附上升级后完成的数据:
========== 2015.11.19 18:11:54 =====================
Packet: WM610_FC550_FW_V01.00.00.30_1012.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2016.03.11 22:19:11 =====================
Packet: WM610_FC550_FW_V01.04.00.70.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:12 remo-con disconnect======
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Packet: WM610_FC550_FW_V01.09.01.30.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:06 remo-con disconnect======
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the device.
========== 2014.01.01 00:00:05 remo-con disconnect======
Upgrading ...
Result: Success.
Result: Abort.
Upgrading ...
Result: Success.
Result: Abort.
Upgrading ...
Result: Success.
Result: Abort.
