10.0.0 -> v1.10.0.0
[00114867][15 00][00] device not detected.
[00114968][17 00][00] v1.1.1.7 -> v1.1.1.7
[00115108][17 01][00] v1.0.2.7 -> v1.0.2.7
[00115179][19 00][00] v255.255.255.254 -> v1.0.8.96
[00115229][01 00][00] v1.30.5036 -> v1.30.5036
[00115275][01 01][00] v1.30.5036 -> v1.30.5036
[00127830][08 00][00] device not detected.
[00127900][09 00][00] v3.0.0.10 -> v3.0.0.10
[00127946]Packet upgrade failed at version checking.
其中有比较奇怪的输出是这些,
最后导致报错
有其他的解法么?谢谢!
